Nigel Posted November 25, 2015 Report Share Posted November 25, 2015 Would someone be kind enough to post a picture or drawing of a draw bar similar to the one Toterman used. I can't seem to find it in the forum and I know I've seen a picture before. My car was rear ended and my trailer hitch is trash so time for something better. Thanks in advance Nigel Link to comment Share on other sites More sharing options...
SuiteSuccess Posted November 25, 2015 Report Share Posted November 25, 2015 Nigel, Don't have a picture but will try to get you one next week when I get to truck if my memory doesn't fail me. I can describe it though. Just two inch (1/4" thick )tubing. Cut slots in one side toward each end large enough for stock Smart eye bolts to slip into. Drill 1/2" holes through and through at 90 degree angle to slots Drop pins through these holes and through eyes of Smart bolts. Multiple ways to connect winch cable. Can use a "solid eye" bolt at appropriate place along tubing. Note to use this tubing you will need either two Smart eye bolts or equivalent. Link to comment Share on other sites More sharing options...
Nigel Posted November 25, 2015 Author Report Share Posted November 25, 2015 Thanks Suite. It makes sense now. I knew he had a quick way of taking it off and on. I know where I can get another tow eye cheap. Link to comment Share on other sites More sharing options...
rdickinson Posted November 25, 2015 Report Share Posted November 25, 2015 Send me a regular e-mail and I will send pics today. Roger Link to comment Share on other sites More sharing options...
SuiteSuccess Posted November 25, 2015 Report Share Posted November 25, 2015 Good. Gotta tell my wife something I said made some sense. She says it's a rare event? Link to comment Share on other sites More sharing options...
Nigel Posted November 25, 2015 Author Report Share Posted November 25, 2015 Send me a regular e-mail and I will send pics today. Roger Done. Thanks Roger. Link to comment Share on other sites More sharing options...
Darryl&Rita Posted November 26, 2015 Report Share Posted November 26, 2015 Not quite what you're thinking, but I'll throw it out there for consideration. The advantages to this system are reduced size of the metal carried, no need for a pulley riser to prevent rubbing, ability to use the winch for other purposes, and better portability. Link to comment Share on other sites More sharing options...
Nigel Posted November 26, 2015 Author Report Share Posted November 26, 2015 Thanks Darryl. That is exactly what Suite was describing without the winch. Nigel Link to comment Share on other sites More sharing options...
Jack Mayer Posted November 26, 2015 Report Share Posted November 26, 2015 The details on mine are in this album LINK. If you click on the little info icon you will get text describing things. Link to comment Share on other sites More sharing options...
Nigel Posted November 26, 2015 Author Report Share Posted November 26, 2015 Jack I get an error message trying to use that link on Chrome and Firefox. Nigel Link to comment Share on other sites More sharing options...
GlennWest Posted November 26, 2015 Report Share Posted November 26, 2015 Not quite what you're thinking, but I'll throw it out there for consideration. The advantages to this system are reduced size of the metal carried, no need for a pulley riser to prevent rubbing, ability to use the winch for other purposes, and better portability. I like that mouse trap. May incorporate that on mine. Link to comment Share on other sites More sharing options...
Big5er Posted November 26, 2015 Report Share Posted November 26, 2015 So do the eye bolts stay in or do you unscrew them and take them out each time? Link to comment Share on other sites More sharing options...
rdickinson Posted November 26, 2015 Report Share Posted November 26, 2015 In my case the bumper stays on with Larry's metric bolts, the winch n snatch block are in the rt side storage and the A frame is kept in the passengers storage box under the sleeper. Link to comment Share on other sites More sharing options...
Nigel Posted November 26, 2015 Author Report Share Posted November 26, 2015 Phil I think you could either. I know from screwing my one eye bolt in it is not flat when tight. So to leave it in I would have to tighten when bar removed and loosen to use. Probably just as easy to take the ten seconds and take them off and toss in the compartment with the bar. If someone decided to remove them for you while shopping that could ruin your day. Nigel Link to comment Share on other sites More sharing options...
Jack Mayer Posted November 26, 2015 Report Share Posted November 26, 2015 Try my link again. Maybe sharing was not set right. Here is a link to the album (main album, not the specific photo. The photos of the crossbar are near the end. Link to comment Share on other sites More sharing options...
Hewhoknowslittle Posted November 26, 2015 Report Share Posted November 26, 2015 Phil I think you could either. I know from screwing my one eye bolt in it is not flat when tight. So to leave it in I would have to tighten when bar removed and loosen to use. Probably just as easy to take the ten seconds and take them off and toss in the compartment with the bar. If someone decided to remove them for you while shopping that could ruin your day. Nigel You could use a backup nut to set it to the correct angle and it would stay tight, not theft proof but stays with the car. Roger Link to comment Share on other sites More sharing options...
rickeieio Posted November 26, 2015 Report Share Posted November 26, 2015 You could use a backup nut to set it to the correct angle and it would stay tight, not theft proof but stays with the car. Roger Yeah, I was thinking a thin washer to get the eye in the proper position, then a dab of Loc-Tite. I wouldn't think these eyes would be a high theft item, except at a rally................ Link to comment Share on other sites More sharing options...
Darryl&Rita Posted November 26, 2015 Report Share Posted November 26, 2015 We pull the 2 eye bolts. Takes but a second. Ours also don't sit flat when tight. Link to comment Share on other sites More sharing options...
Bigtrailer Posted November 28, 2015 Report Share Posted November 28, 2015 Those eye bolts sticking out would really make ya overwidth even more than we already are. 102 inches in the USA is max width. We are all pushing the envelope. Bill Link to comment Share on other sites More sharing options...
rdickinson Posted November 28, 2015 Report Share Posted November 28, 2015 There is more than one reasonably capable forum member here with access to a CNC lathe, why not make some. 2 parts, one threads into the back of the car and the second has the ring. This picture is as close as I can get but you get the idea. Link to comment Share on other sites More sharing options...
