Dollytrolley Posted January 5, 2016 Report Share Posted January 5, 2016 Darn your hide Rooster...... So.....My memory-loss-mom-in-law has decided to give me a break from keeping her away from the large bore handguns and butcher knives so I decided to get a little more crazy than normal and .........assign a Weight & Balance to the Diamond-RV-TEE project........ So....Assume: TEE-Trailer: Fifth box 102 in W X 108 in H X 480 in L , Initial wheelbase 350 in (measured from hitch pin -Datum station 00.0") Empty Wt 13,000 Lbs @ C G 241.32 inches aft of datum Example TEE-Trailer Loading: 1A; Fresh Water (120 Gal Cap) @ Sta 120” = 1008 Lbs 2A; Fresh Water (40 Gal Cap) @ Sta 190” = 504 Lbs 3A; Grey Water (60 Gal Cap) @ Sta 160” = 504 Lbs 4A; Propane (two 40# ) @ Sta 96” = 110 Lbs 5A; Black Water (60 Gal Cap) @ Sta 158” = 400 Lbs 6A; Cargo bay #1 @ Sta 240” = 500 Lbs 7A; Car Power Wagon WWII @ Sta 290” = 4,200 Lbs Example loaded Weight & Balance = 20,562 Lbs , C G @ Sta 246.90 Inches aft of hitch and 103.10 ahead of trailer axle, Hitch pin load = 6,057 Lbs and axle load is 14,505 Lbs (495 Lbs of axle rated load remaining). Weight distribution: Hitch Pin = 29.46% Trailer axle = 70.54% Diamond Tee Toter: Assume: Initial wheelbase 280 in (measured from Steer Axle C L -Datum station 00.0") Empty Wt 12,000 Lbs @ C G 135.33 inches aft of datum Empty Weight Distribution : Steer Axle = 6,200 Lbs; 51.61% Rear Axle = 5,800 Lbs; 48.39% Example truck loading: 1T; Driver @ Sta 96” = 220 Lbs 2T; Pass @ Sta 96” = 120 Lbs 3T; Sleeper Cargo @ Sta 180” = 350 Lbs 4T; Bed Cargo @ Sta 200” = 75 Lbs 5T; Fuel @ Sta 115” = 600 Lbs 6T ; Trailer Hitch load @ Sta 330' = 6,057 Lbs Example loaded Truck Weight & Balance = 19,422 Lbs , C G @ Sta 195.78 Inches aft of steer axle and 84.22” ahead of rear axle, Hitch pin load = 6,057 Lbs and rear axle load is 13,580 Lbs (3,420 Lbs of rear axle rated load remaining). Weight distribution: Steer axle = 30.08% = 5,842 Lbs Rear axle = 69.92% = 13,580 Lbs Disclaimer:.........IF you are rattling around in a Diamond Tee this aint your first gig with hammers and wrenches so.....have a few adult-beverages and …..... Drive on.........(Liers number.......and number lie... some times) 97 Freightshaker Century Cummins M11-370 / 1350 /10 spd / 3:08 /tandem/ 20ft Garage/ 30 ft Curtis Dune toybox with a removable horse-haul-module to transport Dolly-The-Painthorse to horse camps and trail heads all over the Western U S Link to comment Share on other sites More sharing options...
Star Dreamer Posted January 5, 2016 Report Share Posted January 5, 2016 Dolly, For our example, if you have time, rerun your numbers with no power wagon in the back (empty garage) and with a 6600# vehicle in the garage and let us know what happens to pin weight, trailer axle weight and truck axle weights. Also a minor modification would be needed to more closely resemble real loading is the vechile in the garage should be split into two axle loads as most vehicles are not equally loaded on each of their axles, Usually more on front axle. One of the other issues with a single axle trailer is how will it handle if you get a flat, currently with our triple axle, we cannot feel it, which is good in one way in that it does not make us lose control of the trailer but does reguire a TPMS. Dave 2005 Freightliner Century S/T, Singled, Air ride ET Jr. hitch 2019 46'+ Dune Sport Man Cave custom 5th wheel toy hauler Owner of the 1978 Custom Van "Star Dreamer" which might be seen at a local car show near you! Check out http://www.hhrvresource.com/ for much more info on HDT's. Link to comment Share on other sites More sharing options...
