Jeff.Sloan Posted September 19, 2016 Report Share Posted September 19, 2016 Today was demo day (I love demo day!) in the cab of my new 2004 630 and I was able to get both bunks and all the compartments except the fridge. I can't figure out what I am missing. I removed the two 12mm bolts on the floor behind the drivers seat, the two 13mm nuts on the inside back of the compartment. The two small Allen heads from the left inside of the fridge door jamb, and the one Torx at the bottom of the fridge door jamb under the rubber grommet. I am trying to get to the remaining 12mm bolts that are underneath the fridge into the cab floor but the fridge won't come out. Can anyone tell me how to get the fridge out!? I was pulling on it pretty hard and relieved it of it's door, but I can't figure our how to get the fridge assembly out of the cabinet. Am I just not pulling hard enough? Any wisdom or help would be greatly appreciated! Thanks Jeff P.S. Anyone need cheap 630 interior parts? This stuff won't last long before it goes to the trash bin. Link to comment Share on other sites More sharing options...
Refuzn-To-Grow-Up Posted September 19, 2016 Report Share Posted September 19, 2016 If it is like the fridge on my 2008, 780, the fridge is on tracks. It should (?) slide out forward on the tracks. Mine was stuck in place, big time!. I used a pry bar to "muscle" it out. The trick was finding some place solid in the cab that I could place the pry bar on, for better leverage. Link to comment Share on other sites More sharing options...
alan0043 Posted September 19, 2016 Report Share Posted September 19, 2016 Today was demo day (I love demo day!) in the cab of my new 2004 630 and I was able to get both bunks and all the compartments except the fridge. I can't figure out what I am missing. I removed the two 12mm bolts on the floor behind the drivers seat, the two 13mm nuts on the inside back of the compartment. The two small Allen heads from the left inside of the fridge door jamb, and the one Torx at the bottom of the fridge door jamb under the rubber grommet. I am trying to get to the remaining 12mm bolts that are underneath the fridge into the cab floor but the fridge won't come out. demo day web.jpg Can anyone tell me how to get the fridge out!? I was pulling on it pretty hard and relieved it of it's door, but I can't figure our how to get the fridge assembly out of the cabinet. Am I just not pulling hard enough? Any wisdom or help would be greatly appreciated! Thanks Jeff P.S. Anyone need cheap 630 interior parts? This stuff won't last long before it goes to the trash bin. Hi Jeff, I am sorry to say that I can not help you with your fridge. I thought I remember reading about someone removing there fridge over a year ago. May be do a search in the hdt section. Maybe the person that was removing their fridge was Refuzn-To-Grow-Up. I have a question for you. Are you planning to remove the back wall in the sleeper area ? If so, can you post how you did it. I think that the back wall might be held on using Velcro. I have a need to remove the rear wall in the sleeper in my truck, that is the reason for the question. Best of luck with removing your fridge, Al Link to comment Share on other sites More sharing options...
Jeff.Sloan Posted September 20, 2016 Author Report Share Posted September 20, 2016 Just ordered up this brand new 2016 Ford Transit van rear seat on eBay to put into the Volvo. (Click on the image for big picture) It's 62" wide and the cab interior is 72" wide. Should be a nice fit and provide safe seating for five total in the cab. Cab side windows are next. Hoping to find a pair of the 28" x 18" Freightliner Columbia windows with retainer rings for easy install. What tool is recommended for cutting the cab sheet metal once everything is marked out? Thanks for the feedback on the fridge, I bet it is on sliders that I just didn't pull hard enough on. I will try again tomorrow night. I'll also snap a few pics of the back wall interior panels as well once I get them off. Link to comment Share on other sites More sharing options...
forxlr8n Posted September 20, 2016 Report Share Posted September 20, 2016 alan The rear wall is held in place with dura-lock (super velcro). Remove the belts and just pull it out Link to comment Share on other sites More sharing options...
alan0043 Posted September 20, 2016 Report Share Posted September 20, 2016 alan The rear wall is held in place with dura-lock (super velcro). Remove the belts and just pull it out Hi Forxlr8n, Thank you. I thought that might be the case. This going to help. Hi Jeff, This is just an idea that I want to through out there. You are doing some nice work in your truck. Have you ever thought about adding some sound deadening material to the walls and floor of the truck ? I have used a material called Rattle Trap before that you can buy on E-Bay. At the time they seemed to have the best prices. I have no connections with them at all. This is just an idea. If you take out the seat belt bolts be very careful that the nuts do not brake loose from the truck. Don't ask me how I know this. It is a two person job. One person under the truck with heat on the nuts and the second person in the cab with a ratchet. Keep a wet rag handy. Keep up the good work and post some pictures, Al Link to comment Share on other sites More sharing options...
