Are You Driving A Manual Transmission HDT?
Cotreker
I have found the perfect truck or at least I think so but it has a Eaton 10 speed manual. Low miles, clean, price, nice paint, engine, right year, long w.b. but the transmission. Currently I drive a 6-speed manual F-350 with manual so I am use to the clutch.
Clearly there are more manual transmissions in HDT's than Auto's at least in the pre-2007 year HDT's. Pretty sure I understand the con's;
-Shifting
-Resale
Are you driving a manual HDT? If so tell me about your experience.
Without going into a long explanation,,,,,Can you drive your current truck with using the clutch for shifting? Can you do it smoothly? If so, you're on your way to being a real truck driver.
The manuals found in semis aren't black magic. They're just transmissions without synchronizers. You have to match the motor speed to the road speed and slip it into gear.
I have a 10 speed Rockwell in my Volvo, as I was a over the road driver back in the day, shifting is no problem for me.
I do like the fact that my old truck has very little electronics on it, no emissions on the M-11 and with a ME Shift, it will always start even in gear :rolleyes: .
As for resale, I don't plan to sell mine anytime soon, so with it's age, a 99, I don't think that will be a big factor.
Roger
My Volvo came with a 13 speed, it did require a little time to get used to some 12 years ago when I got it.
At this point it is completely 2nd nature.
It is reliable beyond most, always obeys, never complains or offers it own opinion on what it should be doing.....
In my view, based on your experience with your current manual transmission experience you should set aside a full day to get good at the 10 speed in the truck you have found.
After a day you will be shifting "ok".
After a month you will be happy.
Buying a PRE-EVEFYTHING truck has many advantages,
Good luck
Rick
Hewhoknowslittle, on 31 Jan 2017 - 08:07 AM, said:Hewhoknowslittle, on 31 Jan 2017 - 08:07 AM, said:
Roger
I knew that I had a picture of Rogers first truck somewhere and I finally found it. This was when Roger picked this truck up new and was just starting out as an over the road driver :lol:
I'm currently towing with a 92 Freightliner FLD 120, L-10 and a 9 speed. no issues for me, however, I did drive long haul, although it was 30 years ago, and I upgraded to the FLD from a 2000 F350 with a 6 speed.As others have said, shifting is a non issue once you get the hang of it, and it pays to not be in a hurry.
I owned CrazyCooters truck with a 13 Speed! Upshifting is easy as a hot knife through warm butter! Downshifting was a little tougher but not too bad. I think he bought one of those shifting computers but I believe he said after a few days didn't need it anymore but I'd recommend getting one.
Love my 10 speed. I had never driven an HDT before buying it. The GearMaster is a must have in my opinion. With that learning to drive the stick has been pretty easy.
Pretty much ditto. I have a 10 speed. Clutch brake was destroyed before I ever got it - but I do just fine without one. I did buy a Gearmaster with the intent of selling it later. But, I've become accustomed to having it even if I only occasionally look at it these days. My biggest issue was a weak left knee and holding the clutch in - it is pretty stiff (70#). I fabricated a pneumatic actuator for the clutch pedal and have no more issues. If I were buying another truck I would not let a manual transmission stop me if all else was what I wanted.
I have had 2 HDT haulers now, both manual. First was a straight 10 speed and current is super 10. Neither were bad to drive or had a horrible learning curve. Gearmaster will help a lot just because it tells you the range of gears available at a glance. I also like the fact the transmission is simple to have worked on or replaced if needed. I like shifting but to each their own. You will limit potential resale into RV market with manual. With that said if the truck meets everything else you want I would jump on it. There are a lot of trucks out there though so don't get impatient if you have reservations.
Nothing wrong with learning how to shift. Take your time, listen to the motor, don't force anything. You'll get the hang of it in no time. The HDT I am looking at is a 3406e with a 13 speed. I have my class 1 so no big deal.
If you got 10 minutes this guy is worth a watch.
https://www.youtube.com/watch?v=b5RzFtk0B9E&t=507s
This would be a great combo. I like Cat motors but beware the yellow paint is really "gold". If your going to have a manual my personal opinion is the 13 speed is a great option, lots of combos for gearing.
I have heard they are close to gold haha Luckily my brother in law runs a truck wrecker so hoping if I ever need parts or advice I got him to lean on.
Even when I drove trucks with 18's I almost always ran it as a 13 anyway.
On a side note, how did you guys link your you-tube videos so the video appeared right on the forum? I was only able to get the link to appear. Thanks in advance.
