Beating up dually rear suspension
jerryneal
Back in Feburary, I posted needing help to smooth out the ride when pulling a 5th wheel. Thanks for the suggestions. Air ride hitch has made the last year of pulls much better. But, rescent travel on I-10 West toward Texas, I beat the dickens out of the rear end of the F350. No overload, well within pin and overall weight, but those I-10 launch ramps going into and off the bridges were just plain wicked. Took the F350 to the dealer this morning to check out the drive train. But, I need to do something to reduce the shock other than driving 10 miles an hour. Need to find a solution before we hit the road toward Livingston next week. Greatly appreciate any suggestions.
Maybe try adding air bags to your rear suspension. I know what you mean though.. it's a known problem with their approach slabs settling over time. The last I heard TX had something like 52,000 bridges and a good number of them all have the same problem. There had been 'some' talk of trying to use foam blocks under the approaches to help prevent/correct that, but I don't know what ever became of that idea. What kind of suspension do you have on your 5er?
To tell you the truth I have tried most everything and nothing on this earth that I know of will fix I-10 or some of our other major highways. I have air bags and it doesn't help one bit. I have had air ride hitch and that hasn't helped. But I will say the hitch was a junk one in the first place. Prototype is what it was and it failed.
The best fix I have found is to use the smaller hwys. in the area that there is known problems. If someone comes up or has come up with a fix please let us all know.
Thanks
Dave
If you are running more than the required air pressure in the tires dropping it to a lower level but still above the minimum for your tires and weight combination may help.
Air bags might give a minor improvement by bringing you back closer to your unloaded spring height but I'd not expect anything you'd be happy with for the cost.
Have your shocks checked to make sure they are still good, maybe upgrade to a more capable set of shocks.
Yarome, the 5er has a standard 2-axial, 6000lb. Shock doesn't seem to be in the 5er as much as in the rear of the truck. Going to try airbags. Some improvement would be better than nothing.
GeorgiaHybrid, wish I could go the HDT route. For some reason the budget gets in the way for now.
Stanley, running tires at 65lbs. That's the rate on the tires and vehicle recommendation. Was concerned running to low and risk load and heating up tires. Hear horror stories all the time. Spoke with dealer, no oil on shocks. Don't think they're blown. I spoke with them and asked them to look at a different shock set up.
Does anyone know of a better route to Livingston from Lafeyette, LA or do I need to be a big boy and just deal with it?
That 65 PSI is for carrying a full load in the bed, if you are under that less pressure can help. You need to get a load / pressure chart for your tires and have the rear axle weighed to see what can be done.
Our pickup was a single and needed the max pressure but our MDT had such a low axle rating that the tire chart didn't go low enough to show it. A call to Michelin was helpful as they explained that the minimum pressure shown on the charts was not related to load but to keeping the tire on the rims. Still dropping from the sidewall and data-plate pressures to the chart suggested pressure helped the ride a good bit with no noticeable increase in heat using my clunky thermometer.
Charts: http://www.michelintruck.com/reference-materials/manuals-bulletins-and-warranties/load-and-inflation-tables/#/
I would look into the Kelderman System. I put one on a F 550 I had that I towed an 18K Mobile Suite with and it made a huge difference. For some reason I can't post the link, but it is Kelderman.com
Interesting... Did you have the two or four point system?
And , I wonder if that would interfere with my 5th wheel rail mounting plates.....
I tell people that we fell off a bridge on I-10. On one of the overpasses in Louisiana when we left a bridge section and dropped back onto the road way we literally fell. A patch had been torn out making the drop in the 10-12" range. We pulled over to check for damage on the truck and trailer springs and luckily didn't have anything major..... until we opened the rv door and saw all the cabinets and drawers open. There were scrub marks in both truck rear wheels and camper wheel wells where the tires bottomed out.
MorRyde IS on the RV is the best way to go, Air hitch, great shocks, good seats all help too.
Is it just on concrete roadbeds ? If so, it could be the harmonics set up by the distance between the joints and the wheelbase of your vehicles...."Some roads nothing will help....."
Years ago, I-40 east of OKC, the road was so bad for my particular set up (Dodge 3500 w/airbags+20' cargo trailer), the harmonics were so bad, I had to hold on to the shift lever to keep it reasonably still.
Regards
Gemstone
I was out in West Texas, went to Ft Davis and Big Bend area, we got on I-10 for a while and decided to get off, it was banging up the MH pretty bad. We got off on the regular hiways, no problem then.
For some of those roads, I think all we can do is to hope they rebuild the road soon. :(
John in Joplin
Few shocks these days contain hyd. oil, most are compressed gas = no oil in there to leak.
I run Rancho 5000, lifetime warranty shocks on my Chevy dually, bought from Sears. Since purchase, Sears has replaced them 2X so far. A heavy 5er (I used to travel with a 40' 5er) is IMO, the harshest thing that can happen to shocks. That makes 3 sets of 4 shocks in 140,000 miles of towing.
Thanks all for the comments. Let me reply to several.
Thanks for the Hyw 190 suggestion. Was wondering if this is good road. Planning to leave New Iberia north on I45 and looks to be a short trip to Livingston using 190..
Question about the road. It's really amazing. Due to poor soil and probably lack of maintenance, alternating concrete slabs can have 3 to 4 inches in vertical shift causing quite a shock. Actually got out of the truck at a red light to look at the road. There are sections that can repeat every other slab for miles. This will be my last trip on I10 and lower Louisiana State roads for sometime.
I have a Hensley Trailer Saver. Has worked well on bad road, but these roads are in a totally different class. Had air bags added to the rear axle yesterday and crossing my fingers this we'll help, but convinced the only solution is to get off these roads as soon as possible.
On tire pressure, I've been running Generals for a year and a half at 65 lbs per door chart. Haven't had much success finding a tire chart on the web.
Also thought about adding Sulastic Shackles but couldn't find a dealer in the area. May try to add when I return to Georgia late March.
