GlennWest Posted April 8, 2016 Report Share Posted April 8, 2016 Well transmission shift motor problem. It came back home this morning with 1, 3, 5 gears. No gear this evening. Know of anyone in Gonzales area that knows how to work on these? Link to comment Share on other sites More sharing options...
GlennWest Posted April 8, 2016 Author Report Share Posted April 8, 2016 I drove Freightliner to work. Link to comment Share on other sites More sharing options...
Buscrusher Posted April 9, 2016 Report Share Posted April 9, 2016 I did a quick search on the www.smartcarofsmerica.com site...found this thread on shifter motor problems... http://www.smartcarofamerica.com/forums/#/forumsite/21028/topics/107217?page=1 Link to comment Share on other sites More sharing options...
billr Posted April 9, 2016 Report Share Posted April 9, 2016 Call MB ask about Tranny software update. Might be the fix? Or clutch issue? You likely will not find anyone but MB to work on anything other than basic stuff. They need Star scanner system. Link to comment Share on other sites More sharing options...
Bill and Judy LeMosy Posted April 9, 2016 Report Share Posted April 9, 2016 There's a Smart Car Center over in Metarie: smart center new orleans 3727 Veterans Memorial Blvd Metairie, LA, 70002 (504) 456-3727 Link to comment Share on other sites More sharing options...
GlennWest Posted April 9, 2016 Author Report Share Posted April 9, 2016 Well after lots of research I have decided to take it to Smart center in New Orleans. Disassembling the motor and cleaning doesn't seem to be a big job but a dirty one. Here at the rv resort that might not be kosher. Link to comment Share on other sites More sharing options...
GlennWest Posted April 9, 2016 Author Report Share Posted April 9, 2016 I messed with various starting procedures, in gear, etc and it went back to normal. Will drive it and see what happens. Link to comment Share on other sites More sharing options...
stolpsaddles Posted April 10, 2016 Report Share Posted April 10, 2016 I regularly spray lithium lubricant into the clutch actuator motor. Slide the boot of the shift pin and pray it into the area behind the boot as far a you can. Might help it from coming back. You can adjust the clutch motor or remove the clutch motor but you should then have it hooked up to a star machine to teach it the new engagement point. Link to comment Share on other sites More sharing options...
GlennWest Posted April 10, 2016 Author Report Share Posted April 10, 2016 Clutch not problem. It working fine. Shifter motor problem. Thanks for tip though. It may be dirty connectors on motor though. Off after nite till monday night. Have some time. Wanted to do some things to truck. Link to comment Share on other sites More sharing options...
