jdhm Posted March 28, 2016 Report Share Posted March 28, 2016 I have a 2004 National Sea Breeze V10. One of my rear tires is loosing air. Talked to local Goodyear man (he didn't see rig). He said he could fix it but I would need to remove hub cap. It has a long cylinder in the middle which I do not believe was a hub cap. If it is, how do I remove it? Thanks in advance for your advice. J.D. Link to comment Share on other sites More sharing options...
AFchap Posted March 28, 2016 Report Share Posted March 28, 2016 Some rear axle "cans" are held on by tabs under some of the lug nuts. On my diesel, they are held by spring tensioners mounted on the hub, and the cap\"can" pulls off. Link to comment Share on other sites More sharing options...
jdhm Posted March 28, 2016 Author Report Share Posted March 28, 2016 Problem solved. Thank you. Link to comment Share on other sites More sharing options...
