NeverEasy Posted June 5, 2015 Report Share Posted June 5, 2015 Wanted to pull the knobs today. Playing with the mill and lathe was fun, too. Made a tool that sort of looks like a chain breaker I had. Works good. Line-up with little pin. Screw in and pin drops out the bottom. Link to comment Share on other sites More sharing options...
Hewhoknowslittle Posted June 5, 2015 Report Share Posted June 5, 2015 Very nice. Link to comment Share on other sites More sharing options...
ray.service Posted June 5, 2015 Report Share Posted June 5, 2015 Where were you last year when I needed this? Link to comment Share on other sites More sharing options...
sclord2002 Posted June 5, 2015 Report Share Posted June 5, 2015 What a great little tool....bet you could sell them to those of us without the mill and lathe [or the skill to use them]....... Charlie Link to comment Share on other sites More sharing options...
Alie&Jim's Carrilite Posted June 6, 2015 Report Share Posted June 6, 2015 So where is the sign up for the "Loan a Tool" program?.. Great idea! Link to comment Share on other sites More sharing options...
NeverEasy Posted June 6, 2015 Author Report Share Posted June 6, 2015 Maybe I should make a loaner. I can mail it to the first requester and he/she can pass it on to the next. Doesn't take long now that I have the dimensions. I will certainly take one to the next rally. Link to comment Share on other sites More sharing options...
Bill B Posted June 6, 2015 Report Share Posted June 6, 2015 Mine has spring loaded buttons, I just used a small screw driver. No press fit or anything, Link to comment Share on other sites More sharing options...
SuiteSuccess Posted June 6, 2015 Report Share Posted June 6, 2015 Very nice. Steve Dixon got me one of similar design off Amazon for my b-day while at the ECR. Don't know what it was called. Link to comment Share on other sites More sharing options...
NeverEasy Posted June 6, 2015 Author Report Share Posted June 6, 2015 Ssssh! Now you tell me. I can make mine better now. I like the open slot at the bottom so you can see the pin coming out. Plus, you can take the tool off easier half way through. On mine I just made a larger hole in the bottom piece to allow the tool to be removed at any point in the process. I hope the push pin on this one is the right size. http://www.amazon.com/E-Z-Red-PPT13-Pin-Remover/dp/B00BI2M7H8/ref=sr_1_29?ie=UTF8&qid=1433591220&sr=8-29&keywords=pin+remover Link to comment Share on other sites More sharing options...
SuiteSuccess Posted June 6, 2015 Report Share Posted June 6, 2015 Yours is very nice. Maybe appearance on "Shark Tank"? Link to comment Share on other sites More sharing options...
SunJuniper Posted June 7, 2015 Report Share Posted June 7, 2015 id happily buy one of these from you Nevereasy... damn roll pins can be a pain to get out sometimes. loan wouldnt work for me as i tend to tinker on mine and friends trucks. Link to comment Share on other sites More sharing options...
NeverEasy Posted June 7, 2015 Author Report Share Posted June 7, 2015 I will make you one if you wish when I get back from Yellowstone in July. The one from Amazon is only $15. The only advantage mine might have (don't know the length of the one on Amazon) is overall length. I made it so that the length of threads is barely enough to push out the pin because of the distance between the two knobs. The knobs are positioned such that the pins are in-line making it necessary to put the tool between the two air valve stems. Link to comment Share on other sites More sharing options...
