Bill B Posted August 2, 2015 Report Share Posted August 2, 2015 I didn't find anything in the Resource guide (possibly there is) but where are the hidden screws in the back and the best way to get at them? I got the 2 on the floor, one under the bottom drawer, but there seems to be a couple hidden in the back. Thanx guys (fridge works just seems to run a long time. I thought maybe cleaning the coils and perhaps a small muffin fan might be in order) Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted August 2, 2015 Report Share Posted August 2, 2015 Volvo Refrigerator Link to comment Share on other sites More sharing options...
JC and Angie Posted August 2, 2015 Report Share Posted August 2, 2015 Ok the trick I found was to use a c clamp on each side to every pull it out from the bottom evenly.. It's on a very tight track and if not pulled exactly even it binds. I used silicone spray on it the tracks when I reinstalled and it's much easier the second time. Link to comment Share on other sites More sharing options...
Bill B Posted August 2, 2015 Author Report Share Posted August 2, 2015 You mean like a page in the HHRV Resource Guide, Drom Boxes Sometimes I wonder if it is worth it. Yes Mark - It really is - I, for one, appreciate it. Sometimes I can't find it but first go to It's on the DROM page but worth repeating!!! I think that I have it. There is an unknown "amount" of dried "adhesive" in the bottom track. One side (hinge) seems to be clear. The door side has the adhesive. I was able to slip a 12" hacksaw blade 10" back on the hinge side and 1" on the swing side. some playing with it and I was able to get it 3" back. I slipped a needle / syringe filled with universal solvent in there and squirted it to help dissolve the adhesive. I think the adhesive is dried soda pop sugar and that was what is restricting movement. JC, took your advise and shot some lube in the hinge side, still waiting on the solvent (water) to work more on the door side. Link to comment Share on other sites More sharing options...
adept99 Posted August 2, 2015 Report Share Posted August 2, 2015 Seems to me that the mounting system on ours was two bolts in the front on the bottom which could be unscrewed, and two more in the rear, also on the bottom, that slid into a kind of clip. Those did not unscrew until the unit was completely removed and you had access to the bottom of the unit. The problem is that the bolts and clips are rusty and really don't want to slide. In addition, the refrig is not (at least in ours) setting on the floor. There is a steel mounting frame bolted to the floor of the cab and the refrig mounts to that. The bolts in the mounting frame are not accessible until the refrig is removed. The purpose of this whole wildly over/badly engineered arrangement seems to be to keep the unit from tipping over during high speed maneuvers. It will come out, but the posts above are correct, you need to pull square and straight and at the bottom of the unit. You need a mechanical advantage, fingers alone will very likely not work. Take the door off - doesn't help getting it out, but keeps it from beating you in the head constantly, which, of course, improves your attitude enormously. Don't get in a hurry (the cabinet sides will break - don't ask) and reassemble with Never-Seize. Good Luck Paul Link to comment Share on other sites More sharing options...
Bill B Posted August 2, 2015 Author Report Share Posted August 2, 2015 Paul - right now I'm going with the soda in the track. The blade came out all sticky and gooey. I wasn't using it as a saw, more like a feeler gage or shim stock. I got the screws out, also had a L bracket by the upper hinge to the cabinet. I'll see if the water works, may even use a second dose. Fingers crossed. Link to comment Share on other sites More sharing options...
