chuckbear Posted August 26, 2015 Report Share Posted August 26, 2015 Do most of you put your levelers down when the coach is not in use, either at home or in a storage facility? Or do you not use them when not in a campground? Chuck Chuck and Susan 1999 Fleetwood Bounder 34 Triton V10 on Ford Chassis Link to comment Share on other sites More sharing options...
pjstough Posted August 26, 2015 Report Share Posted August 26, 2015 Before we started full timing we left the levelers up when we were not using the RV. 2005 Winnebago Voyage 38J Link to comment Share on other sites More sharing options...
Jimalberta Posted August 26, 2015 Report Share Posted August 26, 2015 I rarely use my levelers. If its on a level site I just dump the air. This includes when we are not using it. <p>....JIM and LINDA......2001 American Eagle 40 '.towing a GMC Sierra 1500 4X4 with RZR in the rear. 1999 JEEP Cherokee that we tow as well. IT IS A CONTENTED MAN WHO CAN APPRECIATE THE SCENERY ALONG A DETOUR. Link to comment Share on other sites More sharing options...
Kirk W Posted August 27, 2015 Report Share Posted August 27, 2015 If you can park the RV and sit on the levelers for several months when living in it, why would it harm anything to do that same thing in storage since the only difference is that it won't have as much weight in it? Leveling jacks are designed to hold the RV up and there should be no problem in leaving weight on them for months at a time, as long as the jacks are in good repair. Our coach sat on the jacks without moving for as much as 4 months with no ill effects when on the road and when we bought the home-base and Pam had surgery it sat for 5 months without moving, on the jacks. You should still put something between the tires and the surface to prevent any moisture intrusion, and especially so if sitting on concrete as the acids of the concrete can damage the steel belts in the tires. I never took 100% of the weight off of the suspension as the chassis manufacturer recommended against that, but I did lift it enough to remove significant weight. In that way if the tires should go low it will do far less harm than it would if sitting on them. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
wildmandmc Posted August 27, 2015 Report Share Posted August 27, 2015 while in back yard jacks are up. camping there down. good to use them once in a while, keeps them in working order. 2000 Itasca Horizon DP (Got Total During Irma). Vice President of Charlotte County Defenders LE MC http://charlotte.defenderslemc.com/ Link to comment Share on other sites More sharing options...
Yarome Posted August 27, 2015 Report Share Posted August 27, 2015 Down. It gives your tires a bit of a break, gives a secondary support in the event of slow leak flat, and helps deter theft. When you go out to do your regular checks on the rig just run them up then back down again to keep them 'fresh'. I wouldn't put much more than a 50-60% load on though. It's perfectly fine to leave them up, but looking at the pros and cons.. there aren't really any cons to having them down, and there are some 'potential' pros. Whatever you're comfortable with. Link to comment Share on other sites More sharing options...
Biker56 Posted August 27, 2015 Report Share Posted August 27, 2015 My Jacks have been down for 365 days a year for the last 13 years. For storage of tires Good Year says: Place your vehicle on blocks to remove the weight from the tires. If the vehicle can’t be put on blocks,make sure the storage surface is firm, clean, well-drained and reasonably level. Michelin says: Nothing about weight in storage. When putting the jacks down for storage/long term. Power Gear recommends: If jacks are down for extended periods, it is recommended to spray exposed leveling jack rods with a silicone lubricant every seven days for protection. If your coach is located in a salty environment, it is recommended to spray the rods every 2 to 3 days. I think the spraying needed by PG is too often. IMO Every month or two would be plenty. Full Time since Oct. 199999 Discovery 34Q DP | ISBDatastorm | VMSpc | Co-Pilot Live | Pressure Pro2014 MKS Twin Turbo V6 365 HP Toad Link to comment Share on other sites More sharing options...
Pat & Pete Posted August 27, 2015 Report Share Posted August 27, 2015 I think the spraying needed by PG is too often. IMO Every month or two would be plenty. We've spent the last couple Winters on the Gulf coast . I haven't 'treated' the rods even that often and I see no adverse effect . I make sure that when I do treat the rods , they get a very healthy dose . And , Yes , we have the jacks down for as long as 6 months at a time . Goes around , comes around . Link to comment Share on other sites More sharing options...
hdonlybob Posted August 28, 2015 Report Share Posted August 28, 2015 UP Cheers, Bob 1989 Safari Serengeti 34'Towing a 1952 M38A1 Military Willys Past HDT owner Link to comment Share on other sites More sharing options...
fairway2002 Posted August 31, 2015 Report Share Posted August 31, 2015 Hello I would not level at home. Most driveways (michigan) are 4 inch. Level a pusher on it. you might crack drive. Link to comment Share on other sites More sharing options...
Pat & Pete Posted September 1, 2015 Report Share Posted September 1, 2015 Hello I would not level at home. Most driveways (michigan) are 4 inch. Level a pusher on it. you might crack drive. Drive a pusher on a 4" driveway and you might crack it . Goes around , comes around . Link to comment Share on other sites More sharing options...
