chuckbear Posted June 14, 2015 Report Share Posted June 14, 2015 The deal on the previous RV we looked at fell through. But we have found a very, very nice 34 foot Bounder. One issue I have is that the roof coating is chalking pretty bad and there are streaks running down the sides and front of the coach from the roof. What will be required to correct this? Is it something I can do myself or will it need to go in for service?No indications of leaks though. Chuck Link to comment Share on other sites More sharing options...
jblscooper Posted June 14, 2015 Report Share Posted June 14, 2015 Are you saying that the roof has had a "coating" of some type applied over the original roof? We have applied Liquid Roof coating to our EPDM due to age, no damage. We do not get streaks from the coating. You might try to find out what was used on the roof. Jim Link to comment Share on other sites More sharing options...
chuckbear Posted June 14, 2015 Author Report Share Posted June 14, 2015 I'm not knowledgeable enough t know. There is either a uniform coating or some kind of material overlaid on the roof. This is chalking when I run my hand over it and causes light streaks to run down the front and sides when it rains. It's a 1999 Bounder Class A. Chuck Link to comment Share on other sites More sharing options...
Daveh Posted June 14, 2015 Report Share Posted June 14, 2015 I have not had to deal with this issue yet. Seems like it is known maintenance item though http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/25549318.cfm Link to comment Share on other sites More sharing options...
SIBERNUT Posted June 14, 2015 Report Share Posted June 14, 2015 My fiver had chalking of the fiberglass roof, looked like guano running down the back. Tried scuffing it and coating it with automotive clear (2 part). Not so good, peeled after a couple of years. Sanded it REAL good, rolled on a fresh coat of activated FG gel coat. seems to have worked. But you gotta' work FAST.... Link to comment Share on other sites More sharing options...
trailertraveler Posted June 14, 2015 Report Share Posted June 14, 2015 What type of roof material are you talking about? EPDM rubber roofs chalk as part of the aging process. There are products that will help reduce the chalking. If it is an EPDM roof, I suggest you visit the Dicor website and read the Frequently Asked Questions (FAQ) section and view some of the RV maintenance videos that they have available. Link to comment Share on other sites More sharing options...
Kirk W Posted June 14, 2015 Report Share Posted June 14, 2015 The 99 Bounder came with an EDPM roof so I'd bet that is what you have. As stated above, chalking is a normal part of the aging process but there are things which can be done to slow the process. If yours is doing it a great deal, the first thing that I'd do is to examine the roof very carefully all over it. The Dicor roofs of that time came with a 12 year warranty on materials and since yours is now 16 years old it may be nearing the end of it's useful life, depending upon the type and amount of care it has had. I would want to make sure that it is still in good enough condition to warrant the continued use and if not then you need to know that so that you can plan how you will make the roof stay weather tight in the future. Link to comment Share on other sites More sharing options...
chuckbear Posted June 14, 2015 Author Report Share Posted June 14, 2015 All good info. Much appreciated. Chuck Link to comment Share on other sites More sharing options...
kathydavidb Posted June 14, 2015 Report Share Posted June 14, 2015 My '06 Coachmen class A MH with EDPM roof did have some streaking down the sides. I also used the Dicor products and that helped. No streaks now. I had to use the cleaner first and then the sealer after. It took a couple of days but was well worth it. Check out Dicor products at a local RV store. Dave. ( I have no reason to recommend this, only that it worked for me.) Link to comment Share on other sites More sharing options...
chuckbear Posted June 15, 2015 Author Report Share Posted June 15, 2015 Thanks Dave. I will check it out. Link to comment Share on other sites More sharing options...
