mpg display
GlennWest
Mine is close as well. My suggestion would be to fill the truck and do a hand calc for the tank. See if the gauge is close. On my old Volvo, any and ever thing I do affects the mileage shown on the gauge. If I sit and High Idle at a rest area for 15 minutes the miles per gallon will drop really low. As soon as I get rolling and do a long run,2-300 miles the average comes back up to the 11-12.
Long idle times, start and stops, and city type driving kill the mileage.
You can scroll through the display and set up a "target" number which is in the center. Mine is set for 7.5 and the gauge jumps left to right. It is almost useless because it changes so much. The turbo boost gauge is a better indicator of real time fuel mileage.
I get from our Freightliner 14l about 7-9 depending on the wind and how much stop and go traffic I am in but I am a mid roof and not has tall as the condos. As Jeff says the reading in the center is a target mileage and is changeable. Ours is on 9.5. The separate readout for the actual MPG that you push some other buttons for and to get gallons used is not too far off but I find a typically get a better number by manually calculating.
Dave
The other big factor is the right foot.....
If I'm bobtail and on the interstate, I put the cruise on 66-67 and Cadilac along, 12-13mpg. If I decide to keep up with traffic at 74-78mph then we get 7-8mpg depending if I can draft another truck for awhile.
Slowing down is the best idea for better mileage.
I run 63 mph. That is where I am comfortable and the truck does best. I did have them put a 2 mph flat on the cruise when I had the completed programmed. I will take it off when I reprogram. I don't look at it as a fuel cost. It is a housing expense since I have to tow my house with me. It makes me feel a little better about it.
