Alie&Jim's Carrilite Posted August 30, 2015 Report Share Posted August 30, 2015 Considering ordering a set of Centramatics for the truck. The old tires have Dynabeads in them and haven't had any issues with the TST sensors. Cost of the Dynabeads is about half of the Centramatics, but if you need to change a tire, you loose the beads. Centramatics stay with the truck. Suggestions? Besides making sure the tires are road force balanced to begin with.... Link to comment Share on other sites More sharing options...
Ronbo Posted August 30, 2015 Report Share Posted August 30, 2015 Balance masters has lifetime warranty Link to comment Share on other sites More sharing options...
Randyretired Posted August 30, 2015 Report Share Posted August 30, 2015 We have Centramatics on our HDT. It had a slight vibration and I thought maybe the Centramatics would help. It turned out to be a front tire that was bad but there still on the truck. The truck is smooth and no vibration so the Centramatics haven't hurt anything. We just through a pack of Equal in the tires along with the Centramatics and it rides and drives fine. Very smooth. Link to comment Share on other sites More sharing options...
sdixon747 Posted August 31, 2015 Report Share Posted August 31, 2015 I recently put new tires on my truck. Also put Centramatics on all 3 axles. Truck is noticeably smoother. Is it the tires, the Centramatics, or a bit of both? Probably a bit of both, but it is definitely smoother. Steve Link to comment Share on other sites More sharing options...
heavyduty Posted August 31, 2015 Report Share Posted August 31, 2015 Just noticed your post on balance issue. I have a similar problem. Have just had new michelin steer tires put on. Have a issue between 40 and 50 mph a slight bounce that leaves at higher speeds. I have taken it back to tire dealer twice for spin balance but it is still there. I was wandering about balance beads or something in that nature. What do you all think Link to comment Share on other sites More sharing options...
Ronbo Posted August 31, 2015 Report Share Posted August 31, 2015 I have balance masters on front and beads in all 10. Much smoother after beads were added. Better than wheel weights Link to comment Share on other sites More sharing options...
orca Posted August 31, 2015 Report Share Posted August 31, 2015 A trucker friend who runs almost 4000 a week and mounts his own tires uses what he calls centering collars. These fit on 3 wheel studs and take up the slight space between the rim and the stud which centers the rim to the studs. He then tightens nuts on the studs that have no collars and then removes the collars and installs the remaining nuts. This procedure ensures that there is 0 runout as the wheel turns. 0 runout + balance beads = smooth ride and long life. I watched a tire installer use the eyeball and chalk method to check runout on a new set of tires on my MH. It worked but nowhere near as accurate as those collars. Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted August 31, 2015 Author Report Share Posted August 31, 2015 Nice idea, just found these. Great idea. I might just do these and the Dynabeads on the new to be rears. https://www.nytechsupply.com/tru-balance-centering-products.htm Link to comment Share on other sites More sharing options...
Big5er Posted August 31, 2015 Report Share Posted August 31, 2015 I have never heard anyone complain about Centrarmatics, so I put them on the rear when I replaced the drive tires. So far I like tham. I will add a set to the steer axle when I replace those tires. Link to comment Share on other sites More sharing options...
beyerjf Posted September 1, 2015 Report Share Posted September 1, 2015 Centering while mounting as mentioned above is a good idea, though rarely done. I credit the centimatics I have on here for extending tge life of the front tires from an average of 100k miles to something over 135k miles. Balancing with weights is largely ineffective unless done several times during the life of the tire, negating any savings. No OEM truck manufacturer balances any tires at the factory. That is their take on the topic. Link to comment Share on other sites More sharing options...
RandyA Posted September 2, 2015 Report Share Posted September 2, 2015 Ditto on the Centrarmatics. I have them front and rear and believe they are working well. No vibration from tires at any speed. Getting good steer tire wear. Also new shocks, welded spring eye pins, Safe-T-Plus and tie rod ends with alignment. Link to comment Share on other sites More sharing options...
