whatsnext Posted September 29, 2015 Author Report Share Posted September 29, 2015 After much discussion with Larry and Mor-Ryde, we are going to raise the hitch and possibly move it back an inch or two then cut the extra length of bracket extending below to make it flush with the pin box extension arm. This will clear everything and maintain strength integrity. Thanks to everyone for your input. It was a huge help. David 2016 Volvo VNL780 D13 I-Shift 2016 DRV 44 Houston 2015 Smart Cabriolet Link to comment Share on other sites More sharing options...
Jim & Wilma Posted September 29, 2015 Report Share Posted September 29, 2015 David, That's great to hear you have a good plan forward. Larry also called me today asking if I was having any problems. I'll be hitching up this weekend and checking everything out but my pin box is different and I expect to have plenty of clearance. I'll give it to Larry for reaching out to me, I know he has great pride in their work and wants to make it right. Jim Jim & Wilma 2006 Travel Supreme 36RLQSO 2009 Volvo VNL730, D13, I-shift, ET, Herrin Hauler bed, "Ruby" 2017 Smart Class of 2017 Link to comment Share on other sites More sharing options...
Jack Mayer Posted September 29, 2015 Report Share Posted September 29, 2015 Call Moreryde for the specs on the pinbox, save time. Jack, could you please provide the link to your deck build file. I want to see about relocating my generator to the void behind the rear end. Thanks HERE is the link to the RV build. There you will see the genset location (for others interest.). It is behind the axles under the livingroom. And HERE are the truck bed build pictures....No genset on the truck though.... Jack & Danielle Mayer #60376 Lifetime Member Living on the road since 2000PLEASE no PM's. Email me. jackdanmayer AT gmail 2016 DRV Houston 44' 5er (we still have it) 2022 New Horizons 43' 5er 2016 Itasca 27N 28' motorhome 2019 Volvo 860, D13 455/1850, 236" wb, I-Shift, battery-based APU No truck at the moment - we use one of our demo units 2016 smart Passion, piggyback on the truck -------------------------------------------------------------------------See our website for info on New Horizons 5th wheels, HDTs as tow vehicles, communications on the road, and use of solar powerwww.jackdanmayer.com Principal in RVH Lifestyles. RVH-Lifestyles.com Link to comment Share on other sites More sharing options...
rdickinson Posted September 29, 2015 Report Share Posted September 29, 2015 Thanks for the links. I took some measurements and will see if mounting the 7kw genset behind the rear end will work. There is enough room, more an issue of how to get it out for service on a slideout. This would also deaden some of the noise. It would need part of the transom of the truck to swing open or pull out and then there is all the attached wiring. Link to comment Share on other sites More sharing options...
