Magnum 8 bag Chassis handling/ride issue, what shocks are you using
Looking for others with the Magnum 8 bag system such as on my 96 Beaver Patriot. Just completed serious trip after having chassis set up done along with new Koni FDS shocks. The ride is terrible, bone jarring over strips, bumps and pot holes. Clearly these shocks are not correct for this chassis. Since I live in California bad roads are unavoidable.
Wonder what others are using on their motorhomes with this chassis.
96 BEAVER Patriot 37' total running weight 27,500 pounds. All alignment and ride heights set to factory specifications. Air pressure running 110psi.
Bob McCormack
I'm removing this post because you have made this same post on the Beaver Ambassador Forum and have further clarified the situation. The pressure you noted above is your coach's internal air pressure, not the tire pressures.
Sandie & Joel
WiFiRanger Ambassador
