Carol K Posted November 25, 2015 Report Share Posted November 25, 2015 Good Morning, brand new member, no RV yet but doing research. Can someone explain the difference, if there is one, between the solar panels with black edge or a silver edge. Do I need to worry about it? So much to learn but such fun. Carol K Link to comment Share on other sites More sharing options...
Jack Mayer Posted November 25, 2015 Report Share Posted November 25, 2015 Check out my website for a bunch of info on solar and DIY installation and design. Link in my signature. To answer your question: in general, no difference due to the frame, but to be sure you would have to look at the specific panels and their specs. Link to comment Share on other sites More sharing options...
Daveh Posted November 25, 2015 Report Share Posted November 25, 2015 I second recommendation to look at Jack's website. Best resource for rv'ers out there. Link to comment Share on other sites More sharing options...
oldjohnt Posted November 25, 2015 Report Share Posted November 25, 2015 FWIW (nothing actually) I likewise am not familiar with differences based solely on the color of edge framing??? But of course match your panels (especially if in parallel) with similar characteristics such as nominal voltage, peak voltage, wattage, mono or poly crystalline, type and brand which I'm sure is intuitive and you would do anyway and consider series or parallel or series/parallel combinations to suit your needs and your solar charge controller ability along with shading problems. From experience and help I obtained here, I learned the importance of a good quality (preferably a so called "Smart" 3 or 4 stage, I prefer MPPT) Solar Charge Controller is as important as the panels I chose. (Thanks Stanley and Jack and Kirk and Yarome and others) I AGREE READ JACKS WEBSITE FIRST then ask him and the other knowledgeable solar gents here any questions, my background is more along the lines of AC Power Distribution then Solar but I try to help if I can. Happy Thanksgiving, John T Link to comment Share on other sites More sharing options...
Carol K Posted November 25, 2015 Author Report Share Posted November 25, 2015 Thanks Jack, funny I was on your site reviewing your latest panels on your 2015 model when I came up with my question. Super site, and I would love to buy my panels now, but realize that without knowing what RV I would eventually buy it may not be wise. Thanks for such a great site. Carol K Link to comment Share on other sites More sharing options...
Carol K Posted November 25, 2015 Author Report Share Posted November 25, 2015 Thanks John T, I am lucky to have a better half that will be able to do the install, but I get left with the research part. So I'm sure the questions will flow! Carol K Link to comment Share on other sites More sharing options...
Smitty77_7 Posted November 25, 2015 Report Share Posted November 25, 2015 Would not one possible difference be slightly lower heat of the grey vs the black? Does not heat impact solar output? (Probably very minor in the overall scheme of things.). Please notice the "?" mark, and the word possible:)! Carol - Jack's site is great! Best to all, Smitty Link to comment Share on other sites More sharing options...
Carol K Posted November 25, 2015 Author Report Share Posted November 25, 2015 Smitty good point. I also wondered if it made a difference the way they fitted into connectors, if certain connectors were only good with certain panels? Could be over thinking it all to lol. Carol K Link to comment Share on other sites More sharing options...
Jack Mayer Posted November 25, 2015 Report Share Posted November 25, 2015 Smitty good point. I also wondered if it made a difference the way they fitted into connectors, if certain connectors were only good with certain panels? Could be over thinking it all to lol. Carol K The connectors these days are usually MC4 on almost all the panels. There are some variations, but 90%+ will be MC4. Link to comment Share on other sites More sharing options...
Forest Grump Posted December 2, 2015 Report Share Posted December 2, 2015 Carol I read as much as I could on solar systems including everything Solar Jack had available. I was trying to find the weak links in a solar system. Most name brand modern panels are very similar as to their specs and quality. The brand of solar controller is very important. The placement of the panels is very important and the gauge of the wiring you use can make or break you. I used 3 160w panels - brand name. Tristar controller. 8g solar cable on the roof into a closet, parallel. Then 2g from the closet to the controller to the batteries. All fused according to Jack. It works, theoretical is 27 amps and I have seen that. My voltage drop to the batteries is measured in 0.0N Volts. The price difference in wire from 2g to 6g is not all that different. What this means is I don't have to find the perfect spot to park. Clouds don't ruin my day. I can camp in forested areas, which is what I do. To sum it up be conservative in your choices. Link to comment Share on other sites More sharing options...
Kirk W Posted December 3, 2015 Report Share Posted December 3, 2015 Good Morning, brand new member, no RV yet but doing research. Just wanted to say, welcome to the Escapee forums, since nobody had done so as yet. Jack is pretty much the resident expert on solar and while I have many years of RV experience, we don't do dry camping so I am just an observer so I'll leave the subject to others. But we are all happy that you have joined us and do hope that you become a regular contributor. Link to comment Share on other sites More sharing options...
