drzcharlie Posted November 26, 2016 Report Share Posted November 26, 2016 We bought a new to us 2005 Newmar Northern Star. The sink has what appears to be some kind of plastic sink material. The PO did not protect the bottom of the sink with a rubber protector. As such the sink has scores of micro cuts and the bottom of the sink is stained and somewhat brownish. I tried using Bar Keepers Friend cleanser and that made some difference but not nearly enough. Any suggestions for perhaps polishing the bottom of the sink or failing that, getting stains out? Any advice would be appreciated. Link to comment Share on other sites More sharing options...
mysticmd Posted November 26, 2016 Report Share Posted November 26, 2016 Have you considered putting the stopper in and soaking sink in a bleach/water solution to get the stains out? Over the years, my husband has changed out those acrylic (?) sinks for deeper , one-bowl, stainless steel sinks and added a shut-off into the plumbing and overall improved the plumbing under the sink. I donated the plastic sinks to thrift shops. Hope you can get some help on this forum. Regards. Link to comment Share on other sites More sharing options...
drzcharlie Posted November 26, 2016 Author Report Share Posted November 26, 2016 Bleach solution might work but I would be inclined not to do that just yet. Thanks for the suggestion. Link to comment Share on other sites More sharing options...
Pat & Pete Posted November 26, 2016 Report Share Posted November 26, 2016 I'm not sure it would work in your application , but , a MAROON 3M scrub pad does an excellent job of cleaning a stainless sink where lesser pads wouldn't touch it . Link to comment Share on other sites More sharing options...
mysticmd Posted November 26, 2016 Report Share Posted November 26, 2016 I looked on YouTube - they used a couple inches of hot water in the sink w/OxiClean and soak: For repairs, another guy used the edge of a palm sander (elec) with 220 grit paper.... I'd be using this as my last resort for repairs: Anyway, browsing YouTube is always interesting and may give you ideas such as this: Published on Apr 1, 2015 Repair Damaged Bathtub / Shower Tray Using Anglo Acrylic Bath Repair Kit. This video shows you how to repair a damaged bath using the Anglo Acrylic Bath Repair Kit. The damage shown is a chip but the kit will also successfully repair scratches, cracks, splits and holes on a variety of different bathroom surfaces including Plastic, Stone Resin, Fibreglass, Enamel, Ceramic and Porcelain. The kit is a QUICK-FIX solution to repairing a damaged Bath or Shower Tray in RAPID time, not only does it save you time and money, you will also avoid the hassle and mess of having to replace the bath and re-tile. The finished result is amazing because it produces a permanent, invisible finish. For more information about the Anglo Acrylic Bath Repair Kit or to purchase one visit www.bathtubrepair.co.uk If you have success, would you mind posting what you did? Thank you. Mary Link to comment Share on other sites More sharing options...
Randyretired Posted November 27, 2016 Report Share Posted November 27, 2016 We had the same bottom staining. Soaking it with denture cleaning solution made it look like new. Link to comment Share on other sites More sharing options...
rpsinc Posted November 28, 2016 Report Share Posted November 28, 2016 Denture cleaning solution sounds good but havent tried it. Did try and had some success with OxyClean. Link to comment Share on other sites More sharing options...
Randyretired Posted November 28, 2016 Report Share Posted November 28, 2016 We used Stain Away Denture Cleanser. It comes in a powder. It says it Whitens and Brightens Dentures. Worked like a charm for our sink. Link to comment Share on other sites More sharing options...
Newt Posted November 29, 2016 Report Share Posted November 29, 2016 In a 5th wheel with Corian sinks, DW filled with water and clorox about once a week for stains. Newt Link to comment Share on other sites More sharing options...
57becky Posted December 2, 2016 Report Share Posted December 2, 2016 Soft Scrub and a green scrub pad is what Dow Corning recommends for cleaning their Corian sinks. We've done this on all our sinks, and it works great. Link to comment Share on other sites More sharing options...
sandsys Posted December 2, 2016 Report Share Posted December 2, 2016 Soft Scrub and a green scrub pad is what Dow Corning recommends for cleaning their Corian sinks. We've done this on all our sinks, and it works great. Be sure to rinse really well. We've seen how Soft Scrub sets up around its container opening and don't want that happening in our pipes. Linda Sand Link to comment Share on other sites More sharing options...
Cypress07 Posted December 2, 2016 Report Share Posted December 2, 2016 I used OxiClean on ours and it worked like a champ.... Link to comment Share on other sites More sharing options...
drzcharlie Posted January 29, 2017 Author Report Share Posted January 29, 2017 Thanks everyone. Link to comment Share on other sites More sharing options...
SIBERNUT Posted January 30, 2017 Report Share Posted January 30, 2017 If anyone has replaced their corian sinks with SS, I'd love to hear the process, pros & cons. Link to comment Share on other sites More sharing options...
Clay L Posted January 30, 2017 Report Share Posted January 30, 2017 My Winnebago owners manual said to soak with a bleach solution. That worked but I found that using Clorox Clean-Up Cleaner With Bleach Spray often pretty well eliminated the need to soak. I also used SoftScrub with bleach from time to time. Link to comment Share on other sites More sharing options...
rambler62 Posted February 3, 2017 Report Share Posted February 3, 2017 Bleach may make plastic brittle. You may want to try hydrogen peroxide. Link to comment Share on other sites More sharing options...
