Bob52 Posted August 19, 2015 Report Share Posted August 19, 2015 I found no caulking around my vent pipe just a big gap all the way around it. Caulking is 2 or 3 inches from vent all the way around. Gap looks like it never had any caulking ever. I caulked it with white caulking around pipe but wondered why it never had any before? Thanks. Link to comment Share on other sites More sharing options...
Kirk W Posted August 19, 2015 Report Share Posted August 19, 2015 The problem is that there is supposed to be a cover over it that looks like this one. That cover should then be installed using some butyl caulk tape and then sealed with a bead of caulking to match the roof material that you have. The end of that black pipe should extend up and inside of the cover shown. Link to comment Share on other sites More sharing options...
Guest THE TRAILERKING Posted August 19, 2015 Report Share Posted August 19, 2015 Yes......From his picture it looks like it was there at one time. Maybe got snapped off with a tree limb. Link to comment Share on other sites More sharing options...
budeneighe Posted August 19, 2015 Report Share Posted August 19, 2015 They get brittle quite fast and can be easily shattered after a few years of aging. There are Stainless steel covers, too, for a price. Link to comment Share on other sites More sharing options...
Kirk W Posted August 19, 2015 Report Share Posted August 19, 2015 Budd makes a good point. There are several different choices. All of these can be found on Amazon for prices ranging from $6 for the one in the center to $19 for the metal one, $19 for the wind vane type, and $75 for the one with the solar powered vent fan to blow out. Link to comment Share on other sites More sharing options...
Bob52 Posted August 19, 2015 Author Report Share Posted August 19, 2015 Kirk I will order a white plastic vent from Amazon and other hardware like Happijac 182496 Swing Out Bracke for my 2005 Truck camper. Thanks for the help. Link to comment Share on other sites More sharing options...
Mariner Posted August 20, 2015 Report Share Posted August 20, 2015 Wow. Wonder how long it's been like that out in the elements????? Link to comment Share on other sites More sharing options...
Bob52 Posted August 20, 2015 Author Report Share Posted August 20, 2015 It wasn't long because I found the pipe inside the camper in a wall and didn't have any water damage. I think the past owner lost the cap on way to my house delivering it. He lives 35 milles from me. Link to comment Share on other sites More sharing options...
budeneighe Posted August 20, 2015 Report Share Posted August 20, 2015 If you do not see any screw holes then it is unlikely that it was "lost". One other thing is to be sure that if you have to fill any gaps with caulk, use NON-SELF-LEVELING caulk. Self Leveling caulk will never "set" and will eventually sag into the gap and open it up, again. Link to comment Share on other sites More sharing options...
budeneighe Posted August 20, 2015 Report Share Posted August 20, 2015 Also, be sure to clean all of the existing caulk off before you put the new one on or it will leak. New caulk will not stick to old caulk very well. Just use a heat gun or hair dryer to warm it up and carefully work it up without puncturing the EPDM roofing material. It is not hard to do with a little heat. Then, vigorously scrub the roof with a wire brush where you will fit the cap, Clean it good with alcohol and then caulk it in place. Be sure to completely cover all the screw heads or they will eventually leak, too. Just FYI. Link to comment Share on other sites More sharing options...
Bob52 Posted August 21, 2015 Author Report Share Posted August 21, 2015 The gap didn't have any past caulking at all. Gap was clean. I wonder if it had a rubber seal that worked it way down the pipe into the wall? Cann't see down the pipe about 4 iiches from roof to the top of ceiling in camper. I can see pipe in a closet going down to the kitchen sink. Link to comment Share on other sites More sharing options...
Kirk W Posted August 21, 2015 Report Share Posted August 21, 2015 When you get the new cap, it has a sleeve that the end of that pipe fits into and which holds it in place. Link to comment Share on other sites More sharing options...
skp51443 Posted August 21, 2015 Report Share Posted August 21, 2015 Caulking the pipe to the roof or using a cap that seals the gap can be very important. We saw an RV totaled when they overflowed their black tank out the roof vent and had no seal there. Instead of having a mess and having to wash the outside of the RV they had poop coming out of every crack and crevice in the ceiling. Hopefully you'll never have an overflow issue like they did but it happens. A lesser reason is if you are using a powered vent to blow air out of your RV, if the area around the vent is open you'll be sucking some amount to tank fumes into the rig. Link to comment Share on other sites More sharing options...
