Snufy1 Posted December 3, 2016 Report Share Posted December 3, 2016 After fixing the shower I started checking out the rest of the bathroom. With the leak I couldn't turn water on. When I tested the toilet out it worked fine but i found a hole in my black water tank. it is close to the discharge fitting. Any ideas on how to fix. Plastic tank. I tried the like I used on the gas tank except the one for plastic it did not work. Tom & Michele 1983 Revcon King33 1989 Goldwing Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted December 3, 2016 Report Share Posted December 3, 2016 A JB Epoxy patch kit might work. It's the Kit with a piece of fiberglass cloth. Clean the area with Acetone, scuff it with 80grit sand paper, Clean it again with Acetone, and apply the patch. What I like to do is mix the epoxy, smear/brush some on the area, place the cloth on, and then saturate the cloth. Put several layers on all at once. Let it dry and cure. If you need a fast cure aim a hair dryer at it for an hour or so on high. Keep it about a foot away. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
jc2 Posted December 3, 2016 Report Share Posted December 3, 2016 If you "need" a good temp fix, eternabond tape will likely do the job but can be hard to remove later if a more permanent fix is desired/needed. 2010 Newmar Dutch Aire 4304-Spartan Chassis-Cummins ISL 425hp-2013 Chevrolet Equinox AWD Towed-SKP# 120487-FMCA #402879- Link to comment Share on other sites More sharing options...
Kirk W Posted December 3, 2016 Report Share Posted December 3, 2016 A great deal of the answer depends upon exactly what type of material was used in your tank. There is a welding process that can be used successfully on some tanks. If you use the wrong materials in a repair effort you may make the problems worse. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Snufy1 Posted December 3, 2016 Author Report Share Posted December 3, 2016 I don't know what it is made of and Revcon is out of business it is a 1983 tank I know that if I put the wrong stuff on it could make it worse I let the putty cure for just over an hour. Maybe I needed to let it cure longer although the instructions said that it cures in 1 hour I was thinking that if I reapply new putty let it cure longer. Then use silicone and screw a patch down over it and seal the patch. Or I could use an epoxy like mentioned above and seal it Tom & Michele 1983 Revcon King33 1989 Goldwing Link to comment Share on other sites More sharing options...
Pat & Pete Posted December 4, 2016 Report Share Posted December 4, 2016 How big is the hole ? And what shape is it ? Goes around , comes around . Link to comment Share on other sites More sharing options...
Retiredin1993 Posted December 4, 2016 Report Share Posted December 4, 2016 I had a leak in my tank where the flange and tank meet. I went to Home Depot and got a JB weld putty that you cut off a piece and knead it to mix the two parks together. It worked fine until I had the tank replaced under extended warranty. I dumped the tank gave it a good flushing and raised that side up before repair and let it set over night. RonUS Army retired2010 Tiffin Phaeton 40QTH2016 Ford F150 XLT Link to comment Share on other sites More sharing options...
Snufy1 Posted December 4, 2016 Author Report Share Posted December 4, 2016 I can put a finger in it and there is a 2"crack coming out from it Ween I tried last time I did put a fiberglass screen over the hole Tom & Michele 1983 Revcon King33 1989 Goldwing Link to comment Share on other sites More sharing options...
bigjim Posted December 4, 2016 Report Share Posted December 4, 2016 I had good luck with "Marine Tex" epoxy on a 1978 TT but it was somewhat difficult getting the tank dried outl. Well not difficult but it took quite a while. I propped the valve on the toilet open with a fan blowing down it for about 5 days. On the trailer I have now I had some damage caused by a tire carcass I couldn't avoid. I went with the plastic weld but I hired a guy that welded all kinds of plastic tanks for commercial business'. It worked really well and it cost me $80. about 3 yrs ago. I know "some" rv shops may know of someone that does it. You might find out about one at someplace that sells large tanks for commercial use. Link to comment Share on other sites More sharing options...
Ray,IN Posted December 4, 2016 Report Share Posted December 4, 2016 I think you'll regret using silicone on the tank. I would opt for plastic welding, most any auto body shop has a machine. You'd have to assure them you have the interior clean and dry. The type material the tank is made from should be molded into the tank somewhere. Another possibility is a new tank: http://www.watertanks.com/category/16/ http://www.plastic-mart.com/category/34/rv-holding-tanks 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Kirk W Posted December 4, 2016 Report Share Posted December 4, 2016 Another possibility is a new tank: http://www.watertanks.com/category/16/ http://www.plastic-mart.com/category/34/rv-holding-tanks I think that if you want a permanent repair, this is the best answer. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
