Mark and Dale Bruss Posted November 24, 2015 Report Share Posted November 24, 2015 Only if you have differential locks and they are engaged. The differentials allow just the opposite of what you describe as happening > differential speed of the inner and outer wheel sets. There is no differential between dual wheels. They are bolted together. A differential allows wheels on the opposite end of an axle to turn different speeds and directions.. Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted November 24, 2015 Report Share Posted November 24, 2015 Glen- PM sent. Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
NoDirectionHome Posted November 24, 2015 Report Share Posted November 24, 2015 Mark, I didn't understand you were speaking of the wheels on the same side if the vehicle. The example you describe is the same for any vehicle though, whether dual wheels or single. There is always tire scrub unless the tire tread is round like a bicycle and hard enough to not deform under load. "There are No Experts, Do the Math!" 2014 Freightliner Cascadia DD16 600hp 1850ft-lb 18spd 3.31 260"wb SpaceCraft S-470 SKP #131740 Link to comment Share on other sites More sharing options...
noteven Posted November 24, 2015 Report Share Posted November 24, 2015 A power divider is a differential between two axles and power is going to both axles when both have traction. Locking out the power divider locks both axles together front to back. Using axle diff locks lock the axle shafts and wheels together side to side. Lightly loaded tandem drive axle trucks tend to pivot on the front drive axle and scuff the rear axle in a turn. "Are we there yet?" asked no motorcycle rider, ever. Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted November 24, 2015 Report Share Posted November 24, 2015 Mark, I didn't understand you were speaking of the wheels on the same side if the vehicle. The example you describe is the same for any vehicle though, whether dual wheels or single. There is always tire scrub unless the tire tread is round like a bicycle and hard enough to not deform under load. Single wheels might scuff sideways in a turn. With duals, one the tire is scuffing in the rotational direction. There are those who beileve that a tandem dual trailer (Newmar) has less tire scrub that a triple axle single. The tandem duals will have 4 tires scrubbing (assuming a pivot in the center of the tandems) wna d the triple axle will hve four scrubbing Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