RoosterBooster Posted January 5, 2016 Author Report Share Posted January 5, 2016 Dolly very cool .... thank you need to play with that some as much as i love them, but there will be no vintage Power wagon garage will only be 10' ... at first for (most likely) a Yamaha Raptor 700cc ATV (iirc ~500lbs) later down the road i may build myself my modern version of this Austin 7 Special; super lightweight (lots of aluminum), 180+ hp Yamaha R1 or GSXR "offset midship" engine, aluminum "baby" quick change rear, .... (if i ever find the time/money to build it ) so that would reduce garage weight (and height) significantly Dave, in your case (HDT air brake truck) i would use a 20klbs air brake trailer axle with standard hub centric 10 lug, together with the beefier 20-25klbs capacity Ridewell suspension. dual tires add some safety in case one goes flat (but i guess only if your not too heavy and the other tire blows right after it gets the full load ) but to be honest i`m not worried about blowouts with virgin 22.5ers that have a combined load rating that is well over the actual load " Diamonds R 4 ever " "class of`95" Pete 379 "Toterhome": Cummins N14, Super10, single axle, 278" WB, 162" sleeper ... sold current project; 1952 Diamond T, Cummins 8.3l @ 375hp/ 800ft lbs, single axle, 239" WB, 1954 Spartan 137" air ride sleeper .... full timing in a 39 foot "sticks & staples POS" Toyhauler (planing to build an all aluminum 42-45 foot replacement soon) ... Link to comment Share on other sites More sharing options...
RoosterBooster Posted January 5, 2016 Author Report Share Posted January 5, 2016 Rooster, Compared to that awesome Diamond T of yours, anything it pulled would be a piece of crap !!! Anxious to see what you come up with for finished project Cheers, Bob thanks Bob The basic RV construction is lousy and cheap like mentioned. The manufacturers assume it is going to sit for 48 weeks out of the year, and rot the rest. Star Dreamer and I are the only guys here that have flavors of a race car trailer, which is a cargo trailer with minimum living space, but at least built a little stronger than the toyhauler that happens to have a garage in the back. But the Vintage that he has and the Work and Play that I have do endure certain drawbacks and minimum design parameters. I just delivered a brand new Kentucky I picked up at the plant in Louisville and delivered to their division in Walled Lake, MI that modifies them for all sorts of uses, enclosed car haulers, Nascar hospitality trailers, portable workshops, etc. There is nothing like starting with something that is designed for the purpose. If you poke around I am sure you can find a 35-40' bedbug trailer that would be suitable for conversion. You may want to quiz them, they build just about anything, and because all of it is the same basic construction, not that expensive. And take it from there. Jeff as some of the older regulars probably remember i was already considering several times to converting a semi trailer single drop (electronics van) or even a double drop like most moving vans... but that was when i had the Pete now with my much lighter <T> it would be too much trailer for my taste too square, too tall, too strong in places where i dont need it,... so i think i cant avoid a "from the ground up" new construction to fit my needs one thing that i desperately want to avoid is a high garage floor height with a heavy ramp door, door frame, etc... a DSC axle-less setup would solve the floor height problem ; http://dallassmithcorp.com/products/lo-floor-trailer-chassis-modules/ ... but is just out of my price range garage is definitely a challenge, considering that i want tall 22.5 tires and have to settle on a basic (fairly cheap) straight tube axle so while looking at (cargo) airplanes like the C130 ... ...i had this idea ; how about no floor in the garage (in the traditional sense) how about making the ramp door doing double duty as the floor this has been done before by Travel Supreme ... made this rough sketch of how i envision it ; (sorry for the cell pic... dont have the PC i use for CAD online at the moment) 10 foot aluminum ramp/floor on HD fabricated front pivots and suspended/moved by two hydraulic cylinders with a light aluminum "swing up" door that also acts as awing/covered work area bedroom over the garage, then a elevated bathroom area over the axle frame drops down for a low kitchen,living room floor couches/ movie room over the 5th wheel... i made this photoshop of how i envision the outside proportions " Diamonds R 4 ever " "class of`95" Pete 379 "Toterhome": Cummins N14, Super10, single axle, 278" WB, 162" sleeper ... sold current project; 1952 Diamond T, Cummins 8.3l @ 375hp/ 800ft lbs, single axle, 239" WB, 1954 Spartan 137" air ride sleeper .... full timing in a 39 foot "sticks & staples POS" Toyhauler (planing to build an all aluminum 42-45 foot replacement soon) ... Link to comment Share on other sites More sharing options...
beyerjf Posted January 5, 2016 Report Share Posted January 5, 2016 You layout is on the money. To make the garage long enough to accommodate say a Jeep Wrangler pivot your ramp on top of the lowered wheel wells to accommodate almost any length vehicle. Put in level position for travel, like the "baskets" on a car hauling trailer. Rear overhang doesn't get to be a problem that way. The Kentucky trailer I just delivered was going to be made into an enclosed car hauler. It had 17.5 tires and very low unintrusive wheel wells. The floor was no more than 18" from the ground, and the wheel wells were no more than 12" above that. They were going to mount a 15' hydraulic tailgate on it for both levels of cars, but your upward tailgate and ramps would have worked just as well. Jeff Beyer temporarily retired from Trailer Transit 2000 Freightliner Argosy Cabover 2008 Work and Play 34FK Homebase NW Indiana, no longer full time Link to comment Share on other sites More sharing options...
