singling question
GlennWest
Yes, it's rather strait forward. We once did this this with our race cars. Didn't have a lathe but ours always turned out good. Been welding all my life and making joints straight. And with a tig rig if it comes out with run out I can draw it back straight.
Thanks but I know how to align a axle. The springs are the same, front and rear, on an 05, right?
No they are not. On the Gen I's they are the same but early Gen II's (starting '04) they are different. Do not use the rear Z springs when moving that axle forward. Using the rear springs in the power divider position will cause the pinion angle to be >10 degrees up.
Can't seem to get this right tonight. Posting doesn't want to work with above attachment or thumbnail. Anyway, IMHO, the most important part is having a pro shop build the drive shaft and balance it as well. The attachment (above, I think) is the bill for the drive shaft.
I will have to do driveshaft myself. I may scrap it and pay someone later but I weld for a living and always making straight joints. Can't see paying for this.
Be careful, Glenn. The deal is not just the welding - trueness can only be accomplished on a lathe. Balancing is important. Imbalance can ruin bearings in diff and u-joint costing much more later.
Not sure about the stock driveline you have but often to the naked eye it looks like the u-joint eyes are indexed zero-zero but often they are indexed slightly offset so that the joints do not toggle high or low at the exact moment during a rotation cycle.
Once in a while our local balance shop is called in to balance a straight zero-zero index driveline and it can't be balanced because it is a joint-toggle condition not a balance problem.
Drive lines can be simple.......and.......not so simple.......
In my abused childhood we had too many drive lines on too many log trucks and washboard roads would hammer the slip-sleeves hard so we had to install new slip-sleeves fairly often so it is important to look hard at the original drive line configuration before waking it apart........once you cobble one together wrong it gets ugly fast........(don't ask......I won't tell)......... Truck drive lines have high mass and they can be a pain when they are........a pain.......
Drive on..........(Drive line.......smooth....)
Glenn,
I have a 2004 630 singled to the front position. My WB is now 218". I left the frame the original length so I have a pretty big bed and lots of storage under it. I had it done in Canada before I brought it home so I do not know what they did for sure. What axle is on the truck. I carry a Smart on mine but I have the 14.6K axle so I have no weight problems.
Brad
