KodiakJack Posted June 27, 2015 Report Share Posted June 27, 2015 The D-seals on our rigs slides have deteriorated badly. I ordered these (http://www.amazon.com/gp/product/B007EXP006?psc=1&redirect=true&ref_=od_aui_detailpages00) to replace them. Only the upper horizontal seals are bad with the vertical one showing much lesser signs of going bad. Worth mentioning is the bad ones were very bad. Looking more or less like they melted in place. Only heat or chemical reaction comes to mind as what would cause them to melt and adhere to the outer slide flange. At any rate I used acetone to clean up the slide flanges pretty well but would like to clean and lubricate all the rest of the seals while I am at it. Any recommendation for product(s) to do this? Later, J 2012 Landmark, San Antonio 2013 Silverado CC, 3500HD, Duramax, DRW, 4x4 Backup, side and hitch cameras, Tireminder TPMS Link to comment Share on other sites More sharing options...
kathydavidb Posted June 27, 2015 Report Share Posted June 27, 2015 For cleaning I don't know but would try different cleaners on small sections. For protection I like to use Aerospace 303 protectant. 2006 Coachmen Aurora 36ft. Class A motor home. 2009 Honda CRV toad. "Snowbirds" apprx. 6 mos. each year. Travelling to the SW each winter than returning to Wi. each summer. Retired and enjoying our travels along with Buddy the cat. Link to comment Share on other sites More sharing options...
rynosback Posted June 29, 2015 Report Share Posted June 29, 2015 For cleaning I don't know but would try different cleaners on small sections. For protection I like to use Aerospace 303 protectant. I agree Aerospace 303 is what I am going to use on our rig. 2015 Ram 3500 RC DRW CTD AISIN 410 rear 2016 Mobile Suites 38RSB3 Link to comment Share on other sites More sharing options...
oscarvan Posted July 1, 2015 Report Share Posted July 1, 2015 After having put various potions and lotions on slide seals I have determined that the absolute best treatment is ..... nothing. Previously a 2017 Forest River, Berkshire 38A, "The Dragonship". https://dragonship.blog/ Link to comment Share on other sites More sharing options...
Hollardawg Posted July 13, 2015 Report Share Posted July 13, 2015 I just replaced several of our slide seals. I used Simple Green to clean the remaining seals. It does a great job. Now using Aerospace 303 to protect them. Larry & Joan WhitworthDaisy - The Japanese ChinAlex - The Tibetan Spaniel2010 Crossroads Kingston KF36CK2008 F-250 6.4LEdge Evolution ProgrammerFull Time Since 2007 USMC 1963-1969 Vietnam 1965-1966 Link to comment Share on other sites More sharing options...
rdickinson Posted July 13, 2015 Report Share Posted July 13, 2015 www.pplmotorhomes.com/parts/caulks-sealants/38-9004.htm The product I was given by an RV repair firm is called Slide out Rubber seal treatment. Made by Protectall. Red can, white cap. It is a foaming product like some tire cleaners. It cleans and lubricates, UV inhibitor and reduces friction, which over a long horizontal and a couple of verticals can add up to quite a bit. You have to double that because you have to do both inside and outside. Some areas are tuft to get at but generally a telescoping handle can reach them. You would be amazed at the amount of crud that comes off. No one can convince me leaving that on is a good thing. Link to comment Share on other sites More sharing options...
