alan0043 Posted November 3, 2015 Report Share Posted November 3, 2015 Hi Everyone, I need to add a siphon hose to my trailer so I can winterize the trailer. I would like to use the same style of fittings that are on the trailer to do this job. Can I get these fittings at the big box stores or do I need to go to a rv dealer ? What type or style of shut off valve is needed ? I don't want this job looking like some after thought. I want to look as much as factory as possible. Thank you for any help, Al Link to comment Share on other sites More sharing options...
Chalkie Posted November 3, 2015 Report Share Posted November 3, 2015 I am presuming you want this so you can put the pink stuff in the water lines? You can get a reasonably priced kit like this: http://smile.amazon.com/Valterra-P23506LFVP-Lead-Free-Converter/dp/B00HSNYWTW/ref=sr_1_5?ie=UTF8&qid=1446563719&sr=8-5&keywords=rv+winterizing+kit Our fiver was already set up for winterizing from the factory. I did that one year and come warmer weather it seemed it took forever to get all the color, and taste, out of the water lines. A friend suggested a better alternative. Blowing the lines clear with compressed air. After getting the lines just blowing air, I then open the low point drains. No need to flush the lines when you want to use the camper next. I only put the pink stuff in the P-traps and a little in the holding tanks (which I always empty before winter). Link to comment Share on other sites More sharing options...
