chuckbear Posted July 18, 2015 Report Share Posted July 18, 2015 Is there an adapter or connector that can be attached to my main propane tank so I can connect our grill without carrying additional 20 lb. tanks? I already have a hose extension. Chuck Chuck and Susan 1999 Fleetwood Bounder 34 Triton V10 on Ford Chassis Link to comment Share on other sites More sharing options...
Daveh Posted July 18, 2015 Report Share Posted July 18, 2015 I have been trying to figure this out over the last couple of days also. Looked at these two. http://www.adventurerv.net/3port-propane-tee-only-camper-p-1303.html http://www.adventurerv.net/degrees-propane-tee-only-camper-p-1307.html Dave and Lana Hasper Link to comment Share on other sites More sharing options...
chuckbear Posted July 18, 2015 Author Report Share Posted July 18, 2015 I see these T connectors. But there needs to be a way to shut off the extra line when not used. Chuck Chuck and Susan 1999 Fleetwood Bounder 34 Triton V10 on Ford Chassis Link to comment Share on other sites More sharing options...
Daveh Posted July 18, 2015 Report Share Posted July 18, 2015 I think these automatically shut off upon disconnect but now I don;t see where I read that. Dave and Lana Hasper Link to comment Share on other sites More sharing options...
Daveh Posted July 18, 2015 Report Share Posted July 18, 2015 Here is where I read it. In the questions and answers, http://www.amazon.com/Camco-59133-Brass-Tee-ports/dp/B000NHLG6W Dave and Lana Hasper Link to comment Share on other sites More sharing options...
chuckbear Posted July 18, 2015 Author Report Share Posted July 18, 2015 Thanks. This looks like just what I need. Will have to check the RV tomorrow to make sure it can be installed OK. Chuck Chuck and Susan 1999 Fleetwood Bounder 34 Triton V10 on Ford Chassis Link to comment Share on other sites More sharing options...
GeorgiaHybrid Posted July 18, 2015 Report Share Posted July 18, 2015 The quick connect propane connectors have a built in shut off valve that has to be closed to to put the hose on/off. Do NOT use regular airline quick disconnects. Just run a gas line under the coach to whereever you want them from your main gas line and add a disconnect fitting to the hose and gas line similar to this: http://www.amazon.com/Camco-59853-Propane-Quick-Connect/dp/B007HG7TFO/ref=sr_1_1?ie=UTF8&qid=1437182719&sr=8-1&keywords=propane+quick+disconnect We use the one under the coach for our grill and I also made a "T" fitting for that plugs into the original port and tees off to two ports. That allows me to hook up the grill and our firepit to one line. Our DRV came with the original line that is just under the basement door on the door side of the trailer. I use a 15' hose on the grill and 30' on the fire pit to be able to move them where needed. 2017 Kenworth T6802015 DRV 38RSSA Elite Suites2016 Smart Prime Link to comment Share on other sites More sharing options...
bobsallyh Posted July 18, 2015 Report Share Posted July 18, 2015 Is your grill low pressure or high pressure? If low pressure you can tap into an onboard propane line going to refer, water heater, etc. Put on propane quick disconnects and you are good to go. If high pressure, you will need to come off a tank with a tap before the regulator. I use a low pressure grill. I black piped a line with a shut off valve where I tapped in, then under the fiver to the opposite side (passenger side) put on a quick disconnect there and jack the grill in and out. The propane quick disconnects come with a built-in shut off. Link to comment Share on other sites More sharing options...
chuckbear Posted July 18, 2015 Author Report Share Posted July 18, 2015 This is the grill we bought. It's designed for the small gas bottles but we want to run it off our main tank under the coach. http://www.amazon.com/gp/product/B0009V1BDA?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00 Chuck and Susan 1999 Fleetwood Bounder 34 Triton V10 on Ford Chassis Link to comment Share on other sites More sharing options...
mscans Posted July 20, 2015 Report Share Posted July 20, 2015 I put this http://www.amazon.com/Camco-59123-Propane-Brass-Port/dp/B0014JG7RQ/ref=sr_1_1?ie=UTF8&qid=1437413148&sr=8-1&keywords=extend+a+stay+propane+kit&pebp=1437413161520&perid=0Y8MTSJFJXEFSC8KEH12 on my MH to allow just what you want to do. worked great. Happy Trails, Florida Mike EXPERTS AREN'T!! Link to comment Share on other sites More sharing options...
bobsallyh Posted July 21, 2015 Report Share Posted July 21, 2015 Chuck Bear, since your grill is high pressure (after seeing picture) the item Mike57 posted is just what you need to do the trick. Link to comment Share on other sites More sharing options...
chuckbear Posted July 21, 2015 Author Report Share Posted July 21, 2015 Thanks everyone. I'm trying to buy that brass tee without the hoses. Harder to find. Chuck Chuck and Susan 1999 Fleetwood Bounder 34 Triton V10 on Ford Chassis Link to comment Share on other sites More sharing options...
mscans Posted July 22, 2015 Report Share Posted July 22, 2015 Camco PN 59113 is the 4 port brass tee by itself. Good luck. Happy Trails, Florida Mike EXPERTS AREN'T!! Link to comment Share on other sites More sharing options...
