Wifiranger with tethered Mifi
Roy & Ann
I have a Go2 with a tethered PANTECH MHS291LVW which I leave on 24/7. The problem I am encountering is the battery is burning out because the tether is constantly charging the Pantech. I tried to remove the battery, but the Pantech will not work without the battery.
Anyone have a solution to this problem?
I have had the same problem and as documented in a couple of previous topics on the subject so have a couple of others. The only solution I found was to buy a supply of replacement batteries from Amazon, unhook the mifi and connect to it by wifi when the speed was acceptable, and try to use the Sleek only when absolutely necessary.
Yes.. we are finding that overtime the MHS291L definitely has battery issues. Here's our overview of the device: The Pantech MHS291L – MiFi / Jetpack Review
If you're running it right next to a booster, especially in a Cradle booster like the Sleek / 4G-S - it's even more compounded with the heat generated. Here's our tips for helping with that situation: Preventing Mobile Hotspot Battery Swelling when Using a Cradle Booster
Some of our members found a hack around it to run the MiFi without the battery installed.. and wrote a member-only step-by-step guide for our RVMobileInternet community. It can be found on our resource center.
- Cherie
- Cherier
The cradle booster is not the problem. I have one but don't use it so it is not powered on. I keep an air gap anyway.
I did joined your web site and I will try the hack once a new battery arrives. The hack looks like it may be the answer.
Thanks
Roy
