RV_ Posted July 10, 2016 Report Share Posted July 10, 2016 Members of the Windows Insider Program can now install build 14383. With final public release only weeks away, the most interesting feature is one you can't see at all. This build is still being worked on so unless you are a developer you might want to wait for the last few tweaks and get it after the 2nd of August, just a few weeks away. This article tells the insiders what this build has. Excerpt: "The relentless march to the August 2 public release of the Windows 10 Anniversary Update continued today with the release of build 14383 to the Windows Insider Program Fast Ring. The new build is available for PCs and for mobile devices. The most noteworthy feature of the new release is something you can't see at all: In earlier preview releases, the build number appears in the lower right corner of the display as a persistent watermark. In this build, it's gone. The other big change is also invisible, affecting the way Cortana responds to speech input. That doesn't mean this is the final version that will be released early next month. Instead, following the same pattern as previous releases, we can probably expect another build incorporating fixes from the current round of testing. At some point, a build will be released to anyone running the Current Branch of Windows 10 (build 1511) who has opted into the new Release Preview ring in the Windows Insider Program. After that, expect incremental updates and bug fixes before the public launch. The release notes for the new build are filled with many small bug fixes and a few interesting changes. If you've seen erratic movement from a Bluetooth mouse in an earlier preview, there's a fix in this build. You'll also find a fix for a memory leak with Microsoft Edge that could cause pages to become unresponsive when the LastPass extension is enabled. Speaking of extensions, this build now makes it possible to browse extensions directly from the their own home in the Store." Screen shots of the extensions page and more info in the rest of the article here: http://www.zdnet.com/article/microsoft-pushes-near-final-build-of-windows-10-anniversary-update/?ftag=TRE17cfd61&bhid=19724681974700635514865380622813 Link to comment Share on other sites More sharing options...
