63belv Posted September 9, 2016 Report Share Posted September 9, 2016 Trying to use Xantrex Pro watt 2000 for Samsung rf18 . Using an extension cord temporarily for test just hooking to fridge and it throws the gfci. Called Xantrex they said try different cord. Can the gfci be bypassed on this inverter? Any ideas? Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted September 9, 2016 Report Share Posted September 9, 2016 You sure there is a GFCI in the Xantrex? Or is it just a flipped breaker? Link to comment Share on other sites More sharing options...
pjstough Posted September 9, 2016 Report Share Posted September 9, 2016 I have a Xantrex Pro Watt 2000 inverter, and the outlet on it is a GFCI outlet. Link to comment Share on other sites More sharing options...
hemsteadc Posted September 9, 2016 Report Share Posted September 9, 2016 Are you using a grounding cord? Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted September 9, 2016 Report Share Posted September 9, 2016 I have a Xantrex Pro Watt 2000 inverter, and the outlet on it is a GFCI outlet. You mean the Xantrex is plugged into a GFCI outlet? Is the Xandrex designed for power cord or did you add a power cord to it? I have seen Inverters flip GFCIs when the Grounding inside was not set properly. Ideally, the shore power side of the inverter should be isolated from the output side. The Hot and Neutral should have the exact same amount of current going out and coming back and that is what the GCFI monitors. If some of the current is not coming on the Hot/Neutral wires but the Ground will flip the GFCI. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted September 9, 2016 Report Share Posted September 9, 2016 The Xantrex uses an onboard GFCI receptacle to provide protection downstream, whether hard wired or corded. There's not really enough info in t original post to guess to the cause. Link to comment Share on other sites More sharing options...
hemsteadc Posted September 9, 2016 Report Share Posted September 9, 2016 Just google up that inverter and you can see the outlets. Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted September 9, 2016 Report Share Posted September 9, 2016 I see the GFCI receptacle on the Xandrex but still not clear which is flipping, Xandrex or wall? Link to comment Share on other sites More sharing options...
hemsteadc Posted September 9, 2016 Report Share Posted September 9, 2016 "Using an extension cord temporarily for test just hooking to fridge and it throws the gfci." This indicates to me it's the outlet on the inverter. Link to comment Share on other sites More sharing options...
63belv Posted September 9, 2016 Author Report Share Posted September 9, 2016 It is the Gfci on the inverter that is tripping. The gfci is built into the inverter. The cord is a grounded cord but Xantrex person suggested using heavier cord. My other part of the question is can the gfci be bypassed. Some online suggests not using gfci with fridge say motor starting can trip gfci. Link to comment Share on other sites More sharing options...
Jimalberta Posted September 9, 2016 Report Share Posted September 9, 2016 A few issues come to mind....I am pretty sure that the gfci could be taken out and a regular non gfci outlet installed in its place. BUT..... that gfci outlet is there for a reason...to protect things. I'm pretty sure you would void any warranty on the inverter by modifying it in any way. I would heed the tech's advice and try a heavier grounded extension cord that is a short as possible to avoid extra resistance first. Link to comment Share on other sites More sharing options...
jcussen Posted September 10, 2016 Report Share Posted September 10, 2016 Had same problem with xantrex prowatt 800 on my samsung fridge. Called xantrex and they told me some of the heating circuits on newer fridges, will cause a very low current to flow between hot and ground and trip the gfci. Went to home depot and bought 99 cent regular receptacle and replaced gfci. It is still grounded to case and bus so works just like any other receptacle in coach. Link to comment Share on other sites More sharing options...
