Frank and Pat Posted December 31, 2016 Report Share Posted December 31, 2016 Is there any way to adjust oven temperature in an Attwood Wedgeood oven? Set it on 350, only heats to 200. Raise it to 450, it goes up to 265ish. Can't find anything in instruction book. It is in a 1886 Winnebago and probably original. Money Pit it is sure becoming. Frank and Patr Vance Link to comment Share on other sites More sharing options...
markandkim Posted December 31, 2016 Report Share Posted December 31, 2016 Get a pizza stone. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted December 31, 2016 Report Share Posted December 31, 2016 Pull the knob off the front. There should be a small screw hiding beside the shaft. That will allow some level of adjustment. 150* might be a stretch. Link to comment Share on other sites More sharing options...
Big Greg Posted December 31, 2016 Report Share Posted December 31, 2016 Here's a link to BryantRV's service manuals. Looking down the list I see 2004 and 2010 Atwood Range Service Manuals. Maybe it will be similar to your 1986, you might also try Googling Atwood Service manuals. Greg http://bryantrv.com//docs.html Link to comment Share on other sites More sharing options...
Yarome Posted December 31, 2016 Report Share Posted December 31, 2016 You might also check your burners to ensure they are clean. A partial blockage (spider web, etc) could be affecting the burner output. You might also check your LP pressure to ensure it is delivering adequate pressure throughout the rig. You would need a manometer for that though. Link to comment Share on other sites More sharing options...
LindaH Posted December 31, 2016 Report Share Posted December 31, 2016 . It is in a 1886 Winnebago and probably original. Now, that's one OLD Winnebago! Link to comment Share on other sites More sharing options...
mscans Posted January 5, 2017 Report Share Posted January 5, 2017 Probably on the 14th team of horses by now! Link to comment Share on other sites More sharing options...
WeBeFulltimers Posted January 5, 2017 Report Share Posted January 5, 2017 Now, that's one OLD Winnebago! Wooden wheels? Link to comment Share on other sites More sharing options...
Kirk W Posted January 5, 2017 Report Share Posted January 5, 2017 Here's a link to BryantRV's service manuals. Looking down the list I see 2004 and 2010 Atwood Range Service Manuals. Maybe it will be similar to your 1986, you might also try Googling Atwood Service manuals. Greg http://bryantrv.com//docs.html Both of those manuals seem to cover the ranges of the period yours was built, but neither lists it directly. My suspicion is that either the temperature bulb or maybe the control assembly. If so, you will probably need to upgrade it to the current model but it does look like that could be done. Link to comment Share on other sites More sharing options...
Frank and Pat Posted January 6, 2017 Author Report Share Posted January 6, 2017 OK, a typo - its a 1996 Winnebago! We tried turningn that screw about 1/2 and that shut the gas off. We will try only turning it a bit. May have to have a repairman come out - this money pit loves those repairmen. Posted before about water heater - had to replace the thermocouple and board. $200, so not too bad this time, but he was the 3rd to look at it and actually admitted there was a problem. Appreciate all the suggestions!! Link to comment Share on other sites More sharing options...
jbh Posted January 7, 2017 Report Share Posted January 7, 2017 You have a thermistor in there; make sure it's where it's supposed to be. There's no board. Next clean out the burner. Link to comment Share on other sites More sharing options...
