What size water pump?
What size water pump do you have? Ours has a 2.6 gpm rating and the flow is fine but the DW would like a little better shower pressure/volume when needed.
Just curious what size others have.
Thanks
upon review, this may be in the wrong forum section. sorry.
2016 Volvo VNL780 D13 I-Shift
2016 DRV 44 Houston
2015 Smart Cabriolet
Loved the output of the Shurflo SmartSensor 5.7gpm pump, but each one lasted an average of a year or less. After the last failure I replaced it with a Flojet vsd 4.5gpm. It works fine, but I am not real happy with it ... doesn't seem much better than the Shurflo 1.8gpm I kept as a backup when the 5.7 kept failing. In reading the specs I find it has a much lower psi than the Shurflo. I believe Shurflo has a variable speed 4.6 gpm model. In retrospect I wish I had tried it or an Aquajet rather than the Flojet.
'05 Honda Odyssey
Escapees, FMCA, WIT, SMART
http://www.pjrider.com
http://www.rvwaterfilterstore.com/Pumps.htm
Scroll down the page to the AquaJet ES. Working great for us.
Thanks Guys.
I saw the AquaJet and was leaning towards that but wasn't sure if you could have TOO much of a good thing (gpm)!! LOL
I'll probably head in that direction.
2016 DRV 44 Houston
Just put a Oxygenics shower head on, problem solved.
Jim
I am also going to acquire one of these too. My DW really likes a shower that she can turn off while lathering without having to mess around with the temperature.
2016 DRV 44 Houston
We are now using a Shurflo 4048 (4 gpm) pump and carry a spare. Loved the old Shurflo 5.7 but it was way too much work to keep repairing it.
Later,
J
PS Our Oxygenics shower head is great, especially when boondocking.
2012 Landmark, San Antonio
2013 Silverado CC, 3500HD, Duramax, DRW, 4x4
Backup, side and hitch cameras, Tireminder TPMS
I installed an oxygenics shower head and when I pause it, the water quickly gets cold. If I cut it off with a
separate on/off valve, it just gets a little cooler. And I didn't like the spray pattern and couldn't figure
out how to adjust it, so I went back to my camco shower head with a separate on/off valve because the camco
valve was hard to work. I have an aquajet pump which I like.
2003 Coachman Chaparal 276 RLS
2000 F250, 7.3l auto ext. cab 4x4
RV Cable Grip
RV Cable Grip
RV Air.
