rving4us Posted October 14, 2015 Report Share Posted October 14, 2015 After 40 yrs of rving, the full time life still poses questions so please bear with me. The DW notices moisture in the fridge on the door shelves. ( none on the walls of the fridge) Here is the scenario. The AC is set to 75 degrees the fridge is set to 7 out of 9 possible, inside the fridge is good at 40 degrees. Ambient temp is 50 to 60 at night and 70 to 80 during the day. Here in SC the humidity is about 75% right now. Why is there moisture on the shelves? PS the fridge was defrosted about 10 days ago so no frost build up. Thanks in advance for your help. Cary 2014 Ram,4x4,dually,CC Cummins 2011 Carriage Cameo 37KS3 full body paint, Most options except Generator SKP# 123923 Link to comment Share on other sites More sharing options...
Kirk W Posted October 14, 2015 Report Share Posted October 14, 2015 Absorption refrigerators such as those in most RVs have no defrosting features and so moisture entering via ambient air entry when the door is opened is a bigger problem. In addition, a leaking door seal may make the problem much worse. The best way to test that door seal is to place a dollar bill into the open door, close it and then see how much force is required to pull if from the closed door. It should require a very definite amount of pressure to pull the bill out, but not be impossible. Make the test every few inches around the door to check all areas of the seal. If the seal is weak, it will allow more air intrusion and thus more moisture. In hot weather it can also impact the ability of the refrigerator to remain at proper temperatures. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
HamRad Posted October 14, 2015 Report Share Posted October 14, 2015 Cary, It sounds to me like you may have some leakage at the door seals. That could account for the moisture on the door shelves. Dennis Trailer: Montana 5th wheel, model 3582Rl, model year 2012 Truck: Ford 450 PSD Super Duty, 2002 Crew Cab, Long bed, 4:88 rear end, last of the 7.3 engines, Automatic Transmission. Link to comment Share on other sites More sharing options...
Barbaraok Posted October 14, 2015 Report Share Posted October 14, 2015 Make sure you scrub around the seals, sometimes a little bit of food or mold can get in a crevice and not be noticeable but can affect the seal. Then after you have scrubbed, go ahead and use a hair dryer on low to warm the seal so that it is VERY pliable and then close the door firmly. That will help the seal to reset itself. That might be all you need to do. But in really humid weather, there is no way to keep all moisture out of the fridge. Barb Barb & Dave O'Keeffe 2002 Alpine 36 MDDS (Figment II), 2018 Ford C-Max HYBRID Blog: http://www.barbanddave.net SPK# 90761 FMCA #F337834 Link to comment Share on other sites More sharing options...
Mariner Posted October 14, 2015 Report Share Posted October 14, 2015 Also check to see that the drain tube outside has a trap in it(a bend). Outside air can get in that way also. Fulltiming since 2010 2000 Dutch Star 2009 Saturn Vue Myrtle Beach, SC Link to comment Share on other sites More sharing options...
shaman52 Posted October 16, 2015 Report Share Posted October 16, 2015 Kirk, Check out the Dometic NDR 1402 absorption refrigerator. It has defrost cycle. Only one I know that does. X2 dollar bill test. Link to comment Share on other sites More sharing options...
Yarome Posted October 16, 2015 Report Share Posted October 16, 2015 You might consider adding a fan. It's fairly inexpensive, cuts down on the frost and moisture and helps the overall efficiency. Link to comment Share on other sites More sharing options...
kinseypw Posted October 19, 2015 Report Share Posted October 19, 2015 We have defrosted our dometic RM2852 twice in the last year. Fridge and freezer are usually pretty full. Is this a lot? Link to comment Share on other sites More sharing options...
