brunsje Posted December 2, 2015 Report Share Posted December 2, 2015 Folks, I really need your help! My 2013 Freightliner Cascadia with DD16 is surging badly enough to cause Eaton 13 Speed Supershift Ultra Plus faults and limiting me to 5th Gear. This occurs whether the engine is cold or fully warmed up. The only way I can get down the road is to place the transmission in Manual Control; Then quickly shift the gears up past 6th gear. Yesterday after I got moving again I was in the Florida Keys. I kept the truck running until I got home to Jacksonville, FL, about 540 mile drive. The engine and transmission operated normally with no dashboard warning lights or alarms after I finally cleared the Eaton transmission alarms. My initial thoughts were bad fuel filters, but it pulls up hills at full power great. I contacted the hotlines at Eaton, DD, and Freightliner but they were of no help. Just said to get it to the local dealer, which I will attempt in a few days. Do you guys have any items I can checkout before I go to a local dealer? I am an amateur mechanic and do not have any code scanning ability. Thanks, JohnnyB Link to comment Share on other sites More sharing options...
NoDirectionHome Posted December 2, 2015 Report Share Posted December 2, 2015 Nothing for sure but I'd check the turbo path from inlet through the intercoolers into the engine. Throttle position sensor would be my next target. Hope you get that sorted with something simple. Good grounding always a suspect as well. Link to comment Share on other sites More sharing options...
beyerjf Posted December 2, 2015 Report Share Posted December 2, 2015 Unfortunately with the level of sophistication and complexity of post 2009 class 8 drivetrains, especially with automated manuals, you have no choice but to hook it up to the appropriate program and start with a diagnosis there. Anything else is pure guesswork and in the long term very expensive changing parts that may nothing to do with the issue. That is why the industry is clearly divided into 2 camps these days. Those that are a slave to this sort of thing and those that refuse to (me) Link to comment Share on other sites More sharing options...
brunsje Posted December 2, 2015 Author Report Share Posted December 2, 2015 I appreciate your feedback. My local dealer said if I felt comfortable to remove the battery cables for a few minutes, but they said it was not likely to fix the issue. Link to comment Share on other sites More sharing options...
Dollytrolley Posted December 2, 2015 Report Share Posted December 2, 2015 Unfortunately with the level of sophistication and complexity of post 2009 class 8 drivetrains, especially with automated manuals, you have no choice but to hook it up to the appropriate program and start with a diagnosis there. Anything else is pure guesswork and in the long term very expensive changing parts that may nothing to do with the issue. That is why the industry is clearly divided into 2 camps these days. Those that are a slave to this sort of thing and those that refuse to (me) X 2 Jeff It's sorta odd that..... if..... or..... when the Auto-Tranny gets "heart-burn" the next desired function is.........to shift the tranny in manual-mode in order to not have to have the truck towed..... It would seem to be a nice option to have a Plug-in-clutch-peddle.......and a plug-in-manual-shift-stick.......so that you could move around until it is handy to have the desired shop perform the needed auto-system-repairs......... It's interesting how many shops these days are converting Auto-Tranny-Trucks back to manual-tranny configuration (Cost seems to hover around $3K for the conversion)........ Seems that if the disconnect-battery-task does work you likely had a transient "glitch" if not maybe various sensors are getting the old-sensor syndrome..........Jeff is likely correct that throwing parts at the problem can get $$$ and may not fix the problem..........Sometimes a few $$ spent with the tranny-geeks is the best solution in to end....... Good luck. Drive on...........(Some gears are better than.......no gears) Link to comment Share on other sites More sharing options...
SIBERNUT Posted December 2, 2015 Report Share Posted December 2, 2015 With Volvo, sometimes cycling the ign key 3 times does a reset. Link to comment Share on other sites More sharing options...
brunsje Posted December 4, 2015 Author Report Share Posted December 4, 2015 I am taking the Cascadia to my local Freightliner dealer tomorrow. I'll let you know the outcome! JohnnyB Link to comment Share on other sites More sharing options...
MrSeas Posted December 9, 2015 Report Share Posted December 9, 2015 Johnny B, What was the out come of your visit to the dealer to resolve your problem? Link to comment Share on other sites More sharing options...
brunsje Posted December 10, 2015 Author Report Share Posted December 10, 2015 Still at the dealer. I'll let U know soon! JohnnyB Link to comment Share on other sites More sharing options...
brunsje Posted December 11, 2015 Author Report Share Posted December 11, 2015 Truck maintenance completed. 1. Surging fault isolated to bad speed sensor on the Eaton 13 speed UltraShift Plus. They also updated the software. Repaired under warranty. 2. They removed, cleaned, and applied corrosion treatment to the battery terminals and grounds based on what I have read in this forum. 3. Did annual service. I always replace the fuel filters every year. Ready to go! JohnnyB Link to comment Share on other sites More sharing options...
CDR Posted December 11, 2015 Report Share Posted December 11, 2015 JohnnyB; I have to ask, are you signed up to Access Freightliner? You should have got the bulletin for this if you were? Curt Link to comment Share on other sites More sharing options...
NoDirectionHome Posted December 11, 2015 Report Share Posted December 11, 2015 Great news JohnnyB. Glad it all worked out for you. Link to comment Share on other sites More sharing options...
brunsje Posted December 12, 2015 Author Report Share Posted December 12, 2015 I am not signed up for Access Freightliner, but I will pursue! Thanks for the info! JohnnyB Link to comment Share on other sites More sharing options...
