Ron Posted January 16, 2017 Report Share Posted January 16, 2017 During certain winter weather conditions we sometimes find condensation on the walls inside the clothes closets of our TT. Does anyone know of a way to prevent the condensation or perhaps some practical way to prevent the clothes inside the closet from getting wet from the condensation? Link to comment Share on other sites More sharing options...
don&penny Posted January 17, 2017 Report Share Posted January 17, 2017 Many times it's a circulation problem. Keeping the closet doors open and perhaps a small fan circulating the air may help. Dry-z-air might also help. Don Link to comment Share on other sites More sharing options...
Kirk W Posted January 17, 2017 Report Share Posted January 17, 2017 It comes from the high humidity that tends to accumulate inside of an RV when closed up tight. It will help some if you keep a top vent opened just a tiny bit, open the bathroom vent when using the shower, be sure to always use the stove hood vent when cooking and other things of that nature. Link to comment Share on other sites More sharing options...
2gypsies Posted January 17, 2017 Report Share Posted January 17, 2017 You might want to check on the mattress where it hits the wall. With your heavy breathing that's a good place for moisture to gather. If it's a problem, move the mattress away from the wall a few inches during the day to let it dry out. We had the problem with a 5th wheel we had. Link to comment Share on other sites More sharing options...
wildmandmc Posted January 17, 2017 Report Share Posted January 17, 2017 I usually put a few containers of Damp Rid. All thru the RV. Link to comment Share on other sites More sharing options...
Chief 62 Posted January 17, 2017 Report Share Posted January 17, 2017 Damp Rid and leaving a vent cracker and a window cracked. Those will help alot, but you do need to use vent fans when cooking and bathing. Some folks will run a dehumidifier to get rid of the moisture. Link to comment Share on other sites More sharing options...
cpaulsen Posted January 17, 2017 Report Share Posted January 17, 2017 A good dehumidifier works also. Link to comment Share on other sites More sharing options...
dzwiss Posted January 17, 2017 Report Share Posted January 17, 2017 We had 7 solid weeks of rain while on the Oregon coast this fall and by the time I realized what was happening we had a mildew problem inside of our cabinets. Humidity was very high the whole time. Next year we will have a humidifier. Link to comment Share on other sites More sharing options...
Pat & Pete Posted January 17, 2017 Report Share Posted January 17, 2017 We had 7 solid weeks of rain while on the Oregon coast this fall and by the time I realized what was happening we had a mildew problem inside of our cabinets. Humidity was very high the whole time. Next year we will have a humidifier. Sounds like you need a Dehumidifier , instead of a humidifier . Humidifier will increase the moisture level . You could just run the AC . That will remove a lot of the humidity . Link to comment Share on other sites More sharing options...
dzwiss Posted January 17, 2017 Report Share Posted January 17, 2017 Sounds like you need a Dehumidifier , instead of a humidifier . Humidifier will increase the moisture level . You could just run the AC . That will remove a lot of the humidity . Yes you are right.........please excuse my brain f...t. Link to comment Share on other sites More sharing options...
Pat & Pete Posted January 17, 2017 Report Share Posted January 17, 2017 We all have that , from time to time . Link to comment Share on other sites More sharing options...
coachmac9 Posted January 17, 2017 Report Share Posted January 17, 2017 We use two of these small dehumidifiers...one in the front and one in the back bedroom along with using the vents and it took care of our problem. Got them from Amazon for around 40 bucks each. Gurin DHMD-210 Electric Compact Dehumidifier Link to comment Share on other sites More sharing options...
budeneighe Posted January 17, 2017 Report Share Posted January 17, 2017 My A/C Thermostat has a humidity sensor in it that (if enabled) will make it work as a dehumidifier. But, I deal with the closet humidity by putting all of my piecemeal clothes in plastic shoeboxes that keep them from touching the walls. This allows for some amount of air circulation around in there just from opening and closing the door. I also make sure that whenever anyone is showering that the main bedroom roof vent is open. It is not powered but the normal heat rising from a hot shower will take a lot of it out the vent. I also occasionally wipe down the bedroom/bathroom ceiling and walls right after a shower with an old towel, just to help the process. The mattress and pillows is a really important thing to not overlook. You can get some pretty bad mildew accumulating inside of them without noticing that it is growing back there. places where I see it has started, I wipe down with Peroxide solution to try to inhibit it from getting restarted too easily. Test it in inconspicuous places before using it all over, though. it does not tend to bleach out materials as bad as clorox but it can do some discoloration on some surfaces. Link to comment Share on other sites More sharing options...