Dollytrolley Posted January 5, 2016 Report Share Posted January 5, 2016 Dolly, For our example, if you have time, rerun your numbers with no power wagon in the back (empty garage) and with a 6600# vehicle in the garage and let us know what happens to pin weight, trailer axle weight and truck axle weights. Also a minor modification would be needed to more closely resemble real loading is the vechile in the garage should be split into two axle loads as most vehicles are not equally loaded on each of their axles, Usually more on front axle. One of the other issues with a single axle trailer is how will it handle if you get a flat, currently with our triple axle, we cannot feel it, which is good in one way in that it does not make us lose control of the trailer but does reguire a TPMS. Dave Star & Rooster...... So.....My memory-loss-mom-in-law has peeked at you guys thread comments and her comment is that you two might need to check the temperature of your adult-beverages........ warm beer may lead to the desire to clone classic British bodies hiding oriental drive-trains........no known cure.......mom knows a lot of things..... they are just a bit-out-of-order........ So Star here is the Rooster-RV-Tee combo numbers after the power wagon fell out...... So....Assume: TEE-Trailer: Fifth box 102 in W X 108 in H X 480 in L , Initial wheelbase 350 in (measured from hitch pin -Datum station 00.0") Empty Wt 13,000 Lbs @ C G 241.32 inches aft of datum Example TEE-Trailer Loading: 1A; Fresh Water (120 Gal Cap) @ Sta 120” = 1008 Lbs 2A; Fresh Water (40 Gal Cap) @ Sta 190” = 504 Lbs 3A; Grey Water (60 Gal Cap) @ Sta 160” = 504 Lbs 4A; Propane (two 40# ) @ Sta 96” = 110 Lbs 5A; Black Water (60 Gal Cap) @ Sta 158” = 400 Lbs 6A; Cargo bay #1 @ Sta 240” = 500 Lbs 7A; Car garage empty @ Sta 290” = 0 Lbs Example loaded Weight & Balance = 16,362 Lbs , C G @ Sta 235.84 Inches aft of hitch and 114.16 ahead of trailer axle, Hitch pin load = 5,337 Lbs and axle load is 11,025 Lbs (3,975 Lbs of axle rated load remaining). Weight distribution: Hitch Pin = 32.62% Trailer axle = 67.38% Diamond Tee Toter: Assume: Initial wheelbase 280 in (measured from Steer Axle C L -Datum station 00.0") Empty Wt 12,000 Lbs @ C G 135.33 inches aft of datum Empty Weight Distribution : Steer Axle = 6,200 Lbs; 51.67% Rear Axle = 5,800 Lbs; 48.33% Example truck loading: 1T; Driver @ Sta 96” = 220 Lbs 2T; Pass @ Sta 96” = 120 Lbs 3T; Sleeper Cargo @ Sta 180” = 350 Lbs 4T; Bed Cargo @ Sta 200” = 75 Lbs 5T; Fuel @ Sta 115” = 600 Lbs 6T ; Trailer Hitch load @ Sta 330' = 5,337 Lbs Example loaded Truck Weight & Balance = 16,362 Lbs , C G @ Sta 235.84 Inches aft of steer axle and 114.16” ahead of rear axle, Hitch pin load = 5,337 Lbs and rear axle load is 11,025 Lbs (5,975 Lbs of rear axle rated load remaining). Weight distribution: Steer axle = 32.84% = 5,337 Lbs Rear axle = 67.38% = 11,025 Lbs Ok Star......next post will be with the garage filled with a 4,200 lb WWII Power Wagon loaded with 2,400 Lbs of........warm beer......... (6,600 lbs in garage).... Disclaimer:.........of course everyone knows that warm beer weighs less than cold beer so …...since many British aircraft tend to be a bit under-powered........warm beer is used to lighten the “load”........ Drive on.........(Liers number .......and who's got the latest numbers) 97 Freightshaker Century Cummins M11-370 / 1350 /10 spd / 3:08 /tandem/ 20ft Garage/ 30 ft Curtis Dune toybox with a removable horse-haul-module to transport Dolly-The-Painthorse to horse camps and trail heads all over the Western U S Link to comment Share on other sites More sharing options...
grendel Posted January 5, 2016 Report Share Posted January 5, 2016 I guess I am a bad influence, eh? Link to comment Share on other sites More sharing options...
