Inverter Trouble Shooting
Full timing for just about a year now and the Xantrex PRO Inverter has gone into the red light fault mode but with no error codes just three red dashes in the screen. Is there a fuse to check or rest button? Nothing in the manual covers this situation without an error code message on the inverter screen. Nothing on the Xantrex web site addresses this and there is no tech support I have found
We also have a USB charging station on the front dash panel that is not working either so not sure if the two are related or where to find a fuse for that on the motorhome as nothing specifically states anything for either one in the fuse section of the owners manual
Do the usual steps. Check the breaker on the inverter itself. If it has a reset button, use it. Turn the inverter and converteroff at the control panned, if you can, and then turn the house batteries off. Wait a few minutes and turn the batteries back on and see if that either fixes it or produces and error code.
RV Cable Grip
RV Cable Grip
RV Air.
