rebntx Posted June 28, 2015 Report Share Posted June 28, 2015 The level of fluid in the reservoir for my hydraulic jacks is very low. My manual does not tell me what kind of fluid to put in the reservoir and nobody I talk to seems to know...do you? Link to comment Share on other sites More sharing options...
Darryl&Rita Posted June 28, 2015 Report Share Posted June 28, 2015 What brand? Different brand, different fluid. What temperatures? Different temps, different fluid. I have been wrong before, I'll probably be wrong again. 2000 Kenworth T 2000 w/N-14 and 10 speed Gen1 Autoshift, deck built by Star Fabrication 2006 smart fourtwo cdi cabriolet 2007 32.5' Fleetwood QuantumPlease e-mail us here. Link to comment Share on other sites More sharing options...
pjstough Posted June 28, 2015 Report Share Posted June 28, 2015 If you have a HWH system, you can use Dexron automatic transmission fluid. I am not sure what other manufacturers recommend. 2005 Winnebago Voyage 38J Link to comment Share on other sites More sharing options...
Big Greg Posted June 28, 2015 Report Share Posted June 28, 2015 Not sure which system you have but Quadra's Big Foot leveling systems use this, from their website: "Our Pumps require ATF (Dexron III) do NOT use hydraulic fluid in our systems." Greg Greg & Judy Bahnmiller Class of 2007 2014 F350 2007 HitchHiker Champagne Both sold 2/19, settled in Foley, AL after 12 years on the road http://bahnmilleradventure.blogspot.com/ Link to comment Share on other sites More sharing options...
Devilishjim Posted June 28, 2015 Report Share Posted June 28, 2015 Make sure legs are up when filling reservoir Jim Spence 2000 Dodge 3500 1 ton QC 4x4 dually 5.9 diesel LB BD exhaust brake, 6 spd manual trans 34CKTS Cedar Creek 5er, Trail-Air hitch Link to comment Share on other sites More sharing options...
Biker56 Posted June 28, 2015 Report Share Posted June 28, 2015 Power Gear use Mercon V Full Time since Oct. 199999 Discovery 34Q DP | ISBDatastorm | VMSpc | Co-Pilot Live | Pressure Pro2014 MKS Twin Turbo V6 365 HP Toad Link to comment Share on other sites More sharing options...
docj Posted June 28, 2015 Report Share Posted June 28, 2015 RVA jacks use Dexron III also. But for RVA jacks put one jack down ~6 inches when filling the reservoir. Sandie & Joel 2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12 2014 Honda CR-V AWD EX-L with ReadyBrute tow bar/brake systemWiFiRanger Ambassador Follow our adventures on Facebook at Weiss Travels Link to comment Share on other sites More sharing options...
Kirk W Posted June 30, 2015 Report Share Posted June 30, 2015 Both brands of jacks that I've used called for Dexron III. I can't recall ever seeing one that used hydraulic fluid. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
Ray,IN Posted June 30, 2015 Report Share Posted June 30, 2015 Quote from the HWH FAQ page: "The use of HWH Specialty Hydraulic Oil is recommended but Dexron or multipurpose transmission fluids can be used if necessary. DO NOT use hydraulic jack oil, brake fluid, or power steering fluid." 2000 Winnebago Ultimate Freedom USQ40JD, ISC 8.3 Cummins 350, Spartan MM Chassis. USA IN 1SG retired;Good Sam Life member,FMCA ." And so, my fellow Americans: ask not what your country can do for you--ask what you can do for your country. John F. Kennedy 20 Jan 1961 Link to comment Share on other sites More sharing options...
Kirk W Posted June 30, 2015 Report Share Posted June 30, 2015 My manual does not tell me what kind of fluid to put in the reservoir and nobody I talk to seems to know...do you? Wondering what make your jacks are, and do you mean the manual for the motorhome or the one for the jacks that is published by the jack manufacturer? If you need a copy of the one from the manufacturer, many of the companies have those available online. Good travelin !...............KirkFull-time 11+ years...... Now seasonal travelers.Kirk & Pam's Great RV Adventure Link to comment Share on other sites More sharing options...
57becky Posted July 2, 2015 Report Share Posted July 2, 2015 The Lippert products all call for ATF, but specifically say to not use Type F, as it will cause seal failure. One thing to understand is, ATF is hydraulic fluid, it just has a dye in it and special additives to help it work in transmissions. Link to comment Share on other sites More sharing options...
mscans Posted July 2, 2015 Report Share Posted July 2, 2015 The storage tank sometimes has that info cast or labeled on it. As others said, find the manufacturer and look up on the net. Failing ALL that post a picture of the leg or pump unit here and someone will recognize it I'm sure. Happy Trails, Florida Mike EXPERTS AREN'T!! Link to comment Share on other sites More sharing options...
