raylen Posted December 24, 2016 Report Share Posted December 24, 2016 I know you cant depend on the gage on the panel. But the gage on the tank worked till last fill up, now it don't move. any ideas how to fix it or tell how much is in the tank. 1990 Bounder 27D by Fleetwood Class A thank in advance Ray Link to comment Share on other sites More sharing options...
sandsys Posted December 25, 2016 Report Share Posted December 25, 2016 I'm not familiar with your rig so this may well not apply. If you can actually see the side of the tank, throw a cup of hot water on it. The condensation line that develops will show you where the fill is currently. Linda Sand Link to comment Share on other sites More sharing options...
Kirk W Posted December 25, 2016 Report Share Posted December 25, 2016 Most propane level indicators found in motorized RVs are of the float type, similar to those in a gasoline tank. The indication is usually just a mechanical gauge on the side of the tank, with a magnetic sensor that is attached to follow the needle. To check it you will need to get under the RV to where your tank is located and so that you can see it. If you locate the pressure regulator assembly and the point where the fill line enter the tank, you should be able to see it. If the mechanical gauge is still working the sensor is easily replaced or the problem could be in the wires between it and your display or it might be the display. Most of these displays are just a voltage sensor but they are not all the same and you will need to determine what type your Bounder has. Some of the display panels used when your RV was built have adjusting potentiometers located behind the display panel that might help. It suddenly stopped working completely, the problem is probably electrical. I helped a friend with a problem just like yours once where the sensor had come off of the face of the level gauge. The mechanical gauge can be replaced, but not likely at an RV shop but most larger LP distributors do repairs. If you take a look at this page from Propane 101, it has a pretty good explanation of how it works. Link to comment Share on other sites More sharing options...
Dutch_12078 Posted December 25, 2016 Report Share Posted December 25, 2016 Since it's the gauge on the tank that's no longer reading, the likelihood is that the external part is what has failed. Failures of the float and magnet that drives the external gauge are pretty rare. Fortunately, replacement gauges with the remote sensor are readily available, and quite easy to change. There are two different styles of gauges with remote sensors, and they are not interchangeable. There's the screw-on gauge that Kirk posted, and there's also the snap-on style shown below. Both are readily available on eBay, Amazon, etc, as well as in most RV dealers parts departments. Link to comment Share on other sites More sharing options...