Jack Mayer Posted January 5, 2016 Report Share Posted January 5, 2016 Dolly, you have too much time on your hands. I can put you to work if you want. I'm working on an HDT/RV that is specifically designed to be hauled by an HDT. It cannot be hauled by a "conventional" truck. Basically a semi design with a flat floor. Jeff, I should have run that by you when we were together. Custom frame and suspension (likely air), with 22.5 wheels. This will likely be commercialized to a product if it comes out as I hope. For me this is "background" work, but I'd like to have a pretty firm proposal done by the summer. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
hdonlybob Posted January 5, 2016 Report Share Posted January 5, 2016 thanks Bob Jeff as some of the older regulars probably remember i was already considering several times to converting a semi trailer single drop (electronics van) or even a double drop like most moving vans... but that was when i had the Pete now with my much lighter <T> it would be too much trailer for my taste too square, too tall, too strong in places where i dont need it,... so i think i cant avoid a "from the ground up" new construction to fit my needs one thing that i desperately want to avoid is a high garage floor height with a heavy ramp door, door frame, etc... a DSC axle-less setup would solve the floor height problem ; http://dallassmithcorp.com/products/lo-floor-trailer-chassis-modules/ ... but is just out of my price range garage is definitely a challenge, considering that i want tall 22.5 tires and have to settle on a basic (fairly cheap) straight tube axle so while looking at (cargo) airplanes like the C130 ... ...i had this idea ; how about no floor in the garage (in the traditional sense) how about making the ramp door doing double duty as the floor this has been done before by Travel Supreme ... made this rough sketch of how i envision it ; (sorry for the cell pic... dont have the PC i use for CAD online at the moment) 10 foot aluminum ramp/floor on HD fabricated front pivots and suspended/moved by two hydraulic cylinders with a light aluminum "swing up" door that also acts as awing/covered work area bedroom over the garage, then a elevated bathroom area over the axle frame drops down for a low kitchen,living room floor couches/ movie room over the 5th wheel... i made this photoshop of how i envision the outside proportions Rooster, I camped next to a motor home like that for 10 days at Sturgis Bike Week a few years ago, and got to know the people well that owned it...That idea as well as it's mechanics is one of the best I have ever seen...Simple, proficient, and very accessible for maintenance if required.. I have always wondered why they quit making them.... Go for it man 1989 Safari Serengeti 34'Towing a 1952 M38A1 Military Willys Past HDT owner Link to comment Share on other sites More sharing options...
RoosterBooster Posted January 5, 2016 Author Report Share Posted January 5, 2016 I guess I am a bad influence, eh? yeah, you definitely re-started the flame for my burning desire to build a trailer that is usable for full timing Dolly, you have too much time on your hands. I can put you to work if you want. I'm working on an HDT/RV that is specifically designed to be hauled by an HDT. It cannot be hauled by a "conventional" truck. Basically a semi design with a flat floor. Jeff, I should have run that by you when we were together. Custom frame and suspension (likely air), with 22.5 wheels. This will likely be commercialized to a product if it comes out as I hope. For me this is "background" work, but I'd like to have a pretty firm proposal done by the summer. Jack yes, Grendel (John) and i are also talking about that exact same thing for our trailers ; get away from the pickup truck tow-able designs and build them to fit our M/HDT needs John already came up with the name; instead of RV`s we call our planed trailers now FTV`s (full time vehicles) " Diamonds R 4 ever " "class of`95" Pete 379 "Toterhome": Cummins N14, Super10, single axle, 278" WB, 162" sleeper ... sold current project; 1952 Diamond T, Cummins 8.3l @ 375hp/ 800ft lbs, single axle, 239" WB, 1954 Spartan 137" air ride sleeper .... full timing in a 39 foot "sticks & staples POS" Toyhauler (planing to build an all aluminum 42-45 foot replacement soon) ... Link to comment Share on other sites More sharing options...
noteven Posted January 5, 2016 Report Share Posted January 5, 2016 A trailer for full timing with all systems enclosed within the well insulated aluminum envelope, heat recovery ventilation for chilly weather... Wiring and etcetera run in chases not dogs breakfast routing Pay attention to weight Air ride Air or wire fed brake option. Like Rooster drop floor garage. Can hear the rattle of empties rolling out the back "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
noteven Posted January 5, 2016 Report Share Posted January 5, 2016 Did I mention no staples and glued sawdust? "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
RoosterBooster Posted January 5, 2016 Author Report Share Posted January 5, 2016 A trailer for full timing with all systems enclosed within the well insulated aluminum envelope, heat recovery ventilation for chilly weather... Wiring and etcetera run in chases not dogs breakfast routing Pay attention to weight Air ride Air or wire fed brake option. Like Rooster drop floor garage. Can hear the rattle of empties rolling out the back funny, as i type this i actually have a torpedo heater screaming right under my toyhauler, trying to get the frozen hot water line to the bathroom going again yeah, NH definitely s.... er... blows in the winter with a crappy RV so yes; fully enclosed, insulated and heated center tunnel is also on my "must have" list " Diamonds R 4 ever " "class of`95" Pete 379 "Toterhome": Cummins N14, Super10, single axle, 278" WB, 162" sleeper ... sold current project; 1952 Diamond T, Cummins 8.3l @ 375hp/ 800ft lbs, single axle, 239" WB, 1954 Spartan 137" air ride sleeper .... full timing in a 39 foot "sticks & staples POS" Toyhauler (planing to build an all aluminum 42-45 foot replacement soon) ... Link to comment Share on other sites More sharing options...