Hewhoknowslittle Posted September 3, 2015 Report Share Posted September 3, 2015 Jeff, I have them on my Goldwing, my LGT one ton truck and my Volvo now, and they work!! Just do it, you will injoy it.!! Roger Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted September 26, 2015 Author Report Share Posted September 26, 2015 Centramatics are on! Ride is smoother, steering wheel is absolutely dead, no vibration at all, its just like holding the wheel at a stop. There were DynaBeads in the old tires, either the new tires are more balanced from the factory, Or the Centramatics are great! Link to comment Share on other sites More sharing options...
Big5er Posted September 26, 2015 Report Share Posted September 26, 2015 Thanks for the info Jim. I installed them on the rears when I replaced the tires last month. I may buy a set for the front soon. I currently have beads in the front. Link to comment Share on other sites More sharing options...
Guest THE TRAILERKING Posted September 27, 2015 Report Share Posted September 27, 2015 A lot do the beads now a days.... Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted September 27, 2015 Author Report Share Posted September 27, 2015 A lot do the beads now a days.... I've had the Dyna beads in both dually pickups and in motorcycles and they do work. Just not well enough for me in the Volvo. In the past, if I have any vibration in the steering wheel I hunt for the issue, either tires, alignment, front end rebuild, suspension, whatever. I traded a 2006 Z06 vette that would develop a vibration at 95-100mph and not leave until over 150mph (track only) . The dealer and I replaced everything on the car, tires, rims-balanced by themselves, all the steering from the steering wheel to the road, suspension everything. They finally gave me a great trade in on another year model.. Link to comment Share on other sites More sharing options...
Darkhorse Posted September 27, 2015 Report Share Posted September 27, 2015 I have had Centramatics on my Dodge 1 ton for many years when I put 19.5" wheels on, they have been great. Link to comment Share on other sites More sharing options...
Gary Hage Posted September 27, 2015 Report Share Posted September 27, 2015 We ran the centramatics on all axles of our commercial trucks and trailers for years. Our tread life on both drives and steers on the tractor, plus axles of the trailer far exceeded that of our friends that ran without them hauling similar freight with similar equipment. The set of cetramatics that we sold with the commercial truck and trailer this past March are still in use and performing as they were designed to do. They had been moved from the T/T we owned before the most recent one, and had just shy of two million miles on them when we sold it. Best more we ever spent!!! Link to comment Share on other sites More sharing options...
Big5er Posted September 27, 2015 Report Share Posted September 27, 2015 One issue with dyna beads, although cheaper, is that they recommend a special valve stem if you run a TPMS that screws onto the valve stem. Link to comment Share on other sites More sharing options...
Ronbo Posted September 27, 2015 Report Share Posted September 27, 2015 When they mounted my rears and put it beads, it came with the special valve stem. Link to comment Share on other sites More sharing options...
Big5er Posted September 27, 2015 Report Share Posted September 27, 2015 Ron, is that just a different valve core or a whole new valve stem? Link to comment Share on other sites More sharing options...
hone eagle Posted September 27, 2015 Report Share Posted September 27, 2015 I had the beads ........and a small vibration at 50 mph .. and they got into the tpm , so centramatics went on and both problems solved. Link to comment Share on other sites More sharing options...
CrazyCooter Posted September 28, 2015 Report Share Posted September 28, 2015 I have used beads in many different vehicles with hit/miss which ended up not so great results overall. Most of the time vibrations would come and go for no reasons. My truck has Centramatics on it and it is perfectly smooth over 100 mph. Link to comment Share on other sites More sharing options...
Ronbo Posted September 28, 2015 Report Share Posted September 28, 2015 Same stem, different core and cap Link to comment Share on other sites More sharing options...
JC and Angie Posted September 28, 2015 Report Share Posted September 28, 2015 Where's the best place to buy these tire balancing wonders ???? JC Link to comment Share on other sites More sharing options...