adept99 Posted September 22, 2016 Report Share Posted September 22, 2016 Jeff; The refrig is mounted on a slide track. Bottom & Top are affixed to the truck, middle piece (the slide) is mounted to the refrig. Once the bolts are out, the expectation would have been to just slide it out. Fat chance of that if your truck isn't brand new. It's rusted in place. There is no Joy and No Easy Way. Use a pry bar very carefully to push it side to side to break the "hold" - seriously, I broke the front cabinet on this step. Now use a heavy strap out the passenger door and in the luggage door. (Pad your paint) Wrap a strap around the base of the refrig and put a ratchet of some kind between the two straps and tighten it up. Wiggle the fridge. You may need to drive a mechanical hacksaw blade down in the slide area. PB Blaster helps. Keep wiggling and tightening. Cursing helps. BTW - The bolts for the fridge are all in the front. Don't remember if there are two or four, but the point is any other bolts are to hold the slide frame in place and are not directly connected to the refrig. If you don't understand what I'm trying to explain, send a pm with a phone # Good Luck Paul Link to comment Share on other sites More sharing options...
Jeff.Sloan Posted September 22, 2016 Author Report Share Posted September 22, 2016 Thanks Paul this is great. I am hoping to get back to this tonight. I will try your recommendation and probably mix in the BFH and/or swazall for extra fun. I will be sure to share some pics :-D Link to comment Share on other sites More sharing options...
Jeff.Sloan Posted September 22, 2016 Author Report Share Posted September 22, 2016 Hi Forxlr8n, Thank you. I thought that might be the case. This going to help. Hi Jeff, This is just an idea that I want to through out there. You are doing some nice work in your truck. Have you ever thought about adding some sound deadening material to the walls and floor of the truck ? I have used a material called Rattle Trap before that you can buy on E-Bay. At the time they seemed to have the best prices. I have no connections with them at all. This is just an idea. If you take out the seat belt bolts be very careful that the nuts do not brake loose from the truck. Don't ask me how I know this. It is a two person job. One person under the truck with heat on the nuts and the second person in the cab with a ratchet. Keep a wet rag handy. Keep up the good work and post some pictures, Al Thanks Al, I am planning to use "redneck Dynamat" all through the interior: http://www.homedepot.com/p/Fortifiber-6-in-x-75-ft-FortiFlash-25-Mil-05020/202094346 I've done it on several other cars over the years with great results. It works as well as real Dynamat and is a fraction of the cost. Link to comment Share on other sites More sharing options...
SuiteSuccess Posted September 23, 2016 Report Share Posted September 23, 2016 Jeff, I have looked at that product once before for a small project and pulled up the safety sheet. Think it is safe for long term use in a closed environment? Not criticizing your selection just asking for my own education. Contains asphalt. Any lingering smell? http://www.fortifiber.com/pdf/sds/sds_fortiflash.pdf Link to comment Share on other sites More sharing options...
forxlr8n Posted September 23, 2016 Report Share Posted September 23, 2016 I used Rattle Trap that I bought on Ebay and it's half of Dynamat. It's made in Ohio Link to comment Share on other sites More sharing options...
Bill B Posted September 23, 2016 Report Share Posted September 23, 2016 As was stated, older truck stuck in place. Mine had soda in / on the track. I took a water bottle and soaked it for a while, day or so. Tried the pry thing, not so good. Finally, I took some tie wire (steel wire used for rebar, like baling wire) and made some loops around the bolt holes / end of the track. Put a couple of 'handles' (large screw driver shaft). wiggle wiggle and finally out. Cleaned the bottom track and the fridge track little oil and things are good. Link to comment Share on other sites More sharing options...
alan0043 Posted September 23, 2016 Report Share Posted September 23, 2016 Jeff, I have looked at that product once before for a small project and pulled up the safety sheet. Think it is safe for long term use in a closed environment? Not criticizing your selection just asking for my own education. Contains asphalt. Any lingering smell? http://www.fortifiber.com/pdf/sds/sds_fortiflash.pdf That is the reason why I used Rattle Trap myself. The price on E-Bay seemed to be good. On some of the car sites guys talk about the asphalt product and they say there is a smell to it on hot days. I have not used any asphalt product in a car or truck. So I have no idea if there is a smell. I am just going off from what I read. Jeff, good luck with your build and please post some pictures. Al Link to comment Share on other sites More sharing options...
Jeff.Sloan Posted September 23, 2016 Author Report Share Posted September 23, 2016 Yeah I have read these types of comments over the years as well. I have been working on four wheelers for ~20 years and have used this in 2 or 3 of my cars already, never had any odor issues. I had done a little research years ago and found one article that seems to state asphalt needs to be around 300-400 degrees F to off gas. I personally have never had issues in the cars that I have done. Edit: Here one article that talks about it: http://assets.cmp.bh.mxmcloud.com/system/7ee1805bb02ce6000b88393adfdad986_npra-q-a-d3_1010_draper.pdf Link to comment Share on other sites More sharing options...