Dollytrolley Posted January 5, 2016 Report Share Posted January 5, 2016 Dolly, For our example, if you have time, rerun your numbers with no power wagon in the back (empty garage) and with a 6600# vehicle in the garage and let us know what happens to pin weight, trailer axle weight and truck axle weights. Also a minor modification would be needed to more closely resemble real loading is the vechile in the garage should be split into two axle loads as most vehicles are not equally loaded on each of their axles, Usually more on front axle. One of the other issues with a single axle trailer is how will it handle if you get a flat, currently with our triple axle, we cannot feel it, which is good in one way in that it does not make us lose control of the trailer but does reguire a TPMS. Dave Star & Rooster...... So..... Star & Rooster, here is the Rooster-RV-Tee combo numbers after Star re-loads the power wagon (4,200Lbs at Sta 290”)......Plus Two-Thousand-Four-Hundred-Pounds of warm beer into the Power Wagon at Sta 290” as well So....Assume: TEE-Trailer: Fifth box 102 in W X 108 in H X 480 in L , Initial wheelbase 350 in (measured from hitch pin -Datum station 00.0") Empty Wt 13,000 Lbs @ C G 241.32 inches aft of datum Example TEE-Trailer Loading: 1A; Fresh Water (120 Gal Cap) @ Sta 120” = 1008 Lbs 2A; Fresh Water (40 Gal Cap) @ Sta 190” = 504 Lbs 3A; Grey Water (60 Gal Cap) @ Sta 160” = 504 Lbs 4A; Propane (two 40# ) @ Sta 96” = 110 Lbs 5A; Black Water (60 Gal Cap) @ Sta 158” = 400 Lbs 6A; Cargo bay #1 @ Sta 240” = 500 Lbs 7A; Car garage empty @ Sta 290” = 4,200 Lbs 8A; Warm beer @ Sta 290” = 2,400 Lbs Example loaded Weight & Balance = 22,962 Lbs , C G @ Sta 251.41 Inches aft of hitch and 98.59 ahead of trailer axle, Hitch pin load = 6,468 Lbs and axle load is 16,494 Lbs (1,494 Lbs OVERLOADED of axle rated load). Weight distribution: Hitch Pin = 28.17% Trailer axle = 71.83% Diamond Tee Toter: Assume: Initial wheelbase 280 in (measured from Steer Axle C L -Datum station 00.0") Empty Wt 12,000 Lbs @ C G 135.33 inches aft of datum Empty Weight Distribution : Steer Axle = 6,200 Lbs; 51.67% Rear Axle = 5,800 Lbs; 48.33% Example truck loading: 1T; Driver @ Sta 96” = 220 Lbs 2T; Pass @ Sta 96” = 120 Lbs 3T; Sleeper Cargo @ Sta 180” = 350 Lbs 4T; Bed Cargo @ Sta 200” = 75 Lbs 5T; Fuel @ Sta 115” = 600 Lbs 6T ; Trailer Hitch load @ Sta 330' = 6,468 Lbs Example loaded Truck Weight & Balance = 19,833 Lbs , C G @ Sta 198.56 Inches aft of steer axle and 81.44” ahead of rear axle, Hitch pin load = 5,768 Lbs and rear axle load is 14,065 Lbs (2,935 Lbs of rear axle rated load remaining). Weight distribution: Steer axle = 29.08% = 5,768 Lbs Rear axle = 70.92% = 14,085 Lbs Ok Star & Rooster...... with the garage filled with a 4,200 lb WWII Power Wagon loaded with 2,400 Lbs of........warm beer......... (6,600 lbs in garage).... the 15K trailer axle is a bit overloaded.......maybe.... What-IF........ Star programmed the Rooster-Optional-Rear-Axle-RELOCATE-Panel just below the fuzz-buster panel and dialed-the-TEE-Trailer-wheelbase out to........Sta 440”..........stay tuned children......the next post has more …..warm beer numbers Disclaimer:.........of course everyone knows that warm beer ….....is worse than warm Dr. Pepper........ Drive on.........(Lairs number .......and who's got the better numbers) 97 Freightshaker Century Cummins M11-370 / 1350 /10 spd / 3:08 /tandem/ 20ft Garage/ 30 ft Curtis Dune toybox with a removable horse-haul-module to transport Dolly-The-Painthorse to horse camps and trail heads all over the Western U S Link to comment Share on other sites More sharing options...
GoldRush Posted January 5, 2016 Report Share Posted January 5, 2016 Here is a suspension set up I'd never seen before but it allowed the trailer floor to be dropped to grade level for easy unloading of their long and low land speed car. Everyone on the team also raved about how [/url] Link to comment Share on other sites More sharing options...
MrSeas Posted January 5, 2016 Report Share Posted January 5, 2016 Check this out.....http://airbaggedtrailers.com/index.html Link to comment Share on other sites More sharing options...
