lenp Posted January 29, 2016 Report Share Posted January 29, 2016 Not sure that is the correct name for the flap on the left door but..... Arrived here at Crystal Beach, TX this afternoon and discovered the flap no longer "flaps" into the correct position to guide it into it's receiver channel when closed. The spring and half of the little plastic piece it connects to was laying on the bottom of the frig. very easy to manually hold the flap in position and get the door closed but need to get it fixed! Have ordered a new part but not sure how to replace it. Anybody ever replaced one of these? I am sure I can figure it out when the part arrives but any guidance appreciated. Thanks, Lenp USN Retired 2002 Winnebago Ultimate Freedom 2012 F150 4x4 2018 Lincoln MKX 2019 HD Ultra Limited Link to comment Share on other sites More sharing options...
Ed ke6bnl Posted January 29, 2016 Report Share Posted January 29, 2016 when my boy had to return a bad phone I took the back off and there is from memory just one screw that attaches it and it takes less then 5 min. to install. I kept the door for my phone in the future. 2000 National RV Sea Breeze 5th wheel 30ft. So.California 1950 F1 street rod 1949 F1 stock V8 flathead 1948 F6 350 chevy/rest stock, no dump bed shortened frame. 1953 chevy 3100 AD for 85 S10 frame 1968 Baha Bug with 2.2 ecotec motor 170 hp, king coil-overs,etc 1970 Baha Bug wihg 2332cc, King coil overs and everything else there is. 1998.5 Dodge 2500 4x4 Cummins, turbo, trans, injectors, lockers, bigger turbo,edge EZ upgrades for towing 35" BFG's, air dog lift pump etc. Link to comment Share on other sites More sharing options...
chirakawa Posted January 29, 2016 Report Share Posted January 29, 2016 when my boy had to return a bad phone I took the back off and there is from memory just one screw that attaches it and it takes less then 5 min. to install. I kept the door for my phone in the future. How did you know he was talking about a phone? I thought this was about a television. Everybody wanna hear the truth, but everybody tell a lie. Everybody wanna go to Heaven, but nobody want to die. Albert King Link to comment Share on other sites More sharing options...
Fulltimer51 Posted January 29, 2016 Report Share Posted January 29, 2016 If you READ the post you can see that he is talking about his fridge. George2011 F350 6.7PSD CC 4X4 DRW Lariate2015 Mobile Suites 41 RSSB4 5th Wheel Link to comment Share on other sites More sharing options...
docj Posted January 29, 2016 Report Share Posted January 29, 2016 How did you know he was talking about a phone? I thought this was about a television. You're both way off base. A Samsung RF197 is a residential refrigerator that was very popular for RV retrofits. We own one, but I don't know the answer to the OP's question. Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
tc tom Posted January 29, 2016 Report Share Posted January 29, 2016 On our Samsung Refrigerator the left door needed to be lifted so the tab on the top of the door will fit into the slot. There were 2 clips that were included when we purchased the refrigerator. I installed both clips on the left door, this lifted the door enough to close the flap. Also there is an adjustment with an allen wrench that lifts the door slightly. Tom Link to comment Share on other sites More sharing options...
chirakawa Posted January 29, 2016 Report Share Posted January 29, 2016 If you READ the post you can see that he is talking about his fridge. Of course, but only if you know what an RF197 is, which I didn't. Everybody wanna hear the truth, but everybody tell a lie. Everybody wanna go to Heaven, but nobody want to die. Albert King Link to comment Share on other sites More sharing options...
Fulltimer51 Posted January 29, 2016 Report Share Posted January 29, 2016 Not sure that is the correct name for the flap on the left door but..... Arrived here at Crystal Beach, TX this afternoon and discovered the flap no longer "flaps" into the correct position to guide it into it's receiver channel when closed. The spring and half of the little plastic piece it connects to was laying on the bottom of the frig. very easy to manually hold the flap in position and get the door closed but need to get it fixed! Have ordered a new part but not sure how to replace it. Anybody ever replaced one of these? I am sure I can figure it out when the part arrives but any guidance appreciated. Thanks, Lenp A frig is a refrigerator. George2011 F350 6.7PSD CC 4X4 DRW Lariate2015 Mobile Suites 41 RSSB4 5th Wheel Link to comment Share on other sites More sharing options...
lenp Posted January 30, 2016 Author Report Share Posted January 30, 2016 Sorry to cause any confusion. YES, it is a residential refrigerator. Parts should be here early next week. Will post how hard/easy it is to install. Lenp USN Retired 2002 Winnebago Ultimate Freedom 2012 F150 4x4 2018 Lincoln MKX 2019 HD Ultra Limited Link to comment Share on other sites More sharing options...
lenp Posted February 1, 2016 Author Report Share Posted February 1, 2016 Parts arrived today - pretty simple replacement process. If interested I posted a short description with photos on my web page at: http://rvroamin.com/SamsungRF197/SamsungRF197HingeReplacement.html I now believe the problem was probably a soda can that fell from a shelf above and hit the protruding portion of the hinge (see first photo). I will have to get some sort of a fence for each of the shelves to prevent it from happening again. Lenp USN Retired 2002 Winnebago Ultimate Freedom 2012 F150 4x4 2018 Lincoln MKX 2019 HD Ultra Limited Link to comment Share on other sites More sharing options...
Fulltimer51 Posted February 2, 2016 Report Share Posted February 2, 2016 I heard that spring loaded curtain rods work. George2011 F350 6.7PSD CC 4X4 DRW Lariate2015 Mobile Suites 41 RSSB4 5th Wheel Link to comment Share on other sites More sharing options...
missourijan Posted February 2, 2016 Report Share Posted February 2, 2016 X2 on what Fulltimer51 said. I have the Samsung rf18 and use the spring loaded curtain rod to keep things in place. Jan & Thomas 2012 Drv Mobile Suite 5'r 2012 Ford F350 Super Duty Link to comment Share on other sites More sharing options...
