aunut Posted April 6, 2016 Report Share Posted April 6, 2016 Does anyone know a way to remove these clamps from a plumbing tube without hurting the tube? And, can I replace it with a screw type clamping ring, or do I need to buy an (expensive) Pex crimping tool? Link to comment Share on other sites More sharing options...
SCClockDr Posted April 6, 2016 Report Share Posted April 6, 2016 No! There is usually enough slack to redo. There are alternatives to the expensive tool but the tool does a reliable job. If you get the tool set there is a removal tool to use once the line is cut. Cut the line just grazing the fitting when you do.. Link to comment Share on other sites More sharing options...
tinstartrvlr Posted April 6, 2016 Report Share Posted April 6, 2016 In order to save a t fitting, I used a pair of channelocks, visegrips, and a whole lot of elbow grease, twisting and turning the tab till it broke. That was on the pinch clamp type, not the collar type. And I highly recommend the tool. It was money well spent as I have used it more than a few times in the past. Link to comment Share on other sites More sharing options...
aunut Posted April 6, 2016 Author Report Share Posted April 6, 2016 Thanks. Why is there a such a huge difference in price on this crimping tool? From the $20's to over $100. Link to comment Share on other sites More sharing options...
Ronbo Posted April 6, 2016 Report Share Posted April 6, 2016 The clamps with the tab is the way to go. You can get those and the tool for install at lowes or Home Depot. That type uses one tool for all sizes. If you go with the ring it is size specific. Link to comment Share on other sites More sharing options...
tinstartrvlr Posted April 6, 2016 Report Share Posted April 6, 2016 Not exactly sure why such a price difference. As it usually is with tools, you get what you pay for. Also the crimping tool has to be "calibrated" so to speak so as not to pinch too tight or too loose. It's not a difficult process and mine came with the feeler gauge to check it. I considered it an investment because if something pex goes bad at the wrong time, theres really no way to fix it without the tool, and it is nice to have it when you need it. Link to comment Share on other sites More sharing options...
tinstartrvlr Posted April 6, 2016 Report Share Posted April 6, 2016 Also might want to invest in the correct cutting tool for pex, especially if you are using Sharkbites. A regular pipe cutter doesn't cut square and will cause problems if not square. Link to comment Share on other sites More sharing options...
Truckman Posted April 7, 2016 Report Share Posted April 7, 2016 No a regular hose clamp won't work. we always used a hacksaw and carefully cut on a diagonal across the crimp ring. If you have the newer kind of crimp with the "bump" on it (can't remember the proper name) use diagonal pliers on it and cut,wiggle it until it breaks. Link to comment Share on other sites More sharing options...
mocroc Posted April 7, 2016 Report Share Posted April 7, 2016 I use the expanding Pex rings & the Milwaukee expanding ring tool. Easiest & best to use but pricey @ around $400. I had to re-plumb the our mortar & brick home so could justify the cost. BUT in most plumbing supply businesses (not Home Depot, Lowes & etc) will rent the Milwaukee tool. Also agree use a Pex pipe cutting tool. They are cheap, easier to use and insure a square cut. rocmoc n AZ/Fld/Baja Link to comment Share on other sites More sharing options...
