Asross72 Posted May 25, 2016 Report Share Posted May 25, 2016 Awesome job Randy. What is the little switch on the gearshift for? 2007 Volvo 880 2014 Palomino Sabre 36qbok Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted May 25, 2016 Report Share Posted May 25, 2016 I use/have a suicide knob on the wheel as well. For the most part the only time I use it is when we're backing into a tight spot and I need to turn the wheel from far right to left or vice-versa. I installed mine on the wheel at about 10 o'clock. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
Nuke-E Posted May 25, 2016 Report Share Posted May 25, 2016 Awesome job Randy. What is the little switch on the gearshift for? The clutch! 45' 2004 Showhauler -- VNL300, ISX, FreedomLine -- RVnerds.com -- where I've started to write about what I'm up to Headlight and Fog Light Upgrades http://deepspacelighting.com Link to comment Share on other sites More sharing options...
RandyA Posted May 25, 2016 Author Report Share Posted May 25, 2016 Awesome job Randy. What is the little switch on the gearshift for? Oh. That's for the NOX system when I want to blow a Pete off the road . OK, I'm lying. Like David answered, it controls a relay for a pneumatic cylinder that pulls the clutch in. That was a project from several years back - it may still be posted on here somewhere. Back to the heat shrink wiring tool. I mentioned earlier that I had tried it after seeing Jeff's post just using a fine tip permanent marker on something other than black heat shrink. Well, it works great and I won't need to buy a special tool and expensive heat shrink next time. Just thought I would show you. Of course, the new tool would be more fun and add to the toy box. Ultra Fine Permanent Ink Felt Tip Marker That is a #12 wire in the background. The foreground is a small section of yellow heat shrink tubing I have used the marker to write on. On the wire and all shrunk up real tight like-with a heat gun. No, it does NOT rub off. Thanks, Jeff. Why didn't you give me the idea earlier? Randy, Nancy and Oscar "The Great White" - 2004 Volvo VNL670, D12, 10-speed, converted to single axle pulling a Keystone Cambridge 5th wheel, 40', 4 slides and about 19,000# with empty tanks. ARS - WB4BZX, Electrical Engineer, Master Electrician, D.Ed., Professor Emeritus - Happily Retired! Link to comment Share on other sites More sharing options...
Asross72 Posted May 26, 2016 Report Share Posted May 26, 2016 Interesting, thanks. The NOX is a cooler story though. Lol 2007 Volvo 880 2014 Palomino Sabre 36qbok Link to comment Share on other sites More sharing options...
