Charles Skinner Posted September 10, 2015 Report Share Posted September 10, 2015 Please review me on how to "clean out" your fresh water tank and make it safe. How much bleach for a 50 gallon tank? Do you run it through the hot water heater, or do you close off the hot water tank? C. S. Link to comment Share on other sites More sharing options...
Yarome Posted September 10, 2015 Report Share Posted September 10, 2015 You'll want to run it through your water heater as well. You'll need just under 1 cup of bleach for 50 gallons (1/4 cup/15 gallons). Your FW tank might hold 50 gallons, but don't forget the couple gallons in your pipes and whatever size water heater you have. That's in addition to your tanks capacity. Don't forget to run your outdoor faucet or other fixtures if so equipped... low point drains, etc. Link to comment Share on other sites More sharing options...
wildmandmc Posted September 10, 2015 Report Share Posted September 10, 2015 taking it out for a quick ride to swish the water all over inside . helps. 2000 Itasca Horizon DP (Got Total During Irma). Vice President of Charlotte County Defenders LE MC http://charlotte.defenderslemc.com/ Link to comment Share on other sites More sharing options...
Zulu Posted September 12, 2015 Report Share Posted September 12, 2015 You'll need just under 1 cup of bleach for 50 gallons (1/4 cup/15 gallons). Also, the 1/4 cup per 15 gallon should sit for at least 4 hours. You can double that (so 1/2 cup bleach per 15 gallon) and let it sit for just 1 hour. SKP #79313 / Full-Timing / 2001 National RV Sea View / 2008 Jeep Wrangler Rubiconwww.rvSeniorMoments.comDISH TV for RVs Link to comment Share on other sites More sharing options...
Yarome Posted September 12, 2015 Report Share Posted September 12, 2015 Also, the 1/4 cup per 15 gallon should sit for at least 4 hours. Absolutely! But overnight would be better. Link to comment Share on other sites More sharing options...
Ray,IN Posted September 14, 2015 Report Share Posted September 14, 2015 The sanitization/disinfection time is usually like this: a 10% bleach solution requires 30 minutes for complete disinfection. The rule of thumb for water piping is: if you open a faucet and smell bleach after 30 minutes of contact time, disinfection is complete. If there is not a residual level of chlorine in water, disinfection may not be complete. Organic matter lengthens disinfection time.http://ndep.nv.gov/bsdw/docs/disinfect_drinking_water.pdf 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Zulu Posted September 14, 2015 Report Share Posted September 14, 2015 The sanitization/disinfection time is usually like this: a 10% bleach solution requires 30 minutes for complete disinfection. The rule of thumb for water piping is: if you open a faucet and smell bleach after 30 minutes of contact time, disinfection is complete. If there is not a residual level of chlorine in water, disinfection may not be complete. Organic matter lengthens disinfection time.http://ndep.nv.gov/bsdw/docs/disinfect_drinking_water.pdf I don't know where you're getting these numbers from but the 1/4 cup or 1/2 cup of bleach per 15 gallons thing is part of the NFPA 1192 Standard on Recreational Vehicles which has been around since 1937. BTW, this standard describes how to disinfect the water tank -- not the water itself (as in your PDF link) -- as the OP wanted. SKP #79313 / Full-Timing / 2001 National RV Sea View / 2008 Jeep Wrangler Rubiconwww.rvSeniorMoments.comDISH TV for RVs Link to comment Share on other sites More sharing options...
Ray,IN Posted September 15, 2015 Report Share Posted September 15, 2015 Zulu, here is my reference: http://oregonstate.edu/dept/larc/sites/default/files/pdf/chlorine-fact-sheet.pdf 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Zulu Posted September 15, 2015 Report Share Posted September 15, 2015 Zulu, here is my reference: http://oregonstate.edu/dept/larc/sites/default/files/pdf/chlorine-fact-sheet.pdf Ok, but this still appears to apply to disinfecting solutions (i.e. water itself) and not surfaces like a water tank. Here's a link to hard surface disinfectants -- notice that the "dwell time" for bleach is listed as 10 minutes, but that assumes you have already cleaned the surface. However, since there's no practical wash to pre-clean your RV's water tank, the dwell time was boosted to 4 hours (or 1 hour for a more concentrated bleach solution). SKP #79313 / Full-Timing / 2001 National RV Sea View / 2008 Jeep Wrangler Rubiconwww.rvSeniorMoments.comDISH TV for RVs Link to comment Share on other sites More sharing options...
Ray,IN Posted September 16, 2015 Report Share Posted September 16, 2015 Ok, but this still appears to apply to disinfecting solutions (i.e. water itself) and not surfaces like a water tank. Here's a link to hard surface disinfectants -- notice that the "dwell time" for bleach is listed as 10 minutes, but that assumes you have already cleaned the surface. However, since there's no practical wash to pre-clean your RV's water tank, the dwell time was boosted to 4 hours (or 1 hour for a more concentrated bleach solution). That pertains to school cafeterias, which as we both know is an entirely different setting. We can agree to disagree, neither way is wrong. Back to regular programming/subject. This link explains the usual way to sanitize an RV plumbing system, and if necessary, how to cleanse it of algae and slime prior to sanitizing. I prefer to use Sodium Dichlor for sanitizing plumbing and disinfecting drinking water from an unknown source. That said, with regular use, an RV plumbing system should not require sanitizing unless water of unknown quality is used (creek, lake, river, etc). 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