Dollytrolley Posted January 5, 2016 Report Share Posted January 5, 2016 Dolly, you have too much time on your hands. I can put you to work if you want. I'm working on an HDT/RV that is specifically designed to be hauled by an HDT. It cannot be hauled by a "conventional" truck. Basically a semi design with a flat floor. Jeff, I should have run that by you when we were together. Custom frame and suspension (likely air), with 22.5 wheels. This will likely be commercialized to a product if it comes out as I hope. For me this is "background" work, but I'd like to have a pretty firm proposal done by the summer. Jack...... You are right on.....All I have is time...... this winter.......mom-in-law memory-jumble has me resorting to ......Recreational-Weight-&-Balance number-juggling to try to not pass her crazy-rating # ( wife says I sometimes pass mom....oh well....) RV Weight & Balance is slightly more complex by a tiny bit than aircraft since once you arrive at the actual calculated Center of Gravity then you next have to calculate the weight distribution related to the vehicle wheelbase and then you now have calculated axle load.......then.......IF you really want to get the job done correctly you should consider the Delta-Mass of each wheel position load (as recommended by Trey).....since most RV's tend to have lateral balance issues due to various 'option" locations (Slides, generators, battery-banks, water tanks, kitchen appliances......warm-beer.....etc.) The calculations are fairly simple.......the hard part is arriving at the accurate mass Center of Gravity and weight location for each item that is shifted around above the basic-RV-Empty-Wt & C G baseline. Normal RV day-today operational Weight & Balance calculations are very simple once the basic-RV-Empty-Wt & C G baseline is documented AND all significant additional loads are entered into the calculations. Design based Weight & Balance tends to be a bit more tedious since it may be desirable to adjust baseline components that often re-calculating components from location to another location and then re-calculating the NEW basic-RV-Empty-Wt & C G baseline. In a perverted-sense it is sorta fun to "play-weight-&-balance-chess" in the design stage since it allows one to make the mistakes on paper before you make the real mistakes with hardware.....(don't ask me how I know....). Anyhow feel free to shoot me the details of what your project is and I'll cast a eye on it....I have some time on my hands and am fully retired so I just need to keep mom away from guns and chainsaws.......my email is mmcdan3189@aol.com Drive on..........(Hide the.......sharp objects) Drive 97 Freightshaker Century Cummins M11-370 / 1350 /10 spd / 3:08 /tandem/ 20ft Garage/ 30 ft Curtis Dune toybox with a removable horse-haul-module to transport Dolly-The-Painthorse to horse camps and trail heads all over the Western U S Link to comment Share on other sites More sharing options...
RoosterBooster Posted January 5, 2016 Author Report Share Posted January 5, 2016 Check this out.....http://airbaggedtrailers.com/index.html yeah ... she looks like she has a set of air bags too yes, i have seen that "kneeling" design before over by the low slung crowd we offroaders usually dont even bother unloading with ramps ... even on my deck-over trailer i usually just gunned it ... thats what ground clearance & suspension travel is for in theory i "could" design and fabricate my own low riding air setup using basic M/HDT spindles, hubs & brakes. but it would be a "one off" thing ... where on the other hand Ridewell and Dexter repair and parts are available everywhere time and desire to do it is also a little low (i really dont enjoy welding all that much anymore ) i really try to KISS this (keep it simple stupid ) " Diamonds R 4 ever " "class of`95" Pete 379 "Toterhome": Cummins N14, Super10, single axle, 278" WB, 162" sleeper ... sold current project; 1952 Diamond T, Cummins 8.3l @ 375hp/ 800ft lbs, single axle, 239" WB, 1954 Spartan 137" air ride sleeper .... full timing in a 39 foot "sticks & staples POS" Toyhauler (planing to build an all aluminum 42-45 foot replacement soon) ... Link to comment Share on other sites More sharing options...
Jack Mayer Posted January 5, 2016 Report Share Posted January 5, 2016 Rooster, The "Keep it simple thing" is paramount, as is nationwide parts availability and commercial robustness. I'm tired of "RV stuff". My design criteria is different than most of you fabricator guys....I done WANT custom. I WANT easy availability of parts and the ability for anyone with a decent commercial shop to be able to fix it. eg. any truck place. The issue of freezup is only something you see in the cheaper RVs. Not an issue at all in the custom trailers ; Spacecraft, Forks, New Horizons. But it certainly needs to be designed in. Not a big deal. Same thing with most of the systems. Pretty easy and well known technology....it is just the expense of doing it "right" is not in the picture for a "build 2000 a year, for under $100K" trailer. The target price of a 45' HDT RV in my mind is right around $200K or under, and that would be a luxury RV with high end fixtures and capabilities. At least that is my current thinking. The infrastructure costs are a good chunk of that.....much more so than in the "flashy" RV industry today. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
grendel Posted January 5, 2016 Report Share Posted January 5, 2016 Rooster, The "Keep it simple thing" is paramount, as is nationwide parts availability and commercial robustness. I'm tired of "RV stuff". My design criteria is different than most of you fabricator guys....I done WANT custom. I WANT easy availability of parts and the ability for anyone with a decent commercial shop to be able to fix it. eg. any truck place. The issue of freezup is only something you see in the cheaper RVs. Not an issue at all in the custom trailers ; Spacecraft, Forks, New Horizons. But it certainly needs to be designed in. Not a big deal. Same thing with most of the systems. Pretty easy and well known technology....it is just the expense of doing it "right" is not in the picture for a "build 2000 a year, for under $100K" trailer. The target price of a 45' HDT RV in my mind is right around $200K or under, and that would be a luxury RV with high end fixtures and capabilities. At least that is my current thinking. The infrastructure costs are a good chunk of that.....much more so than in the "flashy" RV industry today. Funny, I had this conversation last week. I also put together the business plan and a capable model. I have the infrastructure covered already. Link to comment Share on other sites More sharing options...
