Sekenajankow Posted September 1, 2015 Report Share Posted September 1, 2015 Our satellite continues to search for a signal. When it does finally stop it points the way. Don't know if it's bad or if it's the "brain" inside . Don't really want to buy a new one. They start at 1100.00. Please help Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted September 1, 2015 Report Share Posted September 1, 2015 Not enough information. I assume this is a Winegard Trav'ler. Have you checked for tree interference? Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
Dale P Posted September 25, 2015 Report Share Posted September 25, 2015 Call Winegard Support and discuss with them Susan & Dale DaGirls Rv 2008 Alfa Gold SoLong ISL 425 Cummins 2015 Ford F-150 XLT Tow / Roadmaster Setup 1600W@45Vdc Magnum Inv/Chg&Solar880AmpHrDaGirlsRv Blog Link to comment Share on other sites More sharing options...
LindaH Posted September 25, 2015 Report Share Posted September 25, 2015 Winegard makes several different types of satellite TV dishes, from domes (both roof-installed and portable) to the open-faced Trav'ler. Let us know specifically which one you have for more help. But Dale's advice to call Winegard is good. LindaH 2014 Winnebago Aspect 27K 2011 Kia Soul Link to comment Share on other sites More sharing options...
MNRon Posted October 22, 2015 Report Share Posted October 22, 2015 Ditto the recommendation to call Winegard tech support. We have a roof mount manual dish that I couldn't get to connect. Winegard tech services did a great job of stepping me through what needed to be done! Ron and Pat, and 2 Portuguese Water Dogs 2013 Silverado 3500 SRW Duramax w/SuperGlide 2005 NuWa HitchHiker DA 31.5 LK w/MorRyde IS Link to comment Share on other sites More sharing options...
Mariner Posted October 22, 2015 Report Share Posted October 22, 2015 Why do people post a question(8/31) and never respond? Baffles me. Fulltiming since 2010 2000 Dutch Star 2009 Saturn Vue Myrtle Beach, SC Link to comment Share on other sites More sharing options...
teacher's pet Posted October 22, 2015 Report Share Posted October 22, 2015 Had a similar problem with our Trav'ler. Switched cable A with cable C at the base. system came back for about a year. Some here had said it was the LNB, which I bought, then found out about the cable switch before it arrived. Kept the LNB as back up, when the Trav'ler failed this year, switched out the LNB. No change in operation. Talked to Winegard tech support..suggested as a last option before shipping to them to change the "sheathed cable" between the base and LNB. Worked and has worked now for about two months. I have also relocated the A and C cables at the base to the original connections, since I had to add a 6" piece of coax to reached one of the connection. Teacher's Pet '06 40' Phaeton QSH 350 Cat. '04 R-Vision B+ Model 213, 6.0 Chevrolet. http://www.skoolzoutforever.blogspot.com http://map.datastormusers.com/user3.cfm?user=3912 Link to comment Share on other sites More sharing options...
