Upgraded to windows 10, now icons gone
Roy & Ann
I have an hp laptop that was running 8.1 with all the updates. Since I have 3 laptops to upgrade. I down loaded windows 10 to a USB drive.
The upgrade seems to have gone fine with one exception. On the task bar all of the program icons I had, are gone. If I try to Pin to Task bar, The icon moves to task bar and disappears.
Tried to "google" the problem, but cannot see anything that matches my problem.
Any experts have any suggestions?
Roy
2005 New Horizons 36ft 5th/upgrades-Generator, Disk Brakes, Solar Package, Inverter. and more
2008 Ford F450 crew cab DRW
K3ROY
http://www.roanontheroad.blogspot.com/
I have no answer. But, can you add to the Start Menu?
One thing I found, perhaps you have your laptop in Tablet Mode. Tablet Mode changes the desktop layout. Look in Settings / System / Tablet
Mark & Dale
www.dmbruss.com
The icons are in the start Menu.
Yes, I checked it is not in the Tablet mode.
K3ROY
Has your screen size oversized your physical screen size? This has happened to a few because of default display drivers. Typically, try to change your screen resolution and see if you have many choices or just the generic ones. If you only have the generic resolutions listed then you probably need to get an updated video chip driver. Windows update should eventually get you on their WHQL video driver for your video chipset but you may want more control than that one will give you.
NVIDIA has new win 10 drivers if you have an NVIDIA video chip.
Just athought.
RVBuddys Journal Our progress into full-timing.
Budd & Merrily ===-> SKP# 088936 Other Websites:---> Hub of all my blogs
Clifford - 2000 VNL64T770 :: DakotR - 1999 C40KS King of the Road :: $PRITE - 2013 Smart Passion w/cruise
RV/Derek
Retired AF 1971-1998
I fixed it. The problem was a program I installed on the 8.1 computer to simulate the start menu. Stardock, Start8. Once I removed the program the Icons appeared. Now It seems to operate normally.
Thanks for all you help, guys
Roy
K3ROY
Wow,
If you'd mentioned you'd used a desktop altering program . . . ;)
RV/Derek
