alan0043 Posted July 18, 2015 Report Share Posted July 18, 2015 Hi Everyone, I want to adjust my headlights, fog lights, and driving lights. I want to know what is the best distance that the lights should fall on from the front of the truck. What kind of grid is used to set your lights on ? I also need to know the right to left numbers for setting the lights. I do not want to blind any on coming driver. In short, what are the best measurements to use ? I can use my garage doors to act as the grid for the numbers needed. The fog lights are new to the truck. The driving lights where removed for some maintenance. Thanks for any help, Al 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
Nuke-E Posted July 18, 2015 Report Share Posted July 18, 2015 Hi Al, Let's start with the LED fog lights--those are the easiest. The cutoff at the upper edge of the beam should be at or just below the height of the center of the light. In other words, if the light is 18" off the ground, at a reasonable distance away (e.g. 25 feet), that line should be no higher than 18". The driving lights (assuming they're only on with the high beams) should be aimed straight ahead--there's not going to be a clear reference point in the beam pattern, so you're just trying to get the brightest part of the beam dead ahead. The stock headlights are the hardest to do. They're really meant to be aimed with an aiming tool that uses the three raised nubs on the light housing, instead of being aimed with a visual reference like most newer lights. Left-to-right (the lower inboard adjusting screw), just try to get the brightest part of the beam straight ahead. Then my best suggestion is to park the truck in a large open area and adjust the lights so that you illuminate as much pavement as possible with the low beams. That should get you reasonably close to proper aim. 45' 2004 Showhauler -- VNL300, ISX, FreedomLine -- RVnerds.com -- where I've started to write about what I'm up to Headlight and Fog Light Upgrades http://deepspacelighting.com Link to comment Share on other sites More sharing options...
HERO Maker Posted July 18, 2015 Report Share Posted July 18, 2015 Ask and you will find out. Nice job David. These instructions would do well being added to the Resource Guide. (Mark is probably already on it) It's a wonderful forum! Rocky & Sheri Rhoades '01 Volvo 770 2016 DRV Mobile Suites, HoustonHERO Makers Ministry Link to comment Share on other sites More sharing options...
Darryl&Rita Posted July 18, 2015 Report Share Posted July 18, 2015 A picture worth a thousand words: I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
Nuke-E Posted July 18, 2015 Report Share Posted July 18, 2015 That's a good chart for explaining things, for sure. Just know that it's only for VOR (visual optical right) headlamps--the first-gen trucks are mechanical aim, and the second-gen trucks are VOL. If you have a kit from me, the lab that tested the projectors confirmed that the notch height is such that either VOL or VOR aiming procedures result in the exact same position. VOR is easier in my mind, since I don't have to remember any numbers or do any math--right side of the line goes at the same height as the dimple in the headlight lens. I take issue a little bit with allowing aim above the height of the headlights, especially for something like the Frontier in the image--when you've got a vehicle that's likely to carry a load in the bed or pull a trailer, that will result in a very bothersome aim (and leave the pavement in front of the driver largely in the dark). It's only made worse when those same pickup truck drivers start lifting the trucks, putting the lights outside of the acceptable height range. For the big trucks with air levelling, it's a lot less of an issue though--just make sure the suspension is aired up while you're adjusting. 45' 2004 Showhauler -- VNL300, ISX, FreedomLine -- RVnerds.com -- where I've started to write about what I'm up to Headlight and Fog Light Upgrades http://deepspacelighting.com Link to comment Share on other sites More sharing options...
