Hood limiting straps
Stan Wright
On a Generation 1 Volvo, when the hood is fully opened are there straps that stop the hood from tilting or is that done by the hinges themselves? I can't find anything online about it. I'm looking at a truck online and the hood tilt is limited by chains on each side. He said it is because the factory straps broke but I'm not so sure.
There should be big gas springs attached at the frame and on pivot balls inside the front of the hood. They will tear out if the pistons loose their resistance & the hood drops on opening (careless driver). Look real careful around the hinge box & hood pivot ball, if that area is broken it's hard to fix correctly.
...Look real careful around the hinge box & hood pivot ball, if that area is broken it's hard to fix correctly.
Thanks for the replies. That was my concern. In one of the pictures there is a ~4-5" crack in the hood in the area of the passenger-side hood hinge. My suspicion was the chains were bearing the weight of the hood and protecting a cracked mount.
That is very, very difficult to fix correctly. It can be done, but it is a pain. IF you pursue that truck have it repaired - PROPERLY - first, and subject to your approval.
FWIW- If you do buy this truck (or any) with structural weakness such as splits, broken panels, etc. I have a bumper made from 4 others, and a hood with a couple of stress cracks in the hinge box area. I drilled several holes in the inner structure of both, shot it full of expanding foam (after whatever repairs could be done). Made the hood a lot stiffer and the bumper, too. Doesn't tend to "work" as much going down the road.
Speaking of hood struts/shocks.... Opening the hood this morning I heard a seal pop and one side of the hood decided to be floppy.... Rod has extended out of the tube for some odd reason....
Best place to order new struts? Or do the auto stores carry the correct length and lb rating just for another application?
