Ronbo Posted August 8, 2016 Report Share Posted August 8, 2016 We are in Phoenix I devoting chemotherapy. We have been having very warm water coming from the cold faucet. Almost as hot as the hot water. For a while I thought it was because it was so warm here and the pipes were shallow. I turned off the water heater and it was much improved. After a couple days it got on the tepid side. We had to turn on water heater for our shower and turn it off for cold water laundry. I ordered a check valve from Amazon. Less than $11.00. I installed it on the cold water side tonight. Removed the nipple that was in there and installed the check valve. It is a good thing I have a battery powered impact wrench because I couldn't remove the nipple with a socket and ratchet. I just took my shower and it was really nice to be able to adjust the temperature again. Link to comment Share on other sites More sharing options...
VallAndMo Posted August 8, 2016 Report Share Posted August 8, 2016 Howdy Ronbo, Congrats on fixing the issue yourself! Me, as a complete novice in RV inner workings, I'm reading your post and trying to learn. What I can't understand is how you could install a check valve (which, as I understand it, has two ends) in the place of a nipple (which I understand covers a single end). Can you please explain? I'm sorry if this is a stupid question (as it almost certainly it is). Thanks in advance, -- Vall. Link to comment Share on other sites More sharing options...
Ronbo Posted August 8, 2016 Author Report Share Posted August 8, 2016 A nipple is threaded on both ends. The check valve has an insert inside that is the check valve. Unscrew the nipple and screw in the check valve, which is essentially a nipple. Here is a link to the check valve. https://www.amazon.com/gp/product/B00HJ6P184/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 Link to comment Share on other sites More sharing options...
lappir Posted August 9, 2016 Report Share Posted August 9, 2016 While in Florida in late spring and early summer when I had a long hose run from the water source and the trailer I could take a complete shower without turning on the hot water. The water is heated by being exposed to the sun and lying on the ground. My parents noticed it in my Sticks and Bricks many years ago when they visited in the winter and were used to having very cold water in the Midwest and the water in Florida never got cold coming out of the faucets. (according to Mother.) Rod Link to comment Share on other sites More sharing options...
VallAndMo Posted August 12, 2016 Report Share Posted August 12, 2016 Hello Ronbo, A nipple is threaded on both ends. The check valve has an insert inside that is the check valve. Unscrew the nipple and screw in the check valve, which is essentially a nipple.Thanks for the explanation, I understand now. My confusion derived from a misunderstanding of what a "nipple" is... I once heard a pipe fitting similar to the one attached being (wrongly) called a nipple, and the mistake stuck... Thanks for setting me straight. Cheers, -- Vall. Link to comment Share on other sites More sharing options...
Kirk W Posted August 12, 2016 Report Share Posted August 12, 2016 A nipple is threaded on both ends. The check valve has an insert inside that is the check valve. On the RV water heaters that I've seen, the nipple found on water heater lines is usually a cheap, pex material check valve but those do fail and needing replacement is pretty common. If Rombo didn't always have the hot water problem, it likely was more than just a nipple on his also but in looking at them it is difficult to see any indication that they ever were check valves. They seem to get some mineral deposits into them and then lock either in the open or the closed position. I have seem both situations. Link to comment Share on other sites More sharing options...
Pat & Pete Posted August 12, 2016 Report Share Posted August 12, 2016 We've had one of those plastic check valves crack . Nasty leak . I replaced it with a brass valve of the same configuration and have had no problems in the 3 years since . Link to comment Share on other sites More sharing options...
Ronbo Posted August 12, 2016 Author Report Share Posted August 12, 2016 Kirk, I just had a plain brass nipple installed. I have never stayed in a location this hot until this cancer issue. In my research I am actually finding that most manufacturers don't install check valves when building the water heater. If one is installed, it is usually the plastic one. Several dealers I went to in Phoenix had no idea what I was talking about and couldn't find it in their catalog or computer. When they pulled up the water heater parts breakdown, ther was no check valve found on the parts list or diagram. Link to comment Share on other sites More sharing options...
Pat & Pete Posted August 12, 2016 Report Share Posted August 12, 2016 Kirk, I just had a plain brass nipple installed. I have never stayed in a location this hot until this cancer issue. In my research I am actually finding that most manufacturers don't install check valves when building the water heater. If one is installed, it is usually the plastic one. Several dealers I went to in Phoenix had no idea what I was talking about and couldn't find it in their catalog or computer. When they pulled up the water heater parts breakdown, ther was no check valve found on the parts list or diagram. That check valve might be listed along with the By Pass plumbing . Link to comment Share on other sites More sharing options...
