Data useage
Bobq21
Difficult to quantify. What resolution? Is the phone displaying the video? WiFi TV? laptop?
I would run the video via WiFi and note the data transferred. Convert that to data per hour, add a fudge factor and use that to estimate. I would endeavour to have a # for each of the resolutions and devices available. Then I could make informed choices on how to stream.
There are too many variables to predict... what streaming service would it be going through? what resolution? does your carrier do any data compression?
Many of the streaming services give data estimates in their FAQs that can give you a decent ballpark - they can range from 300mb/hr to 7GB/hr . Only way to know for sure is to take a sample data reading and extrapolate.
- Cherie
Media services also dynamically adjust their delivery algorithms to best match the delivery speeds it is sensing. Better delivery profile will deliver higher resolution content and take up more bandwidth/minute. The fewer the skipped frames the more actual data that is actually transferred.
Not the answer you wanted, I know, but the 300mb/hr - 7gb/hr is not being facetious. That range is very realistic.
Also, not all service providers count data the same way. For instance, tethered on my Sprint cell as a wifi hotspot and doing my normal things I was using about 200mb/day. I got a Verizon Mifi hotspot that had a fantastic signal and dl speeds up to 20mbps and I used 5gb in 4 days doing the same stuff. Not a scientifically rigorous test for sure, but Verizon's own online estimator said I would need between 50 and 70GB/month to do what I have been normally doing.
The best way to tell is figure out what might work best for you and do a free 30-60 day trial and see what it works out to be for your usage. Usually, during such a trial, everything up to the trial max data limit is free so be careful to not go over. You will have to pay for the overages.
Best thing to do is always have the wifi in use, prior to watching video's. tv. an if not using wifi turn it off as this will also suck up battery .Also as i have seen this many many times. On androids, not to familar with iphones, when you turn on wifi, make sure you click configure it. as just because you have wifi enabled does NOT mean you are connected.
