Helipilot Posted November 23, 2016 Report Share Posted November 23, 2016 After we bought our fifth wheel we installed the Goodyear G114 Light Truck Tires (as recommended on this forum and others) to prevent the "China Bombs" from tearing up the wheel wells when they failed. The Goodyear G114's are great but the valve stems are the metal type held in tension with a nut at the base.This nut, if it is loose or backs off, allows for a slow leak to develop at the valve stem base. Ours had a slow leak dropping from 125 PSI to 65 PSI overnight. Being the idiot I am I removed the tire and took it in to a tire shop to be repaired. They did the soapy water trick and discovered the leak at the valve stem. A simple deep reach socket tightened the nut and the leak was cured. The tire guy said "no charge" but I gave him a $10 bill for the education. Back at our RV I immediately checked the other three wheels valve stems and all were loose but had not started leaking. Passing this on to you folks at "No Charge" Link to comment Share on other sites More sharing options...
rdickinson Posted November 23, 2016 Report Share Posted November 23, 2016 I had a similar situation earlier this year, loss of tire pressure. It turned out tp be the valve cap being to tight and pushing on the valve stem causing the leak. Link to comment Share on other sites More sharing options...
Truckman Posted November 23, 2016 Report Share Posted November 23, 2016 I have been using the metal 2 piece valve stems for many years and hundreds of thousand of miles on my trucks and trailers and have never heard of one leaking. Is it possible the original installer didn't tighten them properly? Link to comment Share on other sites More sharing options...
Helipilot Posted November 23, 2016 Author Report Share Posted November 23, 2016 I believe the original installer (Goodyear Truck shop) didn't properly tighten the nuts on the stems when the tires were installed and balanced. The new tires were installed last summer and have about 5,000 miles of travel on them. These are the 17.5 wheels and really tow well. No other problems. Next project is to install new disc brake pads and new Monroe shocks. The Mobile Suite only has about 25,000 miles on it since new. The previous owner documented about 20,000 miles and we have documented about 6,000 since we purchased it. Great unit and we are snug and warm in a cold rain/sleet mix that has moved in while we are in Illinois for the Thanksgiving holidays. Exactly why I moved to the South as soon as I could, DW was already a born and bred southern lady when we married 48 years ago. Link to comment Share on other sites More sharing options...
Jack Mayer Posted November 23, 2016 Report Share Posted November 23, 2016 This is actually a fairly common issue. I had to tighten a couple of mine, as well; at least on this set of tires. Just don't over-snug them. You can compress the rubber too much and cause other issues. It is a judgement thing..... Link to comment Share on other sites More sharing options...
travelinbob Posted November 23, 2016 Report Share Posted November 23, 2016 Many years ago I had similar problem and I put a drop of medium strength Loctite on the little nut and have no problem with them backing off since. Link to comment Share on other sites More sharing options...
D&J Posted November 23, 2016 Report Share Posted November 23, 2016 I'm having a simular problem now but ours is from the tire guy over tightening them tearing the rubber seal where it goes into the hole. Denny Link to comment Share on other sites More sharing options...
budeneighe Posted November 23, 2016 Report Share Posted November 23, 2016 old stems should be replaced. The rubber seal inside of the rim gets pinched very thin and some rims distort enough to cause leaks there when the stresses are just right. I have lost a number of tires to this problem over the years. But when I replaced all tires in 2013, I did all new metal valve stems like this, too. No more pressure differences between tires that were last topped off at the same time. Depending on where the weight bearing area was on a rim could cause it to go down overnight or not at all. Yes, tightening up the lock nut can help but if the rubber seal on the inside of the rim is already too flattened, it will not last and will start to pucker the gasket behind it. Link to comment Share on other sites More sharing options...
remoandiris Posted November 23, 2016 Report Share Posted November 23, 2016 Have had four G114s on my coach for going on 2 yrs. Zero problems with air loss. Link to comment Share on other sites More sharing options...
Helipilot Posted December 2, 2016 Author Report Share Posted December 2, 2016 Update...since my original post we have not had any air loss on any tire. Thanks for the comments folks, we are now back at our home base safe and sound. We are planning to purchase a tire pressure monitoring system before our next trip. Will keep you posted on our purchase. Link to comment Share on other sites More sharing options...