RoosterBooster Posted January 5, 2016 Author Report Share Posted January 5, 2016 Jack to not bend the board rules i was trying to avoid talking too much about eventual business sides besides that i think my "poor man`s" MDT`ish version would be a one off and only related in construction technique to an eventual available product i hear you on "custom" fabricated parts ... yes, as older i get the more i look for using/ re-purposing existing parts instead of trying to re-inventing the wheel most fabricators have also the bad tendency (like most German car manufacturers) to "over-engineer" and build things with more parts then really needed for its function that is a large part (together with liability) why i like to use things like a ready available and rather simple Ridewell suspension ; it is designed just like our truck suspensions; commercial duty cycle, virtually no maintenance and nation wide parts availability imho with a little "outside of the box" layout there is not a big issue with the somewhat bulky straight axle and 40" tall tires talking about "Box"; to me it seems the RV pin boxes are getting longer and longer every year ; i kinda see the need for the guys towing with a short bed CC, but to me this is just ridiculous (as in leverage on the frame as well as aerodynamics and wasted space) so i plan to build the pin area in a more "semi trailer" style ; flat kingpin backup plate direct under the nose beams with the pin set back by 3 foot to tuck the trailer close behind the sleeper this gives me a higher interior height and 3 extra foot of living room without longer overall length not to mention a drastic reduction in drag, especially in cross-wind. naturally this requires 3 foot radius rounded front corners for swing clearance, but my desired "vintage look" is asking for that anyway " Diamonds R 4 ever " "class of`95" Pete 379 "Toterhome": Cummins N14, Super10, single axle, 278" WB, 162" sleeper ... sold current project; 1952 Diamond T, Cummins 8.3l @ 375hp/ 800ft lbs, single axle, 239" WB, 1954 Spartan 137" air ride sleeper .... full timing in a 39 foot "sticks & staples POS" Toyhauler (planing to build an all aluminum 42-45 foot replacement soon) ... Link to comment Share on other sites More sharing options...
Dollytrolley Posted January 5, 2016 Report Share Posted January 5, 2016 Dolly, For our example, if you have time, rerun your numbers with no power wagon in the back (empty garage) and with a 6600# vehicle in the garage and let us know what happens to pin weight, trailer axle weight and truck axle weights. Also a minor modification would be needed to more closely resemble real loading is the vechile in the garage should be split into two axle loads as most vehicles are not equally loaded on each of their axles, Usually more on front axle. One of the other issues with a single axle trailer is how will it handle if you get a flat, currently with our triple axle, we cannot feel it, which is good in one way in that it does not make us lose control of the trailer but does reguire a TPMS. Dave Star & Rooster...... So..... Star & Rooster, here is the Rooster-RV-Tee combo numbers after Star re-loads the power wagon (4,200Lbs at Sta 290”)......Plus Two-Thousand-Four-Hundred-Pounds of warm beer into the Power Wagon at Sta 290” as well.....and as we have seen adult-beverage-addiction can have adverse consequences for …...balance......and RV axle loading..... So.......What-IF........ Star programmed the Rooster-Optional-Rear-Axle-RELOCATE-Panel just below the fuzz-buster panel and dialed-the-TEE-Trailer-wheelbase out to........Sta 440”.....what would the “new” weight & balance numbers look like and can we somehow get back to “legal-limits”.....?? So....Assume: TEE-Trailer: Fifth box 102 in W X 108 in H X 480 in L , Initial wheelbase 440 in (measured from hitch pin -Datum station 00.0") Empty Wt 13,000 Lbs @ C G 304.62 inches aft of datum Example TEE-Trailer Loading: 1A; Fresh Water (120 Gal Cap) @ Sta 120” = 1008 Lbs 2A; Fresh Water (40 Gal Cap) @ Sta 190” = 504 Lbs 3A; Grey Water (60 Gal Cap) @ Sta 160” = 504 Lbs 4A; Propane (two 40# ) @ Sta 96” = 110 Lbs 5A; Black Water (60 Gal Cap) @ Sta 158” = 400 Lbs 6A; Cargo bay #1 @ Sta 240” = 500 Lbs 7A; Car garage empty @ Sta 290” = 4,200 Lbs 8A; Warm beer @ Sta 290” = 2,400 Lbs Example loaded Weight & Balance = 22,962 