Yarome Posted September 16, 2015 Report Share Posted September 16, 2015 I tried to do a little research off and on, but it's never amounted to much. I'll toss it out to the experts and see what ideas you might have. This isn't my rig, but it's the same make, and the entertainment center, room division, and bed placement are the same. My issue: The TV 'box' rotates so that it can be viewed from either the bedroom or the main living space. Note that the movie player is mounted into the cabinet above the TV and facing the main living space. My Satellite receiver is mounted such that, from the bedroom, the remote control works great, but not so much in the living space. Conversely... if I want to watch a movie, the remote will only work in the living area and not at all from the bedroom. What I would like to do is install some type of IR sensor or other type mod that would allow their remotes to work from either living space. The only thing I've been able to come up with front internet searches so far is a UHF receiver/transmitter/IR transmitter set-up, but it isn't at all practical to mount IR transmitters to the face of the movie player or satellite receiver, and I don't really want to have a hard wired power solution. Many a moon ago, I had purchased a stereo system that came with a battery powered button sized IR sensor on a 2' wire that you could place anywhere you wanted, and the other end simply sticky taped over the existing units sensor. I can't seem to find anything like that anymore though. My low cost/ugly thought was maybe just using those small convex mirrors (like 'blindspot' stick on your auto side mirrors type) and mounting them. I can't imagine that would be too attractive, but the only thing I've been able to think of short of a gobbledygook UHF unit. Ideas solicited. Link to comment Share on other sites More sharing options...
edatlanta Posted September 16, 2015 Report Share Posted September 16, 2015 Depending on which sat receiver you have, you might be able to switch the remote from IR mode to RF mode. If your receiver will do this your problem should be solved. Ed KM4STL2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch2010 Jayco Designer 35RLTS, RV Flex Armor Roof Link to comment Share on other sites More sharing options...
Yarome Posted September 16, 2015 Author Report Share Posted September 16, 2015 you might be able to switch the remote from IR mode to RF mode. I would have never thought to even check for that. Great information to keep in the ol memory bank. Unfortunately, both remotes (satellite, movie player) are IR only, and the only receivers compatible with my tailgater are not RF capable. Thanks for that tidbit though. Link to comment Share on other sites More sharing options...
Tex Bigfoot Posted September 16, 2015 Report Share Posted September 16, 2015 How big is your TV , does it fill the space for it completely? if not maybe there is room above or below it to mount the Sat box and let it rotate with the TV? I'm only going by the picture so you may not have space. Link to comment Share on other sites More sharing options...
MNRon Posted September 16, 2015 Report Share Posted September 16, 2015 There are ir repeaters like you're looking for. Here's one http://www.rockler.com/channel-vision-all-in-one-ir-system I'm sure you can find others as well. Ron and Pat, and 2 Portuguese Water Dogs 2013 Silverado 3500 SRW Duramax w/SuperGlide 2005 NuWa HitchHiker DA 31.5 LK w/MorRyde IS Link to comment Share on other sites More sharing options...
Yarome Posted September 16, 2015 Author Report Share Posted September 16, 2015 MNRon.. Thank you!! Problem solved. When I had looked in the past I had been searching on remote IR sensors/receivers/transmitters and the like. Pulling up "IR repeater" came up with a whole bevy. I even found a couple of battery operated repeaters that will fit the bill. Much thanks for that! When all else fails.. ask the experts. Link to comment Share on other sites More sharing options...
