IRUNL8R Posted November 24, 2015 Report Share Posted November 24, 2015 I was told today about a new technology that may be coming down the road. It uses visual light communications to transport data instead of radio waves (Wi-Fi). I am not sure about anything else on the subject, so thought I would put it to the forums to see if anyone can confirm or deny it exists? Li-Fi is what is called. I was told that it can transmit data at 100x faster than wi-fi. Technomadia have you guys heard of this?? Link to comment Share on other sites More sharing options...
Jack Mayer Posted November 24, 2015 Report Share Posted November 24, 2015 Yes, I'm aware of it. It uses the visible light spectrum, rather than the radio spectrum for digital transmission. It shows great promise but it is not in the commercial sphere yet. Link to comment Share on other sites More sharing options...
IRUNL8R Posted November 24, 2015 Author Report Share Posted November 24, 2015 Yes, I'm aware of it. It uses the visible light spectrum, rather than the radio spectrum for digital transmission. It shows great promise but it is not in the commercial sphere yet. Yes I was told that it isn't available yet for consumers. I am wondering since it has the word "visual" in it, does that mean it won't be able to go room to room like sound/radio waves? You would have to be close to the source as well??? Link to comment Share on other sites More sharing options...
docj Posted November 25, 2015 Report Share Posted November 25, 2015 There's nothing new about modulating light waves to transmit information--that's how fiber optic cables work. If you read the Wikipedia article on LiFi you will see that it is primarily being directed at applications where radio frequency interference is a concern. https://en.wikipedia.org/wiki/Li-Fi Since radio waves can go through many materials that light cannot and since light waves are more heavily attentuated by the atomosphere than are most radio frequencies, it is unlikely that any visible light-based system would ever be serious competition for conventional wifi. The higher bandwidth capability of Lifi is a function of the higher frequency of the "carrier", but it is more than offset by these other limitations. Link to comment Share on other sites More sharing options...
Yarome Posted November 25, 2015 Report Share Posted November 25, 2015 does that mean it won't be able to go room to room like sound/radio waves? You would have to be close to the source as well??? Exactly. Well.. to some extent. Light does bounce. It's been a few months since I did any reading on it, but if I recall correctly, they were saying something to the effect that if the transmitter is placed correctly, they were still able to achieve 70% strength of signal down a 15' hallway from an adjacent room. I can see the benefit where radio interference might be a concern.. or in mass transit applications like in aircraft, but in my lifetime I don't see it becoming an end user technology. Link to comment Share on other sites More sharing options...
KRum Posted November 25, 2015 Report Share Posted November 25, 2015 I am sure it will require us to purchase some sort of $4-500 device that requires another hole be drilled in the roof of our RV... Link to comment Share on other sites More sharing options...
Yarome Posted November 25, 2015 Report Share Posted November 25, 2015 I am sure it will require us to purchase some sort of $4-500 device that requires another hole be drilled in the roof of our RV... Ain't that always the truth! Link to comment Share on other sites More sharing options...
chuckbear Posted November 25, 2015 Report Share Posted November 25, 2015 The current thinking is that the transmitters will be installed in LED light bulbs and you will be able to populate your home, etc. with these bulbs. You will need a source to get the signal into your home, which will probably be either cable or Wifi. This is still many years from implementation, if at all. Link to comment Share on other sites More sharing options...
RV_ Posted November 26, 2015 Report Share Posted November 26, 2015 It is pretty amazing tech. It can modulate (flash) a single led and carry 100GB on it, and the flashing is too fast for us to see. I'd need to see a consumer or prosumer system before I can get excited. Link to comment Share on other sites More sharing options...
Dutch_12078 Posted November 26, 2015 Report Share Posted November 26, 2015 I think the simplified comparisons would be OTA TV and cable TV, or WiFi and Ethernet, but in the light spectrum. Fiber optic technology without the fiber... Link to comment Share on other sites More sharing options...
chuckbear Posted November 26, 2015 Report Share Posted November 26, 2015 I think the simplified comparisons would be OTA TV and cable TV, or WiFi and Ethernet, but in the light spectrum. Fiber optic technology without the fiber... OTA TV and WiFi will pass through walls, etc. LiFi will not. So the access will still have to be delivered to your home and the LiFi used as a type of router. To pass from one floor of a house or building to another will require the light source to see each other. So there will be limitations. It does not work like a broadcast wifi access point in that regard. Chuck Link to comment Share on other sites More sharing options...
Dutch_12078 Posted November 27, 2015 Report Share Posted November 27, 2015 OTA TV and WiFi will pass through walls, etc. LiFi will not. So the access will still have to be delivered to your home and the LiFi used as a type of router. To pass from one floor of a house or building to another will require the light source to see each other. So there will be limitations. It does not work like a broadcast wifi access point in that regard. Chuck Of course there are fundamental differences and limitations, but my point was to compare the forms of light transmission technology. I think using fiber 'wire' versus free air as the transmission medium has obvious similarities to the lower frequency technologies I mentioned. Then again, using an appropriate laser light source could overcome the wall limitation... Link to comment Share on other sites More sharing options...