alan0043 Posted July 18, 2015 Author Report Share Posted July 18, 2015 Hi Al, Let's start with the LED fog lights--those are the easiest. The cutoff at the upper edge of the beam should be at or just below the height of the center of the light. In other words, if the light is 18" off the ground, at a reasonable distance away (e.g. 25 feet), that line should be no higher than 18". The driving lights (assuming they're only on with the high beams) should be aimed straight ahead--there's not going to be a clear reference point in the beam pattern, so you're just trying to get the brightest part of the beam dead ahead. The stock headlights are the hardest to do. They're really meant to be aimed with an aiming tool that uses the three raised nubs on the light housing, instead of being aimed with a visual reference like most newer lights. Left-to-right (the lower inboard adjusting screw), just try to get the brightest part of the beam straight ahead. Then my best suggestion is to park the truck in a large open area and adjust the lights so that you illuminate as much pavement as possible with the low beams. That should get you reasonably close to proper aim. Hi David, Thank you very much for the info. This is going to be a big help. I need to send you a picture of the fog light set-up. If I say so myself, I like how they turned out. Maybe tomorrow when I get more time I can post a picture or too. Thank again for the help, Al 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
Refuzn-To-Grow-Up Posted July 18, 2015 Report Share Posted July 18, 2015 Hi David, Thank you very much for the info. This is going to be a big help. I need to send you a picture of the fog light set-up. If I say so myself, I like how they turned out. Maybe tomorrow when I get more time I can post a picture or too. Thank again for the help, Al Al Yes, please, post a pictures of your fog light set-up. In some of the remote areas where I camp, there are no street lights and, I would like additional lighting. BTW - I just received my light set upgrade (see above) and hope to install it this week. Jim Link to comment Share on other sites More sharing options...
heavyduty Posted July 18, 2015 Report Share Posted July 18, 2015 Ha guys good info. One question I would like to ask. My headlight lenses are very bad far beyond polishing. I would like to replace them but my question do I need to by new housings then order the dixon upgrade or can you by housings with the upgrade already in them. Link to comment Share on other sites More sharing options...
Mark and Dale Bruss Posted July 18, 2015 Report Share Posted July 18, 2015 Added to the Resource Guide Please click for Emails instead of PM Mark & DaleJoey - 2016 Bounder 33C Tige - 2006 40' Travel SupremeSparky III - 2021 Mustang Mach-e, off the the Road since 2019 Useful HDT Truck, Trailer, and Full-timing Info atwww.dmbruss.com Link to comment Share on other sites More sharing options...
Nuke-E Posted July 18, 2015 Report Share Posted July 18, 2015 Ha guys good info. One question I would like to ask. My headlight lenses are very bad far beyond polishing. I would like to replace them but my question do I need to by new housings then order the dixon upgrade or can you by housings with the upgrade already in them. Buy the housings, then the upgrade. You can install the kit in the new lights and plug them in to test everything before you pull the old lights out pretty easily. I've done it a couple of times pre-installing the kit, but I don't keep the housings on hand--I don't get a better deal than you would, and shipping those things twice gets expensive (in the boxes they're huge). Since you'd be replacing the optics anyways, I recommend the Depo housings. They're a lot cheaper than the real deal from Volvo--$340 from Advantage Truck Center is about the best price I've seen (not including the no-name knock-offs, which aren't worth messing with). 45' 2004 Showhauler -- VNL300, ISX, FreedomLine -- RVnerds.com -- where I've started to write about what I'm up to Headlight and Fog Light Upgrades http://deepspacelighting.com Link to comment Share on other sites More sharing options...
alan0043 Posted July 20, 2015 Author Report Share Posted July 20, 2015 Al Yes, please, post a pictures of your fog light set-up. In some of the remote areas where I camp, there are no street lights and, I would like additional lighting. BTW - I just received my light set upgrade (see above) and hope to install it this week. Jim Jim http://s1310.photobucket.com/user/alan0043/media/July15-2015%20273_zpsbmqkzyne.jpg.html?sort=3&o=12 Here is one photo. I can post more if wanted. Al 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted July 20, 2015 Report Share Posted July 20, 2015 Did you make the housing for the outside round lights? Looks nice! Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
alan0043 Posted July 22, 2015 Author Report Share Posted July 22, 2015 Did you make the housing for the outside round lights? Looks nice! Thanks Jim. I bought the LED fog lights off of David from Deep Space Lighting. And yes I did make the bracket with the help of a friend for the lights. I have included a picture of the parts that where used. 2012 Volvo VNL 630 w/ I-Shift; D13 engine; " Veeger " Redwood, model 3401R ; 5th Wheel Trailer, " Dead Wood " 2006 Smart Car " Killer Frog " Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted July 22, 2015 Report Share Posted July 22, 2015 Save your plans, someone might just be willing to buy a set from you! Alie & Jim + 8 paws 2017 DRV Memphis BART- 1998 Volvo 610 Lil'ole 6cyl Cummins Link to comment Share on other sites More sharing options...