SuiteSuccess Posted September 23, 2016 Report Share Posted September 23, 2016 Thanks Al & Jeff. Link to comment Share on other sites More sharing options...
alan0043 Posted September 23, 2016 Report Share Posted September 23, 2016 Hi Jeff, I have a question or too for you. In the picture that you posted it looks like the storage cabinet behind the passenger seat has been removed. How hard of a job was it ? How many screws or bolts need to be removed ? Does the top section need to be removed first or can the whole cabinet come out together ? I have a need to remove mine for now. Any help would be appreciated, Al PS; Thank you for posting the article Link to comment Share on other sites More sharing options...
Jeff.Sloan Posted September 23, 2016 Author Report Share Posted September 23, 2016 yeah that came out pretty easy. Three bolts on the floor, two nuts on the back/sidewall about waist high, and a couple up top I think. I was able to get mine out as a unit. The bolts on the floor can be hard to get out. Someone here suggested heat, that's a great way to go. I go under the truck and scrape them down with a wire brush and spray some WD40 or thread penetrating oil on them. Unless they are rusted real bad often that is enough. I did break one bolt off on the fridge side, but that's OK I have no plans to put anything back in the hole. It's an easy way to plug the hole in the floor that's for sure hahah Tomorrow morning I'll finally get a change to get back out there. I've decided to take the fridge/cabinet out in pieces with my sawzall. Fun pics coming soon Link to comment Share on other sites More sharing options...
alan0043 Posted September 24, 2016 Report Share Posted September 24, 2016 yeah that came out pretty easy. Three bolts on the floor, two nuts on the back/sidewall about waist high, and a couple up top I think. I was able to get mine out as a unit. The bolts on the floor can be hard to get out. Someone here suggested heat, that's a great way to go. I go under the truck and scrape them down with a wire brush and spray some WD40 or thread penetrating oil on them. Unless they are rusted real bad often that is enough. I did break one bolt off on the fridge side, but that's OK I have no plans to put anything back in the hole. It's an easy way to plug the hole in the floor that's for sure hahah Tomorrow morning I'll finally get a change to get back out there. I've decided to take the fridge/cabinet out in pieces with my sawzall. Fun pics coming soon Hi Jeff, Thank you for the help. I have one cabinet removed from the truck. Al Link to comment Share on other sites More sharing options...
Jeff.Sloan Posted September 24, 2016 Author Report Share Posted September 24, 2016 Fridge is out. Interior is out. Ready for my FL Columbia windows to arrive. I ended up cutting the top off of the fridge cabinet and working the fridge side to side, front to back. After a couple minutes it broke free and came right out. EDIT: The shared album was a failure, so I hosted the pics on one of my own websites: http://nicoleandjeff.net/vnl/ Also realized that the headlights have failed and fogged internally, so I ordered a new set of headlights and fog lights from eBay. The left headlight chassis plug is burned up and missing pins. Going to call Vander Haags Monday to see if they will sell me a pigtail.. Any other ideas on where I might find one? Thanks Jeff Link to comment Share on other sites More sharing options...
HERO Maker Posted September 24, 2016 Report Share Posted September 24, 2016 No pics. Link to comment Share on other sites More sharing options...
Jeff.Sloan Posted September 24, 2016 Author Report Share Posted September 24, 2016 No pics. This site's image hosting abilities are pretty lame. Click on the Google shared album to see all of the pics :-) Link to comment Share on other sites More sharing options...
HERO Maker Posted September 24, 2016 Report Share Posted September 24, 2016 There isn't an album to click on? Have you set it to share properly? I'm not signing on. Link to comment Share on other sites More sharing options...
Jack Mayer Posted September 25, 2016 Report Share Posted September 25, 2016 I can get to the pics OK, but I'm a google user.....and I'm signed into my Google account. Link to comment Share on other sites More sharing options...
alan0043 Posted September 25, 2016 Report Share Posted September 25, 2016 Fridge is out. Interior is out. Ready for my FL Columbia windows to arrive. I ended up cutting the top off of the fridge cabinet and working the fridge side to side, front to back. After a couple minutes it broke free and came right out. Created a google shared album for this project, will update as I go along: https://goo.gl/photos/ybUmYJtxY7JgfiMs9 Also realized that the headlights have failed and fogged internally, so I ordered a new set of headlights and fog lights from eBay. The left headlight chassis plug is burned up and missing pins. Going to call Vander Haags Monday to see if they will sell me a pigtail.. Any other ideas on where I might find one? Thanks Jeff Hi Jeff, You might want to send Nuke-E a p/m. David owns Deep Space Lighting. He has done a load of work developing a replacement head light system for the Volvo trucks. He might just know where you can find the parts you need. Also, I am not able to see your pictures. Keep up the good work, Al Link to comment Share on other sites More sharing options...
Jeff.Sloan Posted September 25, 2016 Author Report Share Posted September 25, 2016 The shared album was a failure, so I hosted the pics on one of my own websites: http://nicoleandjeff.net/vnl/ Link to comment Share on other sites More sharing options...
