ganto Posted June 17, 2015 Report Share Posted June 17, 2015 Or could you do your lathe work in the hrs when AC isn't needed ? Maybe a couple box fans ? http://www.honeywellstore.com/store/products/honeywell-whole-room-air-circulator-fan-ht-908.htm I swear by these there quiet and they push a lot of air for when it's not to hot. and they run forever you can't kill em. you can also get them on amazon for 20.99 vs honeywells site Link to comment Share on other sites More sharing options...
GdognTimber Posted June 17, 2015 Report Share Posted June 17, 2015 I am very interested to hear your report on these. Keep us posted. Where did you end up purchasing from? Home is where you park your heart, or your tires for the night. Link to comment Share on other sites More sharing options...
ganto Posted June 18, 2015 Report Share Posted June 18, 2015 I am very interested to hear your report on these. Keep us posted. Where did you end up purchasing from? who were you talking to? Link to comment Share on other sites More sharing options...
preston-y Posted June 21, 2015 Report Share Posted June 21, 2015 I asked for some advise awhile back on good ideas on what i might need for my 5th wheel.Today I took delivery on a pair of Yamaha EF2000is with the parallel cable set. Will be putting them on the trailer tomarrow.It's hot here in Tucson Az. So this will be a good test on how it will work out for us. Thanks again for all the help. STAY SAFE AND COOL. Link to comment Share on other sites More sharing options...
Devilishjim Posted June 21, 2015 Report Share Posted June 21, 2015 I asked for some advise awhile back on good ideas on what i might need for my 5th wheel.Today I took delivery on a pair of Yamaha EF2000is with the parallel cable set. Will be putting them on the trailer tomarrow.It's hot here in Tucson Az. So this will be a good test on how it will work out for us. Thanks again for all the help. STAY SAFE AND COOL. May I suggest that you install hr meters on them so you can keep track of when it's time to change oil. Also if they will be sitting for a month or more inactive I suggest draining the carbs because the idle jets are so small they gum up very easy. At least on my Hondas they do. Jim Spence 2000 Dodge 3500 1 ton QC 4x4 dually 5.9 diesel LB BD exhaust brake, 6 spd manual trans 34CKTS Cedar Creek 5er, Trail-Air hitch Link to comment Share on other sites More sharing options...
TXiceman Posted June 21, 2015 Report Share Posted June 21, 2015 A good thing to remember on any of the portable generators is to keep Stabilt or SeaFoam in the gas at all times. All the gas now has ethanol and it does not store well. Also make sure you run the generator dry of gas or drain the carb. I drain the carbs on my Hondas and keep SeaFoam in the gas. They always start easily and run smoothly. Ken Amateur radio operator, 2023 Cougar 22MLS, 2022 F150 Lariat 4x4 Off Road, Sport trim <br />Travel with 1 miniature schnauzer, 1 standard schnauzer and one African Gray parrot Link to comment Share on other sites More sharing options...
0369 Posted June 22, 2015 Author Report Share Posted June 22, 2015 Thanks for all of the advice. I use a marine additive called Startron for the dingy engine for my boat that supposedly neutralizes the alcohol in gas and haven't had a problem yet. I ended up getting the generators at a local farm supply called Farm and Fleet here while on sale. Jim and Sue, definitely correct on the jets. When I had a motorcycle shop years ago about 90% of ill running bikes were clogged up pilot circuits in the carbs. Link to comment Share on other sites More sharing options...
GdognTimber Posted June 23, 2015 Report Share Posted June 23, 2015 0369, How did the 2 Champion Units work Out? Home is where you park your heart, or your tires for the night. Link to comment Share on other sites More sharing options...
0369 Posted June 23, 2015 Author Report Share Posted June 23, 2015 I just added gas and oil to fire them up. I should get them under a load next week some time. Link to comment Share on other sites More sharing options...
preston-y Posted June 27, 2015 Report Share Posted June 27, 2015 i started up the 2 gens 1 hr ago. The inside of the traire is cooling off just fine. It's already over 100 out side with high humidity for Az . So this will be agood test . We are looking forward to seeing all of you out there , as we are going to be fulltimers soon. TAKE CARE AND SAFE TRAVELS. Link to comment Share on other sites More sharing options...
