GlennWest Posted November 24, 2016 Report Share Posted November 24, 2016 My wipers only work on intermediate settings. No constant on. They did work but not now. I have low and high relays in fuse panel, also one fuse breaker (resets itself). Freightliner uses a multiple function switch. Basically lower function works but no upper. Upper also controls off so I have to cycle key to shut down wiper. Do y'all think the switch needs changing? Link to comment Share on other sites More sharing options...
Dollytrolley Posted November 25, 2016 Report Share Posted November 25, 2016 My wipers only work on intermediate settings. No constant on. They did work but not now. I have low and high relays in fuse panel, also one fuse breaker (resets itself). Freightliner uses a multiple function switch. Basically lower function works but no upper. Upper also controls off so I have to cycle key to shut down wiper. Do y'all think the switch needs changing? Glenn......we beat this horse to death (sorry Dolly) a few weeks ago in a thread here on the forum.... Your preoccupation with the Freightshaker wiper switch is indicative of a potentially unhealthy condition where you are unable to leave the wiper switch alone..... Glenn....forget the wipers on your Freightshaker.....the switch is a cruel joke (likely invented by the marketing department at Volvo...) IF you simply HAVE to HAVE operating wipers trade your Freightshaker in on a KWopper ......Ken worth don't have wiper switches.....the wipers just run all the time..... The BEST thing you could do is take early retirement and wait for perfect weather and drive non-stop to Death Valley and boondocking where it seldom rains.... Glenn .....stand back....do not touch that Freightshaker wiper switch..... Drive on.....(Do NOT operate your Freightshaker in the rain....) Link to comment Share on other sites More sharing options...
GlennWest Posted November 25, 2016 Author Report Share Posted November 25, 2016 I'm so sorry. I had forgotten about that. Lots going on. Link to comment Share on other sites More sharing options...
RandyA Posted November 25, 2016 Report Share Posted November 25, 2016 The wipers are most likely NOT directly wired to the stalk switch. Like the Volvo (which uses the LCM) there is a control module that handles the signals from the stalk switch and then controls the wipers. Unless you have a open circuit replacing the stalk switch may not fix anything. Dig a little deeper or follow the suggestion used on the DollyTrolly. Link to comment Share on other sites More sharing options...
Dollytrolley Posted November 25, 2016 Report Share Posted November 25, 2016 I'm so sorry. I had forgotten about that. Lots going on. Glenn, just kidding ? Rain ahead when you are herding a Freightshaker down the road is a dreaded weather condition.....maybe you you need the wipers or......maybe you can get by with out the wipers.... Just like looking in the mirror and seeing Big5er with the red and blue lights on and you realize that you are out of Dr Pepper....maybe you just drop the "hammer" down and outrun him......hard choices ....and Shaker wipers are a hard choice... Jeff has a bizzillion miles behind Shaker wipers and he contends that once the wiper switch is...."molested", your life can be more complicated by the wiper arms become unstable in certain wind conditions.... Come on over to Death Valley....not too many rattlesnakes and NO Black Friday crowds today......AND....NO RAIN today, good Shaker Day.... Drive on......(Drive on sunny days...) Link to comment Share on other sites More sharing options...
GlennWest Posted December 3, 2016 Author Report Share Posted December 3, 2016 Update, Switch was bad. Replaced and works now. Link to comment Share on other sites More sharing options...
Big5er Posted December 3, 2016 Report Share Posted December 3, 2016 YEA!!!! Especially with the weather you are looking at this weekend. Stay dry Glenn. Link to comment Share on other sites More sharing options...
GlennWest Posted December 3, 2016 Author Report Share Posted December 3, 2016 Went this morning to Beaumont for switch. Poured rain the whole way. New Smart does much better in rain than my 2013 did. Saw 2 pickups, one in ditch and other in guard rail. Link to comment Share on other sites More sharing options...