LFDR3116 Posted January 17, 2017 Report Share Posted January 17, 2017 We use Damp Rid in any small enclosed area like the closets, storage under the bed, under the dinette. Areas that don't get opened up much. Now my closet is no problem, but DH doesn't open his as much, so his has to have a Damp Rid in it. We have to change them about every couple of months. Also wiping down the shower after use, hanging wet towels outside, all things that help. Link to comment Share on other sites More sharing options...
gjhunter01 Posted January 18, 2017 Report Share Posted January 18, 2017 I installed a fantastic fan in place of the shower sky light and have not had any humidity issues in last 2 years. This includes extended stays in Fl and N. Cal redwoods. It was pretty easy to install, basically a drop in installation with a wire to the shower light. We chose the base model, no remote or rain sensor or reverse needed. Typically we leave the fan run for 10 minutes after showering and also wipe down the shower walls, mostly to keep it clean. Greg Link to comment Share on other sites More sharing options...
Ron Posted January 19, 2017 Author Report Share Posted January 19, 2017 Thanks to everyone for the tips and suggestions. Some of them I have been using already like the Damp Rid in the closets but several days of very cold weather with near 100% humidity just overwhelmed my usual precautions. I really like the idea of putting a fantastic vent fan in the bathroom and keeping some clothes in plastic boxes inside the closet. Thanks again to everyone. ---ron Link to comment Share on other sites More sharing options...
Ray,IN Posted January 20, 2017 Report Share Posted January 20, 2017 My A/C Thermostat has a humidity sensor in it that (if enabled) will make it work as a dehumidifier. All air conditioners/chilled air are also a dehumidifier. Chilled air was a byproduct from the invention of the early dehumidifier. Link to comment Share on other sites More sharing options...
frater jason Posted January 23, 2017 Report Share Posted January 23, 2017 We use two of these small dehumidifiers...one in the front and one in the back bedroom along with using the vents and it took care of our problem. Got them from Amazon for around 40 bucks each. Gurin DHMD-210 Electric Compact Dehumidifier Some folks mod these to drain into the sink or similar. They drill a hole low in the dehumidifier's catch basin and friction fit or silicone in a bit of tubing. I suppose if one was hardcore and did not drink from the freshwater tank one could drain into there. Reminiscent of the stillsuits in Dune. Link to comment Share on other sites More sharing options...
Kirk W Posted January 23, 2017 Report Share Posted January 23, 2017 Some folks mod these to drain into the sink or similar. They drill a hole low in the dehumidifier's catch basin and friction fit or silicone in a bit of tubing. I suppose if one was hardcore and did not drink from the freshwater tank one could drain into there. Reminiscent of the stillsuits in Dune. The dehumidifiers that we use has a connection for a drain hose which can be used in place of the self-contained reservoir. We keep two of them in our home-base. If you were to locate a dehumidifier permanently in an RV, it wouldn't be very difficult run a drain hose from it down through the floor and out the bottom to just drip on the ground outside. There could be some problem with the drain freezing up and blocking with ice in very cold weather if doing that. Link to comment Share on other sites More sharing options...
Pat & Pete Posted January 23, 2017 Report Share Posted January 23, 2017 Some folks mod these to drain into the sink or similar. They drill a hole low in the dehumidifier's catch basin and friction fit or silicone in a bit of tubing. I suppose if one was hardcore and did not drink from the freshwater tank one could drain into there. Reminiscent of the stillsuits in Dune. The unit could be set in the sink or shower with no catch . Simply tilt the unit for decent drainage . And , Dune ... an excellent read . Link to comment Share on other sites More sharing options...
jblscooper Posted January 23, 2017 Report Share Posted January 23, 2017 This is a little late for some, but, when we ordered our current trailer (NuWa), we had the bedroom glass sliding doors replaced with wooden louvered doors, mainly for air circulation (and not having to look at old nekkid bodies). So far we have not had any evidence of moisture in the closet in 19 years. One could possibly find such doors at big box supply stores and since most are more narrow than the standard slider in RV's, join two together for each door. Require some work, but would solve moisture problem. Jim Link to comment Share on other sites More sharing options...
shooter51 Posted February 1, 2017 Report Share Posted February 1, 2017 I just acquired a "new to me" 26 foot Rockwood lite 5er. Currently based in SW Floriduh, My rig is parked with out cover in the shadow of my shop (40 X 60 Ft.) If I can ever clear enough floor space, I'll move it inside. (fat chance) I'm working on a 14 X 60 shed roof to keep the sun off mostly. Right now I'm having condensation problems. (Yes, even in winter, in the tropics, we have high humidity and 35 degree temp swings daily) I want to rum a dehumidifier full time, even when I get 'er under cover. Can you folks help me size and select the most efficient unit? I'll figure the inside volume of the box soon as I'm sure it would help to know the total volume to be processed. Thanks, Paul Link to comment Share on other sites More sharing options...
shooter51 Posted February 6, 2017 Report Share Posted February 6, 2017 Well, I was surprised, the total volume of my 26 foot 5er is only 1640 cubic feet. With the side slide out, it feels big enough to ball room dance. (OK, not really, I'm way too clumsy) Seems to me that a dehumidifier sized for around 2000 cuft, rated at 50 pints per day, should be just the ticket. Any suggested makes or models? Experiences? Thanks, Paul Link to comment Share on other sites More sharing options...