Lbs , C G @ Sta 286.68 Inches aft of hitch and 153.32 ahead of trailer axle, Hitch pin load = 8,001 Lbs and axle load is 14,961 Lbs ( 49 Lbs additional margin remains above axle rated load). Weight distribution: Hitch Pin = 28.17% Trailer axle = 71.83% Diamond Tee Toter: Assume: Initial wheelbase 280 in (measured from Steer Axle C L -Datum station 00.0") Empty Wt 12,000 Lbs @ C G 135.33 inches aft of datum Empty Weight Distribution : Steer Axle = 6,200 Lbs; 51.67% Rear Axle = 5,800 Lbs; 48.33% Example truck loading: 1T; Driver @ Sta 96” = 220 Lbs 2T; Pass @ Sta 96” = 120 Lbs 3T; Sleeper Cargo @ Sta 180” = 350 Lbs 4T; Bed Cargo @ Sta 200” = 75 Lbs 5T; Fuel @ Sta 115” = 600 Lbs 6T ; Trailer Hitch load @ Sta 330' = 8,001 Lbs Example loaded Truck Weight & Balance = 22,962 Lbs , C G @ Sta 207.99 Inches aft of steer axle and 72.01” ahead of rear axle, Hitch pin load = 8,001 Lbs and rear axle load is 15,871 Lbs (1,129 Lbs of rear axle rated load remaining). Weight distribution: Steer axle = 25.72% = 5,495 Lbs Rear axle = 74.28% = 15,871 Lbs Ok Star & Rooster...... with the garage filled with a 4,200 lb WWII Power Wagon loaded with 2,400 Lbs of........warm beer......... (6,600 lbs in garage).... the 15K trailer axle MOVED back to Sta 440” we now have returned back within the rear trailer axle load limits and the Diamond TEE has a pretty hefty hitch pin load but all RV axle loads are now within legal-limits........ Disclaimer:.........Whew.......Me thinks it's time for a COLD Beer or Dr. Pepper........ Drive on.........(“Legal number” .......are ok numbers) 97 Freightshaker Century Cummins M11-370 / 1350 /10 spd / 3:08 /tandem/ 20ft Garage/ 30 ft Curtis Dune toybox with a removable horse-haul-module to transport Dolly-The-Painthorse to horse camps and trail heads all over the Western U S Link to comment Share on other sites More sharing options...
noteven Posted January 6, 2016 Report Share Posted January 6, 2016 Rooster I hear you about keeping the trailer gap close - here are a couple video links to a close-coupled tractor trailer RV - sorry the unit is a bit modern - but similar concept to FTV...it is pretty maneuverable - and short... you give up the off track swing of a trailer hitched way back of the rear axle but you make use of the cab to end of tractor real estate for living space: https://www.youtube.com/watch?v=1KS3F7S95VUand https://www.youtube.com/watch?v=uRbo61h2ow8 looking at my "FTV" notes I've jotted down "suspension overinflation valves" which do the opposite of kneeling the truck and trailer - they overinflate the suspension for raising momentarily - like blocking lowbeds when unhooking or cow pots that have pin leg landing gear, or clearing humpy approaches and rr crossings... One thing we like about our C-Force toyhauler is the ground clearance "off road" parking and on those stupid gas station approaches, so my "FTV" notes show a "drop deck" style trailer but it would be able to be raised at low speed for clearance plus have some skid protection for careful grounding when necessary. "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
oscarvan Posted January 6, 2016 Report Share Posted January 6, 2016 Did I mention no staples and glued sawdust? I'm in. Been doodling something that looks like a medieval castle for some time now. (Long story) Hydraulically extending turrets....draw bridge..... Steel frame and skin. Start with a low boy...... Don't single the truck, keep the commercial fifth wheel hitch. Previously a 2017 Forest River, Berkshire 38A, "The Dragonship". https://dragonship.blog/ Link to comment Share on other sites More sharing options...
Jack Mayer Posted January 6, 2016 Report Share Posted January 6, 2016 My design goal is likely different than most of you guys. I want only living quarters - no hauler space at all. And the ability to pair with an HDT carrying a smart. So the "close the gap" goal is good, but not relevant to what I'm doing. Moving the pin to be a straight down pin is a given...but the setback is minimal - 12" is about it. Unlike a typical semi trailer design. For running gear I've been looking at some of the axles sets with air suspension and complete air disc systems on them. Of course you can mix/match this stuff pretty easily....but a standard setup has its advantages. Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