Nuke-E Posted December 4, 2016 Report Share Posted December 4, 2016 The wipers are most likely NOT directly wired to the stalk switch. Like the Volvo (which uses the LCM) there is a control module that handles the signals from the stalk switch and then controls the wipers. Unless you have a open circuit replacing the stalk switch may not fix anything. Dig a little deeper or follow the suggestion used on the DollyTrolly. They're definitely not wired into the stalk on those trucks. They have to reach all the way over to a switch on the dashboard. Now on the Volvos, what's weird is that all of the variable speed intermittent functionality is via a relay controlled by the LCM, yet all other functions (low, high, and the washer pump) are directly switched by the stalk. And even though power is directly switched by the stalk, they still flow power for the low speed through the normally closed contacts on the intermittent relay. Pretty sure that configuration was designed by the same guy who set up daytime running lights on the older Volvos. Link to comment Share on other sites More sharing options...
Star Dreamer Posted December 4, 2016 Report Share Posted December 4, 2016 I would like to know how long the arms were on the Freightliner engineer that located the cruise switches and the wiper switch on the dash. Either that or they thought that movement kept the blood flowing. And like what was previously stated, why two switches for cruise ( one of which you have to turn off and then back one every time you restart the truck even though the indicator light is on) and only one for all the wiper functions! Glenn, glad the new switch worked. I have a used spare one that I picked up some time ago when I was at a salvage yard getting my rear aluminum wheels, just in case mine starts acting up worse. Dave Link to comment Share on other sites More sharing options...
Dollytrolley Posted December 5, 2016 Report Share Posted December 5, 2016 I would like to know how long the arms were on the Freightliner engineer that located the cruise switches and the wiper switch on the dash. Either that or they thought that movement kept the blood flowing. And like what was previously stated, why two switches for cruise ( one of which you have to turn off and then back one every time you restart the truck even though the indicator light is on) and only one for all the wiper functions! Glenn, glad the new switch worked. I have a used spare one that I picked up some time ago when I was at a salvage yard getting my rear aluminum wheels, just in case mine starts acting up worse. Dave Star, as I recall when I talked to nephew Josh the Shaker engineer I think he mentioned that Two engineers did the switches on the Shaker and one was named rang and the other was a-tang and their momma stared in a movie with Clint Eastwood and her name was A-rang-a-tang and as you may recall she had long arms also...... So Star does it help to drive a Shaker if you can drag your knuckles when you walk... So now that Glenn has a NEW....BRAND NEW wiper SWITCH and it allegedly works I suppose he will seek out thunder storms with cloud bursts to drive through.... As for me I'll just enjoy the bright sunny Death Valley days and not touch the Shaker wiper switch... Drive on....(How much$$$ for a new Shaker wiper Switch?) Link to comment Share on other sites More sharing options...
GlennWest Posted December 5, 2016 Author Report Share Posted December 5, 2016 Drive on....(How much$$$ for a new Shaker wiper Switch?) $130.74 Link to comment Share on other sites More sharing options...
MrSeas Posted December 5, 2016 Report Share Posted December 5, 2016 Part number? Link to comment Share on other sites More sharing options...
GlennWest Posted December 5, 2016 Author Report Share Posted December 5, 2016 06-46159-002 had to go get receipt. $116.16 and with TX taxes and $5.00 freight, $130.74. Link to comment Share on other sites More sharing options...
MrSeas Posted December 5, 2016 Report Share Posted December 5, 2016 06-46159-002 had to go get receipt. $116.16 and with TX taxes and $5.00 freight, $130.74. Thanks! Link to comment Share on other sites More sharing options...
I'mdonewiththis forum Posted December 5, 2016 Report Share Posted December 5, 2016 So now that Glenn has a NEW....BRAND NEW wiper SWITCH and it allegedly works I suppose he will seek out thunder storms with cloud bursts to drive through.... Won't be much of a problem for a few more hours! I'm in Port O'Connor and it looks like the rain may end today! Link to comment Share on other sites More sharing options...
